Doktor
Sve objavljeno od Doktor
  1. Mislim da se ovde radilo o izradi betonskih cipela za nekoga posebno, tj,. dedikejtid para.
  2. https://en.wikipedia.org/wiki/Naim_Audio_amplification#Design_principles Output protection[edit] Vereker also believed that a well-designed amplifier must be stable at all times when driving real-life loads, which are different from those achieved in lab conditions because loudspeakers' impedances vary with frequency.[9] The inherent compromise between the pursuits for stability and sound quality means that Naim's power amplifiers are designed to work optimally with its own moderately priced NAC A5 speaker cable, and its predecessor NAC A4.[19] Product manuals warn users against using "high-definition wire or any other special cable between amplifier and loudspeaker".[18][21] Whilst other manufacturers habitually employ Zobel networks[1] (or an output filter which enhances amplifiers' stability) to protect against use with speakers and or cables with very high-capacitance, Naim amplifiers routinely omit these filters because of their adverse effect on sound quality. The design decision was made to use a suitable length of speaker cable (a minimum of 3.5m, with 5m being optimal) to provide the effective inductance.[1][19] - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - http://www.tnt-audio.com/ampli/nait_e.html " Use Naim cables whenever possible. NAC A5 cables are the best choice (minimum lenght 3.5 meters per channel) but even older NAC A4's could work fine. Both can be found cheap second-hand.DO NOT USE high capacitance cables like our DIY speaker wires." - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - https://www.webcitation.org/6LADjpt0v - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Zaključak : @crni. - znači 3,5 m je minimum. Optimalno bi bilo 5 m po strani. Jedan je bio Vereker, kao što je jedan i Ken Kessler. https://www.kenkessler.com/hi-fi/interviews/an-interview-with-julian-vereker/
  3. Normalno je. Pa to je Naim, a ne neke bzv. audio "kofice". Dakle, NACA5 i . . . vozi.
  4. Kako gde smo ? Pa, tu smo vazda, doduše lurkujemo po običaju. Videh, pratim, ali već imam komada 1, valjao bi još jedan za u kujnu. Nego, isti prodavac, e to je prilika za forumske ribolovce. https://www.limundo.com/kupovina/Sportska-oprema/Ribolovacka-oprema/Stapovi-za-pecanje/Stapovi-za-Pecanje-sa-Masinicama-DAM-Cormoran-Shiver/76347533 Hint - sve ovo za 999 d.
  5. Kako sta je ? Pa SDO ( suvi dnevni obrok ) iz nekadasnje JNA, onaj sto ima u kompletu konzervu sardina.
  6. ^ IMO - Hajdnovih " 7 poslednjih reci Hrista " mi je def. blize od Sostakovicevog kvrteta br. 15.
  7. Vidi, nesam to znao . . . ali, kao i uvek, targetiras da preslusas jedno zbog neceg' , ali se tako namesti . . . Schnittke je eto naleteo . . . odlicno . . . nesto se slicno dogodilo i meni pre vise godina kada sam zbog Schnittke-a dosao do Schoenberg-a.
  8. ^ Snitke . . . . sto bi se reklo u slengu "gadno", naravno u pozitivu . . . ovaj njegov klavirski kvintet je def. za imati u kolekciji. Bilo koji oblik medije je OK.
  9. Slavlje, jerbo je nejaki postar doneo danas samo papirce da je Box Set sa 5 LP prihajao u Prestonicu. Sutra kolektiram, dovlacim u jazbinu, otvaram, pustam, slusam, slikam, postujem . . . Trenutno ide 1st album JH Experience koji je, pa naravno, do yaya . . .
  10. Yeeeep. Cekamo . . . DC 4ever.
  11. Mda. Koja tiha jeza i dunsteraj . Ne govorih ja dzaba da DC rulezzzzz ! Pocetak kraja za sve Marvelovce.
  12. E, ovaj film od mene ima ozbiljnu preporuku. Svaka pojava Arona Sorkina kada iscitavam o nekom filmu mi momentalno pali crvenu lampicu. https://www.imdb.com/name/nm0815070/ Hint : The Social Network i TV serija The Newsroom. Najkrace receno - remek dela.
  13. A film od pre par godina ? Molly's Game ? Koja rola preambicioznog ( u relaciji deteta ) caleta ? Razbio kao epizodista.
  14. Naravno. To su vec filmski klasici i obavezno "stivo" za svakoga ko voli i postuje film generalno. Ovde bih dodao i Igru s vukovima i Dz.F.K.
  15. Pogledao danas The Highwaymen na Netflix platformi. Kevin Kostner i Vudi Harelson odrzali masterklas glume. Bas mi "legao" ovaj film. Preporuka. Teksaski rendzeri, povratnici u cilju eliminacije cuvenog geng para ( Boni i Klajd ). Ono sto me je insultovalo nakon gledanja ovog filma su kritike, narocito kritika The Guardian-a. Toliki animozitet prema svemu sto dolazi iz Netflix-a je toliko ocigledan i postaje polako i oduran. "Dinosaurusi" iz filmske industrije polako posrcu, ali i dalje imaju uticaj na pojedince da pisu konstantno negativne kritike. Zakljucak - ne verujte svemu sto napisu Metacritic, kao i RT ( Rotten Tomatoes ). O "jadnom" The Guardian-u necu vise trositi reci.
  16. ^ Ne da je guzva, vec je postalo neprijatno. Retke ploce Dzimi Henriksa mi cuce i dalje u KG ( 27.03.2019. predato ). 01.04.2019. jedna knjiga iz Leskovca ( nema traking, tako da ni ne znam gde je trenutno ). 02.04.2019. knjiga poslata iz NS-a ( takodje bez trekinga, nemam pojma da li je uopste krenula ). Guzva kao guzva, ali vise neprijatno ( sva 3 item-a su naslovljena na medicinsku ustanovu gde radim, onako za info ).
  17. Nego, ima po netu sinopsis 1. epizode koja ce da bidne u nedelju. Ste citali, videli ? Eve je u attach, pa ko nema prblm za spojler-e, ete je. 1 ep..txt
  18. Meni taj post nije uopste smesan.
  19. Skoro pa svi ce da zaginu. Meni bitno samo da Dzora, Klegan i Berik nekako izvuku zive glave, za sve ostale mi manje bitno. Ocigledno je da mi ljubimica Sersei nece docekati zadnju klapu finalne sezone. Na zalost. A da, kako za sada stoje stvari po net-u, Tarli ce da pretekne.
  20. ^ E ovaj Nocni kralj i njegovi Beli setaci mi bas ono pravo idu na qrc. Malo je pardoxalno u mom slucaju, jer obozavam undead-e, ostale spodobe iz negativnog tabora, ali ove od samog starta nesto ne mirisem. Jbga, kad' sam Lannister fan.
  21. A pokojni Nusrat ( also Pakistan ) ?
  22. Thnx. Uteftereno i bez da slusam. Krenula je upravo potraga.
  • Trenutno na sajtu   1 član, 0 Skrivenih, 305 Gosta (Pogledaj celu listu)
    453.7k
