46946 -
653
Sve objavljeno od Mikorist
@asimze Probaj ovu zadnju verziju - znači sve iznova install Pa javi Zaboravio sam da enablujem sudo systemctl enable rtirq.service Da vidiš šećera sad Ne znam ni kako da nazovem to. Lepilo neko za ušesa.
Neće na par meseci. Obrišem fajl pa upload. Xubuntu Core je srce sistema. Pa jedno 30 tvikova. Uglavnom je gore opisano. I ovde po temama. Jedino je trebalo neko da sedne i uradi. A config fajlove imaš u distribuciji pa ako te ne mrzi možeš ti da okačiš kod sebe na github. Mogu i ja ovde u temi. 99-cpu-dma-latency.rules DEVPATH=="/devices/virtual/misc/cpu_dma_latency", OWNER="root", GROUP="audio", MODE="0660" sudo cp 99-cpu-dma-latency.rules /etc/udev/rules.d/ sudo udevadm control --reload-rules sudo udevadm trigger udevadm info -a -n /dev/cpu_dma_latency audio.conf @audio - rtprio 99 @audio - nice -15 @audio - memlock unlimited @audio - nofile 8192 sudo cp audio.conf /etc/security/limits.d/ 95-pipewire.conf @pipewire - rtprio 95 @pipewire - nice -19 @pipewire - memlock 4194304 sudo cp 95-pipewire.conf i /etc/security/limits.d/ RTiRQ wget http://ports.ubuntu.com/pool/universe/r/rtirq/rtirq-init_20150216-2.1_all.deb sudo dpkg -i rtirq-init_20150216-2.1_all.deb rtirq.conf RTIRQ_NAME_LIST="snd usb i8042" # Highest priority. RTIRQ_PRIO_HIGH=90 # Priority decrease step. RTIRQ_PRIO_DECR=5 # Lowest priority. RTIRQ_PRIO_LOW=51 # Whether to reset all IRQ threads to SCHED_OTHER. RTIRQ_RESET_ALL=0 # On kernel configurations that support it, # which services should be NOT threaded # (space separated list). RTIRQ_NON_THREADED="rtc snd" sudo systemctl enable rtirq.service RTkit /lib/systemd/system/rtkit-daemon.service [Unit] Description=RealtimeKit Scheduling Policy Service [Service] EnvironmentFile=/etc/dbus-1/system.d/rtkit ExecStart=/usr/libexec/rtkit-daemon $RTKIT_ARGS Type=dbus BusName=org.freedesktop.RealtimeKit1 NotifyAccess=main CapabilityBoundingSet=CAP_SYS_NICE CAP_DAC_READ_SEARCH CAP_SYS_CHROOT CAP_SETGID CAP_SETUID PrivateNetwork=yes [Install] WantedBy=graphical.target /etc/dbus-1/system.d/rtkit RTKIT_ARGS="--scheduling-policy=FIFO --our-realtime-priority=89 --max-realtime-priority=88 --min-nice-level=-19 --rttime-usec-max=2000000 --users-max=100 --processes-per-user-max=1000 --threads-per-user-max=10000 --actions-burst-sec=10 --actions-per-burst-max=1000 --canary-cheep-msec=30000 --canary-watchdog-msec=60000 sudo systemctl enable rtkit-daemon.service skrinsejveri xset -dpms xset s off setterm -powersave off -blank 0 /etc/sysctl.conf # # /etc/sysctl.conf - Configuration file for setting system variables # See /etc/sysctl.d/ for additional system variables. # See sysctl.conf (5) for information. # #kernel.domainname = example.com # Uncomment the following to stop low-level messages on console #kernel.printk = 3 4 1 3 ################################################################### # Functions previously found in netbase # # Uncomment the next two lines to enable Spoof protection (reverse-path filter) # Turn on Source Address Verification in all interfaces to # prevent some spoofing attacks #net.ipv4.conf.default.rp_filter=1 net.ipv4.conf.all.rp_filter=1 # Uncomment the next line to enable TCP/IP SYN cookies # See http://lwn.net/Articles/277146/ # Note: This may impact IPv6 TCP sessions too net.ipv4.tcp_syncookies=1 # Uncomment the next line to enable packet forwarding for IPv4 net.ipv4.ip_forward=1 # Uncomment the next line to enable packet forwarding for IPv6 # Enabling this option disables Stateless Address Autoconfiguration # based on Router Advertisements for this host net.ipv6.conf.all.forwarding=1 ################################################################### # Additional settings - these settings can improve the network # security of the host and prevent against some network attacks # including spoofing attacks and man in the middle attacks through # redirection. Some network environments, however, require that these # settings are disabled so review and enable them as needed. # # Do not accept ICMP redirects (prevent MITM attacks) net.ipv4.conf.all.accept_redirects = 0 net.ipv6.conf.all.accept_redirects = 0 # _or_ # Accept ICMP redirects only for gateways listed in our default # gateway list (enabled by default) net.ipv4.conf.all.secure_redirects = 1 # # Do not send ICMP redirects (we are not a router) net.ipv4.conf.all.send_redirects = 0 # # Do not accept IP source route packets (we are not a router) net.ipv4.conf.all.accept_source_route = 0 net.ipv6.conf.all.accept_source_route = 0 # # Log Martian Packets net.ipv4.conf.all.log_martians = 1 # # # Enable a fix for RFC1337 - time-wait assassination hazards in TCP net.ipv4.tcp_rfc1337 = 1 # Use BBR TCP congestion control and set tcp_notsent_lowat to 16384 to ensure HTTP/2 prioritization works optimally # Do a 'modprobe tcp_bbr' first (kernel > 4.9) # Fall-back to htcp if bbr is unavailable (older kernels) net.ipv4.tcp_fastopen = 3 net.core.default_qdisc=fq net.ipv4.tcp_congestion_control = htcp net.ipv4.tcp_congestion_control = bbr net.ipv4.tcp_notsent_lowat = 16384 # Turn on the tcp_window_scaling net.ipv4.tcp_window_scaling = 1 # # net.core.wmem_max = 16777216 net.core.wmem_default = 131072 net.core.rmem_max = 16777216 net.core.rmem_default = 131072 net.ipv4.tcp_rmem = 4096 131072 16777216 net.ipv4.tcp_wmem = 4096 131072 16777216 net.ipv4.tcp_mem = 4096 131072 16777216 net.core.netdev_max_backlog = 30000 net.ipv4.ipfrag_high_threshold = 8388608 net.ipv4.tcp_slow_start_after_idle=0 ################################################################### # Improve writing to external media like USB memory sticks vm.dirty_bytes=335544320 vm.dirty_background_bytes=167772160 # Audio Magic vm.swappiness = 10 vm.vfs_cache_pressure=50 vm.dirty_writeback_centisecs = 1500 fs.inotify.max_user_watches = 524288 fs.inotify.max_queued_events = 65536 ################################################################### # Magic system request Key # 0=disable, 1=enable all, >1 bitmask of sysrq functions # See https://www.kernel.org/doc/html/latest/admin-guide/sysrq.html # for what other values do #kernel.sysrq=438 itd...itd....do sutra ....
Ja reko za opijate
Ma jok...Ovaj je sve spucao u sobu i zvučnike. Spolja normalna kuća i garaža - džip neki - nije Blejk Karington Ima negde u zadnjem delu. Oko 20 godina mu je trebalo da napravi sve ovo zajedno sa prostom za slušanje. Sve sam.
Koga mrzi može i sam da dodaje. Na postojuću instalciju ručno. U svakom slučaju ću barem jednom u dva meseca da kačim sa ažuriranim apdejtovima. Između ako se pojavi neki novi tvik ili neko dobro podešavanje.
Ako ima još nešto korisno da se setite ili neka tajna - ubacite ovde slobodno. Ja ču da gledam da apdejtujem što češće ovo. Skoro sve tvikove i ubrzanja koja postoje sam primenio ovde. Ne samo vezano za audio. Nego i za networking....striming. Pošto je i to sastavni deo kolevke. Neki od linkova koje mogu da se setim UbuntuTweaks/Performance.md at 20.04 · salihmarangoz/UbuntuTweaks GITHUB.COM Ubuntu tweaks for speeding up the PC, fixing problems and installing nice utilities/tools - UbuntuTweaks/Performance.md at 20.04 · salihmarangoz/UbuntuTweaks Easy Linux Tips Project: 40 Tips and Tweaks for Linux Mint - PART ONE EASYLINUXTIPSPROJECT.BLOGSPOT.COM Easy tips, tweaks and tricks for Linux Mint and Ubuntu, both for beginners and for advanced users. Complete starter's guide with simple how-to's. Ali to nije sve. Mnogo ima toga još..... Naravno ovo ne može sve na gomilu da se stavi pa da se kaže to je to. Mora da bude odabir šta i kako može da ne dođe do konfikta ili još nečeg goreg.
190GB je SSD verovatno -
Generalno govoreći to ti je zvuk koji imaš na DAC. Bez bojenja sistema. Bez farbanja i češanja ušiju kako se kome sviđa u Redmondu u Microsoft ili u Apple. Reprodukcija nije ništa drugo nego algoritam za transfer. Nema Graal-a random postupkom sklapanja PC. Minimizacija i optimizacija svih delova OS će ti dati zvuk kakav nisi verovao da moze i da izađe iz DAC - nirvana za malo para. A sad...ko još ima i jako dobro sklopljen računar (namenski za audio) još bolje.
To zavisi od tebe. Prilikom instalacije može se zadati da /home/ bude recimo drugi SSD/HDD od 1T. I onda trpaš muziku u Music , video u Video...itd.... A može i ručno da mu se zada kroz /etc/fstab - da u / imaš direktorijum PODACI I onda odatle da vučeš Muziku i vIdeo. Veoma je jednostavno ručno. Drugi disk formatiraš u Gparted kao ext4 Izlistaš sa blkid koji ima UUID sudo nano /etc/fstab UUID=ovde-ide-UUID /PODACI ext4 noatime,errors=remount-ro 0 2 ispod postojeceg / ext4 Posle se podesi i da iz LMS/squeezebox vuce odatle Muziku....
taj /run/user/1000/doc. nisam uspeo da resim. cak i na sajtu ove aplikacije stoji X za to. IRQS ne rade na Live USB jer u GRUB Live USB nema opcija postavljena za to.
Negde si preskočio neku stavku iz prvoga posta. Najćešće je da nema GRUB uopšte - ili nije startovano kao UEFI iz BIOS. ovo ovde...ne sme da se formatira. ako si preskočio Gparted - neće da radi. I treba nam informacija koja je mašina i procesor.
Vix-ov skromno sirotinjski fi-fi sistem tj. Zavrzlame...
Mikorist je odgovorio/la Vix's temus u Galerija sistema
Put do pakla popločan je nepotrebnim idejama -
Odgovor je u prvom postu. Svaka instalacija sve od nule i stavka po stavka isto. Za drugačije ne garantujem kako če da radi.
Mikorist je odgovorio/la BANAT's temus u Muzika , Film i Fotografija
Hvala svima na ovome. @zika @Kuja @Srecko @silentbob Ne bih uspeo sàm. Dugi neka kažu kako se čuje kod njih.
apdejtovano. diya@diya:~$ systemd-analyze blame 1.891s NetworkManager-wait-online.service 1.411s e2scrub_reap.service 1.159s systemd-journal-flush.service 846ms dev-sda3.device 758ms lightdm.service 757ms boot-efi.mount 717ms mpd.service 528ms accounts-daemon.service 528ms avahi-daemon.service 464ms loadcpufreq.service 448ms grub-common.service 444ms alsa-restore.service 440ms lvm2-lvmpolld.service 436ms boost.service 436ms apport.service 425ms dbus.service 366ms lm-sensors.service 365ms gpu-manager.service 291ms systemd-random-seed.service 189ms preload.service 187ms systemd-tmpfiles-setup-dev.service Diže se sad za nepune 2 sekunde.
Trenutno na sajtu 5 članova, 0 Skrivenih, 181 Gosta (Pogledaj celu listu)
Ukupan broj tema452.1k
