skrstic Napisano Mart 13, 2016 Share #23 Napisano Mart 13, 2016 Ja ladno zaboravio link[emoji2] https://www.msi.com/Motherboard/H61M-P20-G3.html#hero-overview Sent from my GT-I9305 using Tapatalk Connectors Back panel PS/2 mouse port PS/2 keyboard port dVi-d port* VGA port* 6 uSB 2.0 ports LAN jack 3 flexible audio jacks** *(the dVi-d & VGA ports only work with integrated Graphics Processor.) **(to reach the 8-channel sound effect, the 7th and 8th channels must be outputted from front panel.) on-Board Connectors 2 uSB 2.0 connectors Front Panel Audio connector Parallel Port connector (optional) Serial Port connector (optional) tPM connector (optional) Chassis intrusion connector Ovo je sve što ima. Na žalost nema mogućnost koaksialca ako ne kupiš zvučnu koja na sebi ima koaksijalni izlaz. Link to comment Podeli na ovim sajtovima More sharing options...
Spachek Napisano Mart 13, 2016 Share #24 Napisano Mart 13, 2016 Sta ima od tih jeftinih zvucnih sa coax-om? Sent from my GT-I9305 using Tapatalk Link to comment Podeli na ovim sajtovima More sharing options...
mrcelavi Napisano Mart 13, 2016 Share #25 Napisano Mart 13, 2016 Šta ima je široka tema, starije ( jeftinije) prevaziđene a novije skupe tako da se više isplati možda promeniti ploču, ipak stvar izbora, nego trujemo čoveku temu. Link to comment Podeli na ovim sajtovima More sharing options...
Spachek Napisano Mart 13, 2016 Share #26 Napisano Mart 13, 2016 Ok, sa moje strane stop Sent from my GT-I9305 using Tapatalk Link to comment Podeli na ovim sajtovima More sharing options...
skrstic Napisano Mart 13, 2016 Share #27 Napisano Mart 13, 2016 Mora i Groznog da razočaram. Nema ni njegova. J... mora na USB da idete. Rear Panel 1 x PS/2 green color for mouse 1 x PS/2 purple color for keyboard 6 x USB 2.0 Ports 1 x RJ-45 LAN 1 x VGA Port 1 x DVI-D Port 1 x Audio I/O 1 x Serial Port 1 x Parallel Port Internal 1 x 4-pin ATX 12V Power connector 1 x 24-pin ATX Power connector 1 x 4-pin CPU Fan connector 1 x 3-pin Chassis System Fan connectors 1 x Header (Headphone/Mic) 1 x Front panel connector 1 x USB 2.0 header 1 x Clear CMOS jumper 1 x Battery socket (3V) Link to comment Podeli na ovim sajtovima More sharing options...
Spachek Napisano Mart 13, 2016 Share #28 Napisano Mart 13, 2016 Ja vec jesam na usb-u, nego me kopka da probam coax Sent from my GT-I9305 using Tapatalk Link to comment Podeli na ovim sajtovima More sharing options...
grozni Napisano Mart 13, 2016 Autor Share #29 Napisano Mart 13, 2016 Ok, idemo na amanero il jl Link to comment Podeli na ovim sajtovima More sharing options...
prophet Napisano Mart 13, 2016 Share #30 Napisano Mart 13, 2016 Zavisi i kolika je veličina slotova nazad. Ako je onaj manji format onda u principu ili HiFace ili digitalni deo ove kartice: http://www.hi-files.com/forum/index.php?/topic/29485-esi-julia/#comment-606402 U svakom slučaju bolje od Amanero-a, a od SPDIF sa matične da ne govorim (ukoliko ga uopšte uspeš uloviti). Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Mart 13, 2016 Share #31 Napisano Mart 13, 2016 Zavisi i kolika je veličina slotova nazad. Ako je onaj manji format onda u principu ili HiFace ili digitalni deo ove kartice: http://www.hi-files.com/forum/index.php?/topic/29485-esi-julia/#comment-606402 U svakom slučaju bolje od Amanero-a, a od SPDIF sa matične da ne govorim (ukoliko ga uopšte uspeš uloviti). Provereno, probano,...? Link to comment Podeli na ovim sajtovima More sharing options...
silentbob Napisano Mart 13, 2016 Share #32 Napisano Mart 13, 2016 Ok, idemo na amanero il jl imas i ova dva diyinhk i waveio Link to comment Podeli na ovim sajtovima More sharing options...
vinko Napisano Mart 15, 2016 Share #33 Napisano Mart 15, 2016 Molim te slikaj pa da Skrstic vidi, kod mene je pa glavimo stvari. U svakom slucaju hvala kolega Samo da javim da nisam zaboravio. Pokusavam da nadjem spdif out, znam da imam dve plocice koje mi ne trebaju, sve sam zivo preturio. Sad i mene nervira gde su. Cim nadjem, ako ne bude kasno, poslacu fotke. Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Mart 15, 2016 Share #34 Napisano Mart 15, 2016 http://www.aliexpress.com/item/latest-XMOS-U8-USB-384K-32B-module-I2S-SPDIF-output-support-DSD-for-es9018-DAC/32535682674.html?spm=2114.01010208.3.261.BKgFGK&ws_ab_test=searchweb201556_0,searchweb201602_4_505_506_503_2000017_504_301_10034_10020_502_10001_10002_10017_10005_10010_10006_10011_10003_10021_10004_10022_10009_10008_10018_10019,searchweb201603_9&btsid=330963dd-1727-4b45-921a-ec6660db8517 Link to comment Podeli na ovim sajtovima More sharing options...
prophet Napisano Mart 15, 2016 Share #35 Napisano Mart 15, 2016 Provereno, probano,...? Za HiFace vs Amanero da, slušano na istom DAC-u. Oba interfejsa implementirao isti čovek. Sistem fenomenalan, DAC verovatno najbolji izvor koji sam ikada čuo. Uvek naravno treba imati dozu rezerve što zbog softvera i OS-a što zbog niza drugih faktora. Ipak razlika je bila značajna. Oba interfejsa su imala odvojena napajanja i bila u posebnoj kutiji a koliko se sećam i sa HiFace je izveden I2S. Link to comment Podeli na ovim sajtovima More sharing options...
silentbob Napisano Maj 12, 2016 Share #36 Napisano Maj 12, 2016 Ako nisi vec pazario evo nesto novo od Loriena http://www.diyaudio.com/forums/digital-source/188902-xmos-based-asynchronous-usb-i2s-interface-281.html#post4711132 Link to comment Podeli na ovim sajtovima More sharing options...
