shonne
Sve objavljeno od shonne
  1. bravo, bravo, bravo Woland...samo napred. Ce vidis koliko je ovaj hobi zapravo lep
  2. shonne
    Ampohm PIO 8uf
    Prodajem 2 komada Ampohm PIO 8uf... http://www.humblehomemadehifi.com/Cap.html Amp Ohm PF-XAL-AL 630VDC Paper in Oil aluminium foil - 10% tolerance Technical Specifications (according to manufacturer): "Amp Ohm paper in oil (PIO) capacitors are hand wound using high aluminum foil. They are oil impregnated before being assembled and oil filled. The capacitors are then hermetically sealed in an aluminum housing with phenolic resin and rubber end discs. Each lead is hand solder sealed to the eyelets in the end discs. The leads are 1.0mm in diameter and made of tinned copper. All Amp Ohm Audio Capacitors are individually hand tested. Line on label denotes outer foil." Sound: The Amp Ohm PF-XAL-AL 630VDC is basically the same type as the above mentioned capacitor but with a higher voltage rating. The higher rating is obtained using thicker materials and therefore the 630VDC version (65mm) has a larger diameter than the 300VDC version (45mm). Both have the same length (95mm). The 630VDC version reminds me of a can of beer or coke. The higher VDC type is also very rich in harmonic textures and quite spatious. The tonal balance is very neutral and seems a fraction smoother than the lower VDC type. Imaging depth is very good but like the 300VDC version, not quite at the same level as their paper-in-wax or polyester-in-oil stable mates. My review notes also state: black background. Verdict: 11- Cena, 120 eur PP ili 0658031133 Slike, kad stignem...mrzi me od rano jutro
  3. sve ovo vreme sam izbegavao projekte sa SMD, sve do sad dok me nije privuko jedan. Planiram da uzmem jednu lemilicu sa duvaljkom, pa me interesuje kakva su iskustva sa budget markama tipa Baku i slicno?
  4. http://www.imdb.com/title/tt5491994/ Planet earth 2...odlicno je.
  5. Jaooo...dvv, molim te...nemoj ti da mu pomazes. Osudjeno je to na... Sent from my LG-E460 using Tapatalk
  6. Mislim da ne. Ovo je sa SS 8545 i 9500,...9700 To sto ti mislis mislim da su one male Tizo...one su micro. Ne, monitori Bas cu da pogledam cene kad se vratim kuci...imam neki pdf. Sent from my LG-E460 using Tapatalk
  7. Za koliko je Dayens prodavao svojevremeno njegove Studio Monitor-e... Ovo bi trebalo da je bolje. Zato mislim da je cena na mestu Sent from my LG-E460 using Tapatalk
  8. Alex me slatko nasmeja Car... Inace, ne idem mnogo na ta slusanja, ali bih ovo bas voleo da cujem, samo da sam malo blize. Kada bude bilo, neki utisci...
  9. from Serbia...
  10. shonne
    Boenicke W5 SE
    ko vam kriv kad pravite male stvari
  11. shonne
    Boenicke W5 SE
    nisu bas toliko male...nego je moje pojacalo bas veliko
  12. shonne
    Boenicke W5 SE
    koliko se Alex-u sa slika cinilo da je moje pojacalo malo toliko se meni ucinilo da su ove kutije veceg gabarita Elem, male kutije koje daju odlican zvuk,...odlican.
  13. shonne
    Boenicke W5 SE
  14. Nikako da zavrsim Mr Robot zadnju sezonu. Mucio se od pocetka i ostale zadnje 4 epizode i nikako mi ne ide...Razocarenje.
  15. Neskor valjda... Koliko znam novi vlasnik je srecan sa njima u njegovom setup-u... Zvuk i nas hobi je bas relativna stvar...
  16. Merenja su za sisice Salu na stranu. Jesam zamenio vufer sa 22W/8851, promenio litrazu, otvor za bass reflex.....i visoke koje sam imao sa 9500, sa modifikovanom skretnicom za visoke. Isto po Troels-ovoj filozofiji, jer je taj visoki malo vise osetljiv u odnosu na 9900. Ako pricamo o zvuku ja zadovoljan sa basom i visokim dok sa mid jos nisam...iako je po originalu 8531...hebu me 110uf, ne daju mi se pare za bolje. Transparentan do bola, cistina kad zamenim Icar kondove. Ako se prica o zvuku, ja vec nekog cekam duze vreme. Za sad su bila samo dva hifi-ca...jedan koji se krece u krugu ljudi koji sve mere patkometrijom i drugi koji kaze da je dobro. Ne treba mi vise, osim sto me i dalje hebu onih 110uf Pogledajte koliko je ljudi pravilo Troelsove projekte...citajte malo. Zar su svi oni fini pa nece da kazu da je nesto lose. Hm.
