NIXIE Napisano Mart 14, 2023 Autor Share #23 Napisano Mart 14, 2023 (izmenjeno) The I²S protocol outlines one specific type of PCM digital audio communication with defined parameters outlined in the Philips specification. The bus consists of at least three lines: Bit clock line Officially "continuous serial clock (SCK)".[1] Typically written "bit clock (BCLK)".[3] Word clock line Officially "word select (WS)".[1] Typically called "left-right clock (LRCLK)"[3] or "frame sync (FS)".[4] 0 = Left channel, 1 = Right channel[1] At least one multiplexed data line Officially "serial data (SD)",[1] but can be called SDATA, SDIN, SDOUT, DACDAT, ADCDAT, etc.[3] It may also include the following lines: Master clock (typically 256 x LRCLK) This is not part of the I2S standard,[5] but is commonly included for synchronizing the internal operation of the analog/digital converters.[4][6] Znači sve ima na gogleta, ne mora da se pita. Ovo su pinovi koji se koriste na BT pločici: 1 - SCK=BCK 2 - WS=LRCK 3 - DATA=DATA 4 - napajanje +5V struja do 30mA 5 - GND vezati na napajanje za BT pločicu MCK se ne koristi u ovom slučaju Izmenjeno Mart 14, 2023 od NIXIE Link to comment Podeli na ovim sajtovima More sharing options...
_fly_ Napisano Mart 14, 2023 Share #24 Napisano Mart 14, 2023 Kakva zbrka, gledao sam onaj "Schematic diagram" sto je dao u opisu. Tamo pise WS, SCK i DAT. Hvala na objasnjenju. Link to comment Podeli na ovim sajtovima More sharing options...
NIXIE Napisano Mart 14, 2023 Autor Share #25 Napisano Mart 14, 2023 Sa tom digitalijom nema problema, ako pogrešno povežeš I2S neće da crkne, smo neće radi. Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano Mart 14, 2023 Share #26 Napisano Mart 14, 2023 Ja kad sam pravio PCM obrnuo naopako I2S žice. Šušti kao radio bez stanice NIXIE je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
VukJov Napisano Mart 14, 2023 Share #27 Napisano Mart 14, 2023 30 minutes ago, NIXIE said: Sa tom digitalijom nema problema, ako pogrešno povežeš I2S neće da crkne, smo neće radi. Не мора да се повеже погрешно, некад неће да ради и када је исправно повезано, довољно да су предугачке жице и сл.. Link to comment Podeli na ovim sajtovima More sharing options...
NIXIE Napisano Mart 14, 2023 Autor Share #28 Napisano Mart 14, 2023 U jednom daku (nije moj naravno, samo sam ga malo sređivao) je bilo 30cm I2S kabla. Hteo sam ali nisam mogao to da promenim tako je bilo zakucano. Radilo je bez problema. Da je dobro nije, ali tako je bilo. Link to comment Podeli na ovim sajtovima More sharing options...
