Woland Napisano Septembar 21, 2012 Share #1 Napisano Septembar 21, 2012 Naleteo sam na interesantan kit : Dual ES9018 balanced/unbalanced. Cena mu je 468 USD. specifikacija: DAC Dual ES9018 balanced/unbalanced 1 The DAC unit designedto use the highest industry benchmarks DAC chip ES9018, one DAC chip just handle one channel. 2.DAC board built-in microcontroller, software control ES9018 work in MONO mode, duel DAC chip for L & R channel separately. 3. Three control buttons, a mute button, an input signal selection key, a FIR roll-off mode selection key. 4. 5 source input port, two fiber optic ports, a coaxial port, an AES / EBU ports, an IIS port, source selected by a pushing key switch. 5.LED indicates the current source and the lock status, real-time display the sampling rate of the current input source. VFD display included can display the status. 6. two stage regulated voltage source supply to get a better power supply ripple rejection rate, each ES9018 DAC chip with its own regulated power supply. The regulator chip using 1086 Series. 7. analog stage using the four set of bi-op amp., with I C socket for easyreplacement and exchange difference grading op-amp components, the default precision op amp with TI / BB OPA1612. 8.ES9018 clocking to use TCXOwith 0.3ppm. 9. Double Sidedwith think copper PCBis used, signal and power traces are carefully handled. 10. audio output connectorswelded to the DAC board directly, coaxial port, RCA port are made of high-grade gold-plated terminals, balanced terminalconnector with Neutrik brand. 11. Power supply 0-15V x2 & 0-9V x4 12. DAC board size : 310mm x 225mm x 40mm http://www.ebay.com/...=item337c2ee7ae Fotografje: Kako Vam se ovo čini? Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Septembar 21, 2012 Share #2 Napisano Septembar 21, 2012 treba angažovati BBaneta i eto očas od jedne dualne 2 obične Link to comment Podeli na ovim sajtovima More sharing options...
krvimozak Napisano Septembar 21, 2012 Share #3 Napisano Septembar 21, 2012 9 USB? Link to comment Podeli na ovim sajtovima More sharing options...
Woland Napisano Septembar 21, 2012 Autor Share #4 Napisano Septembar 21, 2012 Neima. Link to comment Podeli na ovim sajtovima More sharing options...
ManicP Napisano Septembar 24, 2012 Share #5 Napisano Septembar 24, 2012 Da li neko zna koji su ovo RCA konektori? Hvala. Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Septembar 24, 2012 Share #6 Napisano Septembar 24, 2012 koji u smislu tipa ili čiji ?ovo si kinezi , šta bi drugo iz kine a ako voliš brandirano (a isto) ondaDeltron43-028 DELUXE RCA (PHONO) PANEL SOCKET PCB mounting, black43-029 DELUXE RCA (PHONO) PANEL SOCKET PCB mounting, red Link to comment Podeli na ovim sajtovima More sharing options...
Leonardo Napisano Septembar 24, 2012 Share #7 Napisano Septembar 24, 2012 Da li neko zna koji su ovo RCA konektori? Hvala. Vidiš da piše na limčiću bravice XLR-a, PUSH ! Sve su to ista buranija. Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Septembar 24, 2012 Share #8 Napisano Septembar 24, 2012 evo i npr originalnog kinezahttp://best-b2b.com/Products/545/574-1/pcb-connector_128399.html Link to comment Podeli na ovim sajtovima More sharing options...
bata bane Napisano Septembar 25, 2012 Share #9 Napisano Septembar 25, 2012 jel ko narucio ovo vec Link to comment Podeli na ovim sajtovima More sharing options...
krvimozak Napisano Septembar 25, 2012 Share #10 Napisano Septembar 25, 2012 jel ko narucio ovo vec Jel narucio sta - RCA konektore ili celu plocu? Link to comment Podeli na ovim sajtovima More sharing options...
bata bane Napisano Septembar 25, 2012 Share #11 Napisano Septembar 25, 2012 Plocu sa sve DAC. Link to comment Podeli na ovim sajtovima More sharing options...
chakija Napisano Oktobar 31, 2012 Share #12 Napisano Oktobar 31, 2012 Ja bih pazario ovaj DAC. Idealno bi mi bilo kada bi neko hteo pola-pola da uđe u priču da se sastavi i čuje?Jel može neko od iskusnijih kuka da malo "konstruktivnije" iskomentariše dizajn i vredi li investirati u ovo - možda svira bolje od weiss-a ?http://www.htpc.jp/t48/index.html Link to comment Podeli na ovim sajtovima More sharing options...
krvimozak Napisano Oktobar 31, 2012 Share #13 Napisano Oktobar 31, 2012 Jel može neko od iskusnijih kuka da malo "konstruktivnije" iskomentariše dizajn i vredi li investirati u ovo - možda svira bolje od weiss-a ???? Zasto ovaj fabricki model po tezini parira sa M53???Soske tolko materijala sahranjeno u kutiju?13kg?Zar im nije bilo lakse da ubace koju ciglu unutra? Link to comment Podeli na ovim sajtovima More sharing options...
Macsinks Napisano Oktobar 31, 2012 Share #14 Napisano Oktobar 31, 2012 ??? Zasto ovaj fabricki model po tezini parira sa M53???Soske tolko materijala sahranjeno u kutiju?13kg?Zar im nije bilo lakse da ubace koju ciglu unutra? Cela kutija je pravljenja od 11mm aluminijum. Jel zna neko koja je cena za kompletirani dac? Link to comment Podeli na ovim sajtovima More sharing options...
krvimozak Napisano Oktobar 31, 2012 Share #15 Napisano Oktobar 31, 2012 Cela kutija je pravljenja od 11mm aluminijum.A bez toga ne bi svirao kako svira? Mislim, 2mm, 3mm itd se pokazalo kao lose? Link to comment Podeli na ovim sajtovima More sharing options...
Macsinks Napisano Oktobar 31, 2012 Share #16 Napisano Oktobar 31, 2012 A bez toga ne bi svirao kako svira? Mislim, 2mm, 3mm itd se pokazalo kao lose? Ne, ali kad zelis da prodajes High End uredjaj,pomaze ako proizvod ima bar 10 KG Link to comment Podeli na ovim sajtovima More sharing options...
krvimozak Napisano Novembar 1, 2012 Share #17 Napisano Novembar 1, 2012 Ne, ali kad zelis da prodajes High End uredjaj,pomaze ako proizvod ima bar 10 KG Aha, kapiram! Pojacalo i zvucnici su mi hajend a dac jadnicak nije. Odo' da ubacim koju olovnu cev u njega, gre'ota da se izdvaja od drustva... Link to comment Podeli na ovim sajtovima More sharing options...
ManicP Napisano Novembar 1, 2012 Share #18 Napisano Novembar 1, 2012 To s olovnim cevkama je stara fora... ...npr. EMU 0202 USB je u laganom plastikanac kućištu a na bočnim stranama ima umetnuta dva gvozdena flaha da dobije malo na kilaži. Link to comment Podeli na ovim sajtovima More sharing options...
grau. Napisano Novembar 1, 2012 Share #19 Napisano Novembar 1, 2012 malo ste se zaleteli u tu pricu o kilazi, kod pro uredjaja je dosta bitno da kabel ne moze da drzi uredjaj u vazduhu, ako razumete sta hocu da kazem. neces da trazis ciglu po stadionu na kome radis posao, nego sprava treba da ima dovoljnu tezinu da je periferije ne pomerajunego bitnije pitanje, jel bi neko umeo da sa cipa izvuce atenuaciju, to za ESS32 ne bi trebalo da je problem.takodje bi lepo bilo da se kontrolise preko daljinca, i to i ulazi:) Link to comment Podeli na ovim sajtovima More sharing options...
chakija Napisano Novembar 1, 2012 Share #20 Napisano Novembar 1, 2012 Ja bih pazario ovaj DAC. Idealno bi mi bilo kada bi neko hteo pola-pola da uđe u priču da se sastavi i čuje?Jel može neko od iskusnijih kuka da malo "konstruktivnije" iskomentariše dizajn i vredi li investirati u ovo - možda svira bolje od weiss-a ?http://www.htpc.jp/t48/index.html...aj malo da iscitiram sebe da se priča ne svede samo na to koliko je teška kutija. Link to comment Podeli na ovim sajtovima More sharing options...
dj.nik Napisano Novembar 1, 2012 Share #21 Napisano Novembar 1, 2012 A šta da pazariš kad je već prodat :)Ima (makar) jedan u Bgd. Sam ga čuo. Nemo' se nadaš - nije bolji od Weiss-a :DDoduše postavka mi se nije svidela, garantovano to može bolje da radi:CD plejer srednje klase vrteo CeDe-je, što bi rekli biJo transporat pa signal doturen u ovaj 'Dual ES9018'Ja biK rekao - ni trećina mogućnosti ES9018 nije upotrebljena. Link to comment Podeli na ovim sajtovima More sharing options...
d.veljko Napisano Novembar 1, 2012 Share #22 Napisano Novembar 1, 2012 Ja bih pazario ovaj DAC. Idealno bi mi bilo kada bi neko hteo pola-pola da uđe u priču da se sastavi i čuje? Jel može neko od iskusnijih kuka da malo "konstruktivnije" iskomentariše dizajn i vredi li investirati u ovo - možda svira bolje od weiss-a ? http://www.htpc.jp/t48/index.htmlA gde pise kolika je cena?I vec si odustao od http://www.ebay.nl/itm/Hongji-Audio-ES9018-Sabre32-Reference-32bit-DAC-/280913545884?pt=US_CD_Players_Recorders&hash=item4167c08a9c Link to comment Podeli na ovim sajtovima More sharing options...
