Zen Mod
Administrator
Sve objavljeno od Zen Mod
  1. Zen Mod
    Babelfish ᄅſ
    then yesterday and today I put it in T-Bed , and did some final tweaking of some values for start , they're equipped with 1+1 Toshiba 2SK170BL in FE , Iq set at 10mA (5mA per tiny) and pair of goodoldsturdy IRFP150 are in OS
  2. Zen Mod
    Babelfish ᄅſ
    few days ago , I received 0 series pcbs , and did some stuffing
  3. Zen Mod
    Babelfish ᄅſ
    while we at Eagle files , two more
  4. Babelfish ᄅſ Seeing some stones turned lately , I simply couldn't resist Babelfishing urge...... Though , as I already did some mild Babelfishing of our dear and beloved J2 , logically that this time I needed to do something ...... completely different due to constant demand and popularity mainly on Far and less Far East , schematic of original FW J2 is still generally unknown or - better said - none of circulating DIY schematics weren't blessed by Mighty Pa (pleonasm here , Pa is Mighty by 42) few things we all know , and these few things are good and plenty enough for basic postulates of variation of Jazz Standard Basic premises : 1. possibility of incorporating less critical ( for acquire) JFets for input LTP, by choice and must possible use of 1+1 , or 2+2 in same ; 2. possibility of incorporating various output devices , of lesser and bigger rarity and/or price 2a. possibility to avoid tearfully matched parts (outputs and other ) , while still easy settable both output offset and OS Iq in broad range of values I got it all ........ how: 1.easy peasy - use N channel JFets (choice is waste!) , lead them (currents) back to lower output gate via simple and effective current mirror ..... put few cascodes here and there to pet both JFets and fine CM parts (tiny JFets are always grateful for that, but high beta small BJTs like that too) ....... and while we are there - why not using fine emiter follower between CM final end and lower output's gate ....... 2. OK - trimpot in front of lower output's gate is trivial ; second part is feeding Optocoupler with CCS , with some current spare , and routing the same in loop around ( in parallel practically) said optocoupler , so we can set Iq of upper mosfet with ease and in broad range 2a.partly already covered above , just to add that output devices can be plain old IRFP150 , same as any boutique part you already have , value of Ugs is irrelevant - easily covered with change of ,say, two resistors 'nuff talking , time for schm (read notes on left side):
  5. nazovi i izdiktiraj tu prostoprosirenu recenicu ako te pita da li je napon pod opterecenjem , ti reci bas me briga , naravno da jeste
  6. 0.16% na punoj snazi od 25W/8R
  7. 20W , staticki i magnetni oklop 38V sa srednjim izvodom licnasti izvodi i primar i sekundar , duzine 20cm , primar naspram sekundara sa tim tvojim opterecenjem sekundarni napon ce biti i visi , i racunao sam sa tim , pokriven si sve situacije - i -15% u mrezi ako se desi
  8. msm , stvarno .......
  9. ko je ista rekao o kupovini novoga ? DIY , naravski .......
  10. pa ima - T-Bed , napravljen za to a na gomili (treba sastavljati al ce kad bude moranje) sve za jos jedan T-Bed , da se ima a onda ce morati da se sastavi demo primerak ......
  11. bolje Cornwall IV ili jos bolje Klipschhorn ili jos bolje Jubilee
  12. ima sve EMU1212 od pre a stigao i Quantasylum mozda sutra i prosvira , why not ........ mada sumnjam da cu imati kad da merim
  13. il ce bude slavni propadaus , il ce bude zanimljiv projektic
  14. pa lepa ograda .....
  15. ma maleno je to , ko japanski kanister od 20L
  16. ja ne znam sve ali ima ko zna ako je drugacije od ovoga , onda se neko igrao imzenjera https://www.rane.com/note110.html
  17. ozdo bolan , samo ce ti se kaze kad dobijes pcbs , jedna fotka od mene ce ti bude dosta obicna lemilica i tinol 0.5 sve radi
  18. moze i drugi tip , sta god da nadjes od blok kondova , svejedno nece biti ispod 50V i to je OK predmetne imas u Silkenu
  19. bas si shonnast
