Zen Mod
Administrator
Sve objavljeno od Zen Mod
  1. nista ne fali smd
  2. zvucace kockasto
  3. pa smanjite gain
  4. https://www.rts.rs/radio/radio-beograd-2/5444796/uvek-drugi.html
  5. msm, šta reći ...... Fiat je Fiat, ali DKW Rulez!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  6. vukao pržinu u prikolici, isto tako vukao drva, cement, vukao stogove sena po oooogromnoj livadi, okretao na uskom putu ubrdo Wartburg je bio jos u normalnoj eksploataciji ali je planirana skora zamena, tako da je bilo ..... ajde mali uci se sem neumitnog grebanja laka kupinom, nikakvu štetu nisam napravio
  7. meni su dali Wartburga da obavljam poslove po Ličkim vrletima kad sam imao 14, tako da su me predupredili od želje za krišom praktično sam radio poslove koji se rade motokultivatorom ..... pa ti vidi koja je to avantura bila
  8. ja sa mojom imam dogovor da svak gleda svoj poso
  9. Admin nije ni za qrc, odavno
  10. a sta fali motor run, Ducati i Icar?
  11. Big DiyA Store web reorganizovan The diyAudio Store - DIY amplifier kits, chassis, and parts DIYAUDIOSTORE.COM DIY amplifier kits, amplifier chassis, hard to find transistors and circuit boards i onda, dva draguljcica (ZM nema materijalnog interesa u Store, to bese/behu/su pokloni u korist Greedy Boyz) Iron Pre DIYAUDIOSTORE.COM There are two versions of the Iron Pre: Balanced / Differential and Single-Ended. Builders of the balanced version can select balanced or single-ended for each input. The boards include not only the “iron-based” gain stage, but also a shunt-regulated PSU section, and a relay-based input switching section. A total Project Aleph JZM DIYAUDIOSTORE.COM New Product Information - 100 kits are available for immediate purchase. In addition, we are taking a set number of pre-orders for the next batch, which is expected to ship no later than July 2024. Learn how pre-orders work. The Nelson Pass designed First Watt Aleph J is a classic. Various versions of the Aleph J have
  12. ne moze, moras da nabavis releje koji odgovaraju kolu takva je konstrukcija napajanje za releje je takvo kakvo je, logika istog podsklopa nije samo da napoji releje nego i da ima uktrakratku vremensku konstantu, da bi se releji iskljucivali momentalno po iskljucenju pojacala na glavni prekidac svima nama je najdraze kad ne samo da ne moramo da platimo za neki novi deo, nego ihaj jos kad mozemo da iskoristimo ono sto imamo po fiokama no, vremenom se izgradi kriterijum koliko prepravki originalnog kola je smisleno, da bi se iskoristio deo iz fioke da ne pricam o slucajevima kad ne mozes ni prepraviti kolo da bi koristio receni deo
  13. kako mislis da napojis 48Vdc rele sa 38Vac sa polutalas ispravljanjem?
  14. The Beast with Thousand JFets
  15. ja imam Basetech ZD-8925 vec par godina, radi za sve pare
  • Trenutno na sajtu   0 članova, 0 Skrivenih, 391 Gosta (Pogledaj celu listu)
    454k
    DusanJovanovic
    DusanJovanovic
