47005 -
661
Sve objavljeno od Mikorist
http://www.youtube.com/watch?v=3SXPvOOlZvs
trazite na youtube "3D Binaural Audio"problem je sto ce muzicari morati da se pomeraju dok sviraju da bi efekat bio bolji.najbolje da im ugrade tockice u stolice
ovo nije normalno koliko je realno - zvuk ide - "oko glave" - "iza - napred" - "gore - dole" - levo i desno slusalice na glavu pa proverite sami:
jeste...... napravis zid do mesta gde sedis izmedju zvucnika. :doh:doduse....posle ovoga nemas vise ni zenu - pa je zvuk jos i bolji
Mikorist je odgovorio/la BANAT's temus u Muzika , Film i Fotografija
http://www.youtube.com/watch?v=JRW9lGOBnuIhttp://www.youtube.com/watch?v=oJy4FJXUDD0 -
ZAŠTO !!!! su dobri mini(ili ti nearfield) monitori toliko skupi ?
Mikorist je odgovorio/la chakija's temus u Hi-Fi audio
da se razumemo ni ovaj mali JBL uopste nije los - ko ima pojacalo...(imam ih licno)i jos moze skoro na nemoguca mesta da se postavi na zid... :sarcastic_hand:jedno 6 komada u sobu i to je to..... full Surround -
By default in Windows Vista, the format command writes zeros to the whole disk when a full format is performed.tako kazu na microsoft.com.... ako lazu onda
preko MBRako je u pitanju Boot sektor virus fdisk /mbr je obicno resavao taj problem . pre formata. http://support.microsoft.com/kb/122221 no postoje ogranicenja za ovu komandu. ranije sam obicno koristiohttp://www.ranish.com/part/ ima zero-filling opciju u sebi.
Low-level formatting neadekvatno (kao izraz) koristi mnogo ljudi "While it is generally impossible to perform a complete LLF on most modern hard drives (since the mid-1990s) outside the factory[11], the term "low-level format" is still used for what could be called the reinitialization of a hard drive to its factory configuration (and even these terms may be misunderstood). Reinitialization should include identifying (and sparing out if possible) any sectors which cannot be written to and read back from the drive, correctly. The term has, however, been used by some to refer to only a portion of that process, in which every sector of the drive is written to; usually by writing a zero byte to every addressable location on the disk, sometimes called zero-filling." http://en.wikipedia.org/wiki/Disk_formatting Format komanda pod Windows-om 98/2K/XP NIKADA ne radi zero-filling. Format komand pod Vistom i 7 uvek PRE formatiranja - osim ako se koristitI /Q prekidac dakle zero-filling je jedini nacin da se hard disk vrati u "fabricko stanje" potrebno je 30-40 puta odradiditi full zero-filling da niko ziv ne bi mogao vise da procita magnetne slojeve i podatke sa Hard diska. i zato je LLF jako teska operacija prakticno i nemoguc u jednom cugu... evo nekih stvari na tu temu: -------------------------------------------------------------------------------------------------------------------- There are "de-magnetisers" machines (degausser) that are used for disabling drives that have contained top-secret data, and these cost a bundle. However, only using software, you can only have the drive read or write data. The drive heads cannot just "scatter magnetic charges"... how would a head that is designed to read and write individual bits (in block), ie precisely, be able to do that?. Besides, if it were the case, the drive would either need a low level format after that or be filled with bad clusters, ie: be just plain dead. Here's an extract of DoD 5220.22-M shredding guidlines: http://www.killdisk.com/dod.htm chapter8 a. Degauss with a Type I degausser b. Degauss with a Type II degausser. c. Overwrite all addressable locations with a single character. d. Overwrite all addressable locations with a character, its complement, then a random character and verify. THIS METHOD IS NOT APPROVED FOR SANITIZING MEDIA THAT CONTAINS TOP SECRET INFORMATION. Also, a comparaison of software "shredders" can be found here: http://www.sdean12.org/Comparison_Shredders.htm (Check the "Overwrite algorithm" row for wiping technique) -------------------------------------------------------------------------------------------------------------------- Well, no, IT IS possible: Overwriting data on disk isn't like filling a closet, it's like writing over used paper... What happens is that when the disk heads write on the platter, it re-aligns magnetite (or whatever magnetic compound they use) in a diffrent direction. However, a single write doesn't manage to get all magnetite (or whatever) particuls re-alligned. So while the majority of particuls will have change directions, there will be a few residual ones that will still be oriented in the previous direction. So finding out what data was there before means using a more sensible device that can distinguish or detect variations in the magnetic field or such... (That's why whiping software will make multiple writing passes, sometimes with randomized caracter, in order to try and re-allign all particuls). Of course this is hard to do and pretty expensive, but people with enough money and resources (think FBI, CIA, NSA...) could and do have the means to do it. In fact, I remember reading somewhere that it was rumored the NSA (I think) was able to recover data after 27 passes! -------------------------------------------------------------------------------------------------------------------- When data is written to magnetic media it is written to a magnetic domain. This domain consists of a number of magnetic bits (not to be confused with a data bit 0 or 1) which receive the magnetic charge. Not all of the bits in the magnetic domain will change when the head passes over during the write operation and will retain the magnetic properties from a previous operation. Does this mean that a magnetic domain can contain magnetic bits that are set to a zero and magnetic bits that are set to a one? It certainly does, but if the write operation was setting the bit to a one then the majority are set to a one, strongest at the center of the domain weaker at the edges. Remember in grade school when you put metal filings on a piece of paper and ran a magnet underneath. Most of the filings lined up and pointed in the same direction, but the ones at the edges didn't all point with the others. The same thing is happening when you write to the hard disk. Is it easy to peel back these layers to determine what was overwritten? With modern hard disks this is a difficult, costly, and time consuming process but portions of overwritten data can be recovered if it was overwritten or wiped with a single pass process. The minimum process that should be involved in a wipe would be a three pass write. A three pass will make one pass writing 00 followed by it's complement which is an FF and a final pass of random data. It is still possible to recover some data after a 3 pass wipe, but whoever does will want that data very badly and have the $$ to attempt the recovery. Generally a 7 pass wipe will make it near impossible to recover the data and I have never heard of any data being recovered after a Guttman 35 pass wipe. (Disclaimer.. Doesn't mean that those agencies with 3 letter names can't do it but they would really want you bad to go to the expense involved) -------------------------------------------------------------------------------------------------------------------- DBAN: Darik's Boot and Nuke: (free tool) Darik's Boot and Nuke ("DBAN") is a self-contained boot floppy that securely wipes the hard disks of most computers. DBAN will automatically and completely delete the contents of any hard disk that it can detect, which makes it an appropriate utility for bulk or emergency data destruction. DBAN is a means of ensuring due diligence in computer recycling, a way of preventing identity theft if you want to sell a computer, and a good way to totally clean a Microsoft Windows installation of viruses and spyware. DBAN prevents or thoroughly hinders all known techniques of hard disk forensic analysis. http://sourceforge.net/projects/dban/ Eraser: (free) Eraser is an advanced security tool (for Windows), which allows you to completely remove sensitive data from your hard drive by overwriting it several times with carefully selected patterns. Works with Windows 95, 98, ME, NT, 2000, XP, Windows 2003 Server and DOS. Eraser is Free software and its source code is released under GNU General Public License. The patterns used for overwriting are based on Peter Gutmann's paper "Secure Deletion of Data from Magnetic and Solid-State Memory" and they are selected to effectively remove magnetic remnants from the hard drive. Other methods include the one defined in the National Industrial Security Program Operating Manual of the US Department of Defence and overwriting with pseudorandom data. You can also define your own overwriting method http://www.heidi.ie/eraser/download.php u sustini ko zeli da popuno brzo unisti dokaze i podatke sa hard diska mora da ga cibne u visoku pec: toliko o efikasnosti obicne komande FORMAT C:
ubijanje nulama znaci upravo to (fill with zeros)podaci na hard disku se sastoje od 0101010100101010101010101 prosto receno posle nulovanja imas samo 000000000000000000000na hard disku odnosno nema ni virusa. nova FORMAT komanda ima ugradjeno to u sebi. (napredovala je)ranije morao sam da koristim najmanje dva programa da bih odradio ovu operacijui bio 100 % siguran da sam ocistio HDD.
i za kraj Union Jack svezijehttp://www.youtube.com/watch?v=tCZ3JyngVNsPlatipus Records 2009 -
i jos zescehttp://www.youtube.com/watch?v=xW1638jkPaA http://www.youtube.com/watch?v=kjw0uzAdyJk -
:clap: Killer track. -
a sad...only to BANAT - jedan set acid trance-a -
Ko ne zna da zna kad i ako se zarazite pod sedmicom teskom zarazom.Obican FORMAT ubija uvek nulama hard disk pre obicnog formata osim ako se koristi /q opcijaNa win 2K/XP nije bio taj slucajReferenceSTARO:http://support.microsoft.com/kb/302686/en-usNOVO:http://support.microsoft.com/kb/941961/en-us
Crnogorsko tochenje -
odlicni su - za te pare i namenu :my2cents:http://www.mitrosmusic.com/proizvod/1292-Behringer-MS16-MONITOR-SPEAKERS-CENA-ZA-PAR/ -
klon projekt je ovdehttp://home.comcast.net/~klone-audio/page15WhisperProj1.html auuuu brate minli tek sad vidim kakav je ovo zvucnik
Legacy Whisper ne znam kako svira ali izgleda jezivo dobro
Teti Extreme speakers.
utikac za samoubice -
Trenutno na sajtu 3 članova, 1 Skrivenih, 28 Gosta (Pogledaj celu listu)
Ukupan broj tema452.7k
