neskor
Sve objavljeno od neskor
  1. ja sam i dalje u soku od juce onakav BR bas nisam nikada cuo... reference dubina i sirina pozornice, super definicija svakog dela zvucnog spektra.... ukljucis i zaboravis na zvucnike, ostaje samo muzika ja bih se samo malo poigrao sa amplifikacijom, mozda neki lampas za srednje i visoke
  2. Ja sam na svojoj bivsoj Lampuceri umesto izlaznih kondova stavljao 600:600 trafoe i bio prezadovoljan sa zvukom. Naravno svaki trafo ima svoj "zvuk".
  3. dugo ocekivani LP konacno stigao:
  4. SME+Denon 103R
  5. nije preporucljivo brisati ploce sa ovim jer je abrazivni materijal, nesto nalik finoj smirgli
  6. za ciscenje igle ja uzeh ovo:
  7. neskor
    clip on ferrites
    Mislim da sam video kod Tome iz Krusevca. A vidim i da ima ovde: http://www.mikroprinc.com/proizvodi/elektromehanicke-komponente/instalacioni-materijal/prateci-kablovski-materijal/index.php
  8. Amanero u Buffalo III
  9. mozda bolje odmah usb na i2s
  10. evo i slika:
  11. evo seme SSC3.pdf
  12. ja porucio
  13. probajte da napravite Valve itch necete zazaliti http://www.diyaudio.com/forums/analogue-source/140635-valve-itch-phono.html
  14. The Sound Engineering Magazine db Magazine covered audio engineering.from about 1968 to 1994 (28 single volume years) http://www.americanradiohistory.com/db-Magazine-Guide.htm
  15. Malo da se prisetim metalskih dana
  16. da citiram: Q: Does anyone know which Lundahl tansformer is used in the Ortofon Verto SUT? A: I don't and Lundahl will not share that sort of info, so there's no use asking. Size might be a good clue if you can see the inside of one... The appearance suggests something based on the LL9226/LL1678 size core. Kevin Carter K&K Audio www.kandkaudio.com
  17. ima ih ovde: http://www.ebay.co.uk/itm/Neutrik-NF2D-B-9-Phono-RCA-Chassis-Panel-Socket-White-00837-/200960280341?pt=UK_Musical_Cables_Leads_Connectors&hash=item2eca2a8715
  18. Wes Montgomery - Milt Jackson - George Shearing ‎– Wes And Friends
  19. sjajan album
  20. Galliano - Twyford Down
  21. drugar porucio i ovo je posledica njihove "saradnje"
  22. i mene zanima
  • Trenutno na sajtu   0 članova, 0 Skrivenih, 1170 Gosta (Pogledaj celu listu)
