shonne
Sve objavljeno od shonne
  1. Mozda nema neku veliku ocenu, ali je dobar 🤗 Der denkwürdige Fall des Mr Poe (2022) - IMDb M.IMDB.COM Der denkwürdige Fall des Mr Poe: Directed by Scott Cooper. With Christian Bale, Harry Melling, Simon McBurney, Timothy Spall. A world-weary detective is hired to investigate the murder of a West Point cadet. Stymied by the cadets' code of...
  2. Samo 950...pfff 😂
  3. Dobar... As bestas (2022) - IMDb M.IMDB.COM As bestas: Directed by Rodrigo Sorogoyen. With Marina Foïs, Denis Ménochet, Luis Zahera, Diego Anido. A middle-aged French couple moves to a local village, seeking closeness with nature where their presence inflames two locals to the point of...
  4. Wire sam odgledao, zato i cekao da mi se steknu uslovi da skinem ovo... @Zen Mod, pratis li 1923, vredi li nesto?
  5. Napokon nasao u ducanu od 45gb i sa dobrim netom... da se ovo pogleda
  6. Predvidjam vam sudbinu. I Zeljko Mitrovic se na kraju prebacio da pravi dronove 😁😛
  7. nemojte da dodjete u situaciju da vam taj vas DAC na kraju ne poleti u vazduh 😁😛
  8. Uhh, ova serija je bas... The White Lotus (TV Series 2021–2023) - IMDb M.IMDB.COM The White Lotus: Created by Mike White. With Jennifer Coolidge, Jon Gries, F. Murray Abraham, Adam DiMarco. Set in a tropical resort, it follows the exploits of various guests and employees over the span of a week.
  9. sad se odluci, da li ti vise znace dobavljivi delovi ili obsolete
  10. shonne
    JC-80, UGS
    In general use 5-6V more DC input than output for good performance, the 20k trimmer is alright for 32V range also. When you first test make sure the dummy load resistors don't consume more than the current limit you decided. Else it will not reach target output in test. Example, if your final real load will be 32V/100mA don't test with less than 390R dummy i.e. 82mA. CCS target setting is 0.58V/R1=mA or R1=0.58V/mA i.e. when you want 150mA R1=0.58V/0.15A=3.866 (3.9R)
  11. moze tu i da se stavi druga konfig za vece struje, pa da se biraju opampovi koji vuku znatno vise mA
  12. UGS Muse Salas shunt regulators.pdf
  13. Ako mislimo na isti reg, kako su ljudi odradili taj psu, sa kojim delovima...
  14. To ili Classic dok je bilo. Uh, memories 🤗
  15. ukinuo netflix 2 i 3 sezonu. Mozda se bude pojavilo na nekim drugim platformama, za sad je tako. @Doktor, sta se prati ovih dana?
  16. opaaa... ipak ce budne malo merenja
  17. Cekam taj satic u avatar da promenis pa opet da se uplasim 😁😛
  18. Pitaj @NIXIE, svo ovo ludilo je pocelo od kad se on pojavio na forum. Do tad smo bili normalni🤔 😁😛
  19. shonne
    Sa 4 na 8 Oma
    Beta je deklarisana na 170W/8 i mnogo vise u /4 ohma. Sa lakocom gura impedansu od 3ohma...bice da je probana i na wilsonima ispod 3ohma. Ne zaboravite, Beta ima jedan par izlaznih 😁 Aleph je vrlo prosto pojacalo sa 4 tranzistora, deklarisano je i za 2ohma, a greje se uvek u A klasi. 🤔 To sto ovaj amp ima dva para i ako se se malo pogura na 4ohma, pa sta. To i nije pojacalo ako crkne na 4ohma. Ako se vec traze kutije od cistih 8ohma, pa gde to ima bez skretnice? To su zvuje od 16ohma, koji sa skretnicom i kutijom dolaze na nominalnih 8ohma. A u tom slucaju se ne ide na ovo pojacalo vec se tad radi lampas za uzivanje 🤗
  20. shonne
    Sa 4 na 8 Oma
    Uskoro se Mika, razvodi...koliko ja vidim 😁😛
  21. shonne
    Sa 4 na 8 Oma
    Hahaha, ovo me slatko nasmeja. Mika, u svom elementu 🤗😁
  22. osciloskop
  23. Koji je zadnji koncert u Srbiju bio, od velikih grupa na otvorenom? Da zanemarimo, klubove i zatvorena mesta. Koje god i ko?
  • Trenutno na sajtu   3 članova, 0 Skrivenih, 150 Gosta (Pogledaj celu listu)
    453.5k
