Magura
Sve objavljeno od Magura
  1. That's a real nice amp you've made there. Magura
  2. Ok, I'll lok into this when I get back home, and send you a pair. Just left for Switzerland again. Magura
  3. Magura
    DIY gramofon - III
    Hmm, that place looks familiar
  4. Bad news. I have 8 and 10mm ceramic bearings, but nothing around 6mm. The second best solution then, is graphite loaded PTFE. This however is super easy to make bearings of, as you can cold set them with a minimum of force. Magura
  5. I'm Switzerland right now, but will be back home next week. I'll look and see what I can find for you then. 6mm sounds like something I may have in stock. Magura
  6. That sounds like a good starting point. What's the diameter of your axle? I may have a couple of ceramic bearings for you. Magura
  7. I sure have suggestions The wider the bearing, the less edge load it will see, thus the lower load per mm2. Depending what your current bearing and rod is made of, I can offer you a suggestion. My initial suggestion (again this depends of your current axle material) would be ceramic, PTFE/graphite, if your axle is ground steel. Magura
  8. That indeed depends how it's done. Which materials have you used for the bearing interface? Magura
  9. This looks like a great idea. Very simple to make. The linear bearing looks a tad narrow to me though. Magura
  10. Unfortunately I'm drowning in work, and partly living in a suitcase on top of that, or rather due to that, so no Burning Amp for me this year. Dropping by sometime in the spring looks more likely. Depending how the next product industrialisation goes. Magura
  11. Magura
    Gde kupiti Arduino?
    www.hobbyking.com has a nice selection at the right price. Magura
  12. Hmm, so now SS with transformers didn't do it for you anymore? Lokking forward to hear this toy though. Магура
  13. Lack of Choky's plum brandy
    1. stein
      stein
      Jeez, where have you been?
    2. Magura
      Magura
      Lost in work for the last year or so :-(
      Spending like half of my time in Switzerland.
  14. Congratulations on your 2nd. place :D
    1. Zvu
    2. Zen Mod
      Zen Mod
      congrats on your 1st place ;)
    3. Magura
      Magura
      Hey, it wasn't me wasting time, running around to catch a ball, just to throw it away shortly after ;-)
  15. Merry Christmas, for those of you whom believe in the right god :-D
    1. Zen Mod
      Zen Mod
      every Holiday is good ... doesn't matter from which God :rofl:
    2. stein
      stein
      I don't, but thanks anyway :)
      Greetings to Metaldanske couple!
    3. zerowaf
      zerowaf
      Thanks! There is only one....we just call him/her/it by diff names and imagine diff apearings... :)
  16. See that's what I hope will change in the 2012 season. They have the money and the people.Magura
  17. True, but they sure are entertaining.I'd just wish that Shumacher would mix with them in the top. That could be quite a season, rebellion blood against calculated experience.Магура
  18. .......ok, this is a case of fighting my lack of reading Serbian for a while.Магура
  19. Hey, I'm entitled to make stupid moves as well Магура
  20. Things just might turn very interesting. As I understand it, there will be at least 3 possible winners, which is a lot better than the last couple of years.Магура
  21. I think so I just upped my working hours to like 15 a week, and it seems to take a lot of effort that "work" stuff :DHow about you? Everything as usual?Magura
  22. Time for an update:Last week one Donut went south. The CCS poured 10A through.The culprit turned out to be the JFET in the CCS, and it had boiled a capacitor as well, most likely due to the heat generated by the source resistors of the Lu1014 pair.After some half an hour of chatting up The fluffiest Serbian, the amp was back in good shape.The funny part is that nothing died, even though it was running for an evening with a 10A bias.Overkill anyone? :DMagura
  23. Magura
    at Manu's
    You had the momentum of surprise.......... Don't count on it happening again. Magura / currently listening to some respectable rock, dreaming of the one and only
    449.7k
    markot
    markot
