855 -
1
Sve objavljeno od ab
Bobby Troup https://www.youtube.com/channel/UC3vOR1i5ImJXwV1-T3wG9Nw "Meaning of the Blues" by Bobby Troup and Leah Worth - Live at The Lab
Clark Terry And Marian Mcpartland Skylark
Larry Coryell - goodbye porkpie hat
Pretpostavljam da si poslao Italijanima SN?
Tako brzo italijani poslali novi firmware?Obavezno probaj hiface i na nekom drugom racunaru, ne daj Boze da je on ostecen.
Trazi od M2Tech-a noviji firmware i resi problem.
Ja se drzao preporucenog, nisam bio u situaciji da biram - lepo je znati pa makar i naknadno. Hvala za info.
Reko moze nekome biti interesantno ko se nije susretao, nije da namecem
Sto se tice nabavke potrebnih el.komponenata, AMB Audio shop - spisak sledecih potrebnih komponenata: ItemsDisplay filter: Show all items By project: CK²III headphone amplifier By project: LCDuino-1 display I/O processor By project: Mini³ portable headphone amplifier By project: M³ headphone amplifier By project: α10 stereo pre-amplifier By project: α20 line amplifier By project: α24 fully-differential line amplifier By project: β22 amplifier By project: β24 fully-differential power amplifier By project: γ1 modular miniature DAC By project: γ1.5 miniature high resolution USB DAC + headphone amplifier By project: γ2 compact high performance DAC By project: γ3 high resolution DAC By project: δ1 relay-based R-2R stereo attenuator By project: δ2 relay-based stereo input/output selector By project: ε12 delay/muting/protection for headphone amplifier By project: ε24 power switch driver circuit By project: ε27 volume control pot mounting board By project: ζ1 audio widget asynchronous USB-I²S module By project: σ11 single-rail regulated power supply By project: σ22 dual-rail tracking regulated power supply By project: σ24 transformer mounting board By project: σ25 regulated power supply By project: χ1 Li-Po battery board for Mini³ By type: Circuit boards By type: Connectors, Jacks By type: Crystals, oscillators By type: Discrete semiconductors By type: Integrated circuits By type: Panel components By type: Passive components By type: Thermal management (Related projects: M³, γ1, γ2, γ3) Description Price (USD) Quantity Notes σ11 single-rail regulated power supply printed circuit board $12.00 each PSU for M³, γ3 and others Aavid-Thermalloy 529802B00000 1.5" extruded TO-220 heatsink (3.7°C/W) $2.00 each 4 needed per β22 board 4 needed per σ22 board 2 needed per σ11 board International Rectifier IRLZ24N power MOSFET (TO-220) $3.50 pair 1 pair needed per σ11 board 1 needed per ε24 board BC546B NPN 65V small signal transistor (TO-92) $0.20 each 6 needed per σ22 board 3 needed per σ11 board 3 needed per ε12 v2 board BC556B PNP 65V small signal transistor (TO-92) $0.20 each 6 needed per σ22 board 3 needed per σ11 board 2 needed per ε12 v2 board Semitec E-202 2.0mA current regulator diode (DO-35) $2.30 each 2 needed per σ11 board 2 needed per σ22 board Semitec E-562 5.6mA current regulator diode (DO-35) $2.30 each 1 needed per σ11 board 2 needed per σ22 board BZX55C12 12V 500mW low noise zener diode (DO-35) $0.25 each 8 needed per β22 board 8 needed per β24 board 1 needed per σ22 board (certain output voltages) 1 needed per σ11 board (certain output voltages) 1 needed per Mini³ board Wima MKS2 1µF 63V MKS film capacitor $0.90 each 2 needed per α20 board pair 7 needed per β22 board 6 needed per β24 board 4 needed per σ22 board 2 needed per σ11 board 13 needed per M³ board 1 needed per ε12 board 3 needed for γ1 full config 1 more for γ1 USB-to-S/PDIF converter or full++ config 2 needed per γ2 board Kemet/Evox-Rifa MMK 3900pF 63V MKT film capacitor $0.38 each 2 needed per σ22 board 1 needed per σ11 board Najbitnije su regulator diode naruciti preko AMB Audio shop-a jer ih necete nigde naci, a pored toga naravno i plocica. Napomena: dostava sa teritorije USA bez obzira na kolicinu i iznos je 30USD. Veci deo preostalih komponenata narucio sam iz Farnell-a: http://www.farnell.com/ Ovde obratiti paznju da se naruci ono sto je na stock-u iz EU i za sve takve dostava se naplacuje 5evra, dok se komponente iz stock-a iz USA to naplacuje 25USD. Inace, sve je preko Farnell-a profi, naruceno stiglo za 1.5dan i maksimalno profi upakovano i obelezeno. U mom slucaju, iz AMB-a sam zajednicki narucivao sa kolegom sa DIY foruma, moja kostala 30USD, dok smo postarinu od 30USD preraspodelili on 2/3 ja 1/3 zbog kolicine koju je on narucivao. Porudzbina iz Farnell-a placena 20evra. Za skutijavanje, videcemo. To prepustamo kolegi Leonardu profesionalcu. Kada leonardo zavrsi slede utisci i zapazanja.
Najlepse od svega je sto je sve iz prve proradilo bez bilo kakve greske i cinculiranja
Bice torus, vec kupljen. U svakom slucaju hvala za info. Za mrezni filter je rano, prvo cemo probati sve ovo. Koliko ce uticati izbor DC kablova od PSU do uredjaja?
Sad si se iskupio 10A je nesto drugo, nema veze sa ovom temom, oprosti... Sigma 11 single-rail PSU, obzirom da ima 4 DC OUT-a, meni ce napajati M2Tech vozic (Hi Face EVO, EVO Dac i EVO Clock)
Link bi mi bio od velike pomoci? Neki Kit mozda?
Ima li nesto vredno paznje od Single Output DC 12V/10A? Bio bih zaista zahvalan.
Niko zaista nije spominjao izum, nema potrebe da se ljutis, takodje niko nije osporavao ili tvrdio koja je plocica bolja ili gora.
Meni je svakako draze da kupim proizvod od nekoga ko je u to ulozio vreme na razvoj, testiranje i obezbedio punu podrsku. Ti Kan to sigurno zasluzuje. Najlepse od svega sto je plocica Sigma 11, po zavrsetku iz prve proradila bez ikakvih problema. Sam kvalitet izrade je od pocetka ulivao poverenje. Takodje sam se pri nabavci potrebnih komponenata drzao preporuka Ti Kana vezano za serije i preporuceni kvalitet ugradjenih delova. Sto se tice kradje, sve je vec dostupno i nemoze se nazvati kradjom sve dok se koristi za sopstvene potrebe, a prodavati komercijalno i pozivati se na originalno ime proizvoda - to je vec ocigledno.
BTW, dodaj.rs je zatvoren - pocinju da nestaju fotke?! evo ponovo: http://www.oldschool-samp.com/slike/?v=imag12tyt.jpg http://www.oldschool-samp.com/slike/images/dscn54czc.jpg
Ok slazem se, ionako sam to rekao intuitivno na osnovu letimicnog pogleda na oglas sa Ebay-a koji je kolega Zbotic okacio kao link - nekako mi se na prvu loptu ucinilo kao "bleda kopija". Stvarno nisam probao ni koristio ni jednu ni drugu. Nemam nameru napamet da tvrdim nesto. Zboticu, malo si editovao svoj post na koji sam reagovao, naknadno si dodao ovo sto sam boldovao. Tako da sam kasno saznao da si i licno poredio obe verzije. Meni tek predstoji privodjenje primeni i testiranje, pa da vidimo koliko ce zapravo boljitka doneti. Dotle mogu da prijavim sledece:
Blagodarim, ostavicu svakome da donese svoj zakljucak po tom pitanju.
Ako cemo posteno, nije to ni blizu Sigma 22 ni po izgledu ni po kvalitetu, jedino su se kinezi zapravo priblizili ceni, dakle cena niposto nije kikiriki. Ako Vas ne mrzi pogledajte malo na sajtu i napravite objektivno poredjenje cena. http://www.amb.org/audio/sigma22/_s22_assy.jpg https://img.alicdn.com/imgextra/i1/2529159729/TB2mEfPeXXXXXa4XXXXXXXXXXXX_!!2529159729.jpg
U ocekivanju EVO teme - evo kolegama koje interesuje jedna tema koja opisuje potragu, adresu, dokumentaciju, fotografije i nadam se konstruktivne diskusije do gotovog proizvoda jednog single-rail PSU koji je u svakom smislu sve ono sto jedno napajanje sa visokim performansama treba da predstavlja. U ovoj temi bavicemo se prvenstveno Sigma 11 single-rail PSU iz prve ruke, a mozemo napraviti osvrt ili ako neko ima licnih i prakticnih iskustava sa ostalim dostupnim projektima koji su kompletno predstavljeni na sajtu: AMB Laboratories http://www.amb.org/audio/ ... je podigao sajt gde se mozete informisati, upoznati, prouciti, dobiti potpuno slobodan pristup (Open Sours) kompletnoj dokumentaciji i uputstvima za izradu DIY projekata koji su osmisljeni, ostvareni i provereni u praksi uz punu tehnicku podrsku vlasnika sajta Ti Kana http://www.amb.org/ti/ i online prodavnicomhttps://www.amb.org/shop/ gde mozete naruciti najvaznije komponente, a za sve otvorene diskusije i razmenu informacija tu je i forumhttp://www.amb.org/forum/ kome mozete pristupiti i aktivno doprineti razvoju postojecih ili mozda novih projekata. Dakle, Sigma 11 single-rail PSU: http://www.amb.org/audio/sigma11/ U levom delu ove stranice postoji meni za navigaciju kroz kompletan projekat i dokumentaciju kaja Vam je potrebna, pa ako imate interesovanja pogledajte malo o cemu je rec, pa mozemo malo prodiskutovati. Pozdrav
I2s zadovoljavajuci sto se mene tice, takodje bih voleo firewire vezu.
Na prodaju po 2 kom: - 33000uF/63V cena 15 eura komad - 3300uF/63V 120din KOMAD Napominjem da su elektroliti novi i neformirani, nazalost greska u komunikaciji (racunao sam na dimenzije za 33000uf sa dva pina na vrhu, ispostavilo se da su te dimenzije bez - bez njih V 105, S 65 - sa V 112, S 65mm sto je u mom slucaju postalo neupotrebljivo, nazalost). Idem sa istom cenom kao i kolega Vajs 1986, a ko je iz Beograda ustedece na kurirskoj sluzbi. Trebace i broj telefona za kontakt - 065 44 250 22 Ukoliko je moguce, molba za moderaciju, da se broj ubaci u gornji post. Hvala. UbaČito. Nema na čemu.
^ I kakvi su utisci? Valja li cemu i u kojem se cenovnom rangu krece ovaj uredjaj?
Uff, dobro je, taman pomislio da su Woland i Zen blizanci p.s. sto ne znaci za svaki novi par zvucnika - nijedni ne lice na prethodne
Trenutno na sajtu 4 članova, 0 Skrivenih, 1795 Gosta (Pogledaj celu listu)
