InSides
Sve objavljeno od InSides
  1. I will try to summarize.I started this thread with the intent of acquiring several M2.5 machine head/allen head screws and a M2.5 tapping bit set, in order to, in the end, create a brass mounting plate for my Denon DL-103. I would like to run it nude to see what the hype is all about. This is an example of the work I needed done: Denon DL-103 and a brass plate Alas, the gentleman that had built these in the past wanted $50 + shipping for a single plate, and I thought that I would be able to get the tools for that amount and still have the tools once I'm done. But the nice gentleman at the board [namely ZM and stoN_Kold] offered to get the plate made for me and thus spare me of a potentially hideous monstrosity that would surely arise when I attempt to use such tools. Seeing that I also am looking forward in getting my tonearm wire from these gentlemen, this is quite convenient. Now, Mr. Magura, if you can help additionally in any other manner, it would be much appreciated. All the best, InSides, the Macedonian.
  2. Након задњег прерачуна, схватио сам да ове димензије горе су мало претеране, и добијем више тежине него што сам тражио.Зато, ево овде ревидиран цртеж. Дебљина лима 2мм опет, оквирна димензија 18мм х 18мм.
  3. Ево и цртежа... надам се да је довољно јасан.По прорачунима, 2мм дебео лим би био сасвим довољан.
  4. Odlichno, hvala puno.Ja idem da pripremim crtez i zalepim ovde.
  5. Poshtovani kolega stoN_Kold,probachu da nadjem neki od tih kasetnih dekova, ali se ne nadam neshto tome previshe - ipak je pazar u Makedoniji maleni.E sada, alternativno, kako sve one stvari koje bih dobio od Vas stane u jedan maleni koverat, mozda bi najbolje bilo da ja Vama direktno platim za sve to i vi meni poshaljete u Makedoniji?Pishite mi, molim Vas, koliko bi to sve skupa bilo, i mozemo ichi dalje - ako se slazete.A kad zavrshimo transakciju, ukoliko nadjem neki od tih dekova, dobijete na poklon. Ukoliko nadjem.Hvala.@Zen_Mod - hvala moderatoru na link za magnete, ali ja vech poruchio, i to nekoliko velichina. Kako dobijem 20 setova za istu cenu, kad magneti stignu, ostatak ide zainteresovanih likova na ovom Forumu... pokrijem i poshtarinu.P.S. Kolika je debljina tog mesinganog/bakarnog lima koji bi koristili za podloshke? 2mm? 3mm?
  6. Није мени неки велики проблем да купим алат - можда искористим опет некада.Ал што се тиче завртњева, требали би ми десетак... са матицом или без, зависи од тога дали могу да поручим и добијем урезницу.M2.5 x 10mm дужина.П.С. И шта бих могао да понудим у замени за жицу и завртњеве...? Очигледно не могу прекидач...
  7. Hvala na iscrpnim odgovorima. Sharafe sam hteo naruchiti svakako... zato sam i pitao gde ih mogu nachi. Radi se o dimenziji M2.5. Najmanje shto sam nashao u Makedoniji je M3. A shto se tiche ureznica/nareznica, hteo bih da uradim navoj U nechemu. Da skratim, hteo bih da eksperimentishem sa DL-103 i da ga montiram na metalnoj plochici. Evo [male] slike kako bi to izgledalo: Radi se o mesinganoj plochici izmedju headshella i ono shto je ostalo od DL-103-ke. Kao shto se moze videti, navoj mora biti U plochici kako bih mogao montirati zvuchnicu. Svakako, i ne mora biti navoja, nego samo rupe pa iskoristim maticu... ali ovo je puno bolje. Bilo je nekog tipa koji je te plochice radio za $50 + shipping, ali za te pare mogu kupiti alate, ne?
  8. Izvinio bih se svima zbog upotrebe Engleskog u naslov teme, ali stvarno nemam pojma kako se to zove na bilo kojim drugim jezikom [ukljuchujuchi i moj rodjeni].Elem, trazim alat za pravljenje navoja M2.5 [slichno alatima u bata bane-ovim postovima] kako i shtrafovi M2.5.To su bash navoji za montiranje zvuchnica - i mada imam nekoliko setova koje sam dobio sa zvuchnicama, trebaju mi josh za nekoliko eksperimenata.Prvo molio bih vas za tachan naziv alata kako i mesta gde bih ih mogao nabaviti [kao i shtrafove].
  9. Ne mogu da najdem taj prekidach... jel' mogu da ponudim neshto drugo u zamenu za zicu?
  10. Kako kaze naslov, kupujem 2 komada Mundorf 2.2uF.Za sada bi se ogranichio na MCap / MCap ZN ili MCap Supreme.Sve iznad toga je malo too rich for my blood.
  11. Jel' se to radi o ovome?http://www.diyaudio.rs/index.php/topic/332-prekidac/
  12. Kako chemo sada?
  13. Hvala. Ne zuri se meni puno.
  14. MSS7? Ili onu koja Zen Mod predlaze?U svakom sluchaju, da li je ta zica na prodaju? Treba mi oko 4-5 metara.
  15. Elem, treba mi zica za ruchicu. Neshto fleksibilno i ne deblje od 32AWG, recimo.Znam da kod Korata bi trebali imati VdH MSS-7, ali ne javlja se niko na telefon i ne mogu dobiti informacije o lageru i cenu. Mozda ima neko...?Ne mora biti VdH. Sve shto je kvalitetno, a moze se nabaviti lokalno.
  16. Zaboravio da stavim update na ovo... ipak uzeo pertle: Hvala svima.
  17. Hvala!Dali mozda imate sliku kako izgleda ova plochica montirana na hladnjaku? Mislim, treba li mi hladnjak kako onaj koji Pass koristi, sa "flange" ili kako se vech zove?Ja bi koristio HiFi2000 Pessante Disipante kutiju, koja ima ravan hladnjak.
  18. Niko nema plochice? Jeli neko radio F1 point-to-point onda?
  19. Haha, ne prodajem ja kablove, niti nameravam da pochnem. Hteo bih da promenim ozichenje u mojim K-1000 slushalicama, pa bash mi se svideo nylon multifilament.Proverichu i one dve druge opcije, uzad [hvala Zen-u], a vech sam se javio kod Kanibala.Trecha opcija su mi pertle, kako i da to smeshno zvuchi. @Stein,hvala za preporuku mikrofonskog kabla. Nashao sam u Skoplju Tasker C301, koji u sebi ima 2 x 24AWG licnast OFC - metar je 1 EUR.
  20. Radi se o ovome: Nylon Multifilament @ Cable Organizer Nemam pojma kako se lokalno zove, nit' dali se moze nachi. Naruchio bih ja od ovih gore, ali mi stvarno ne treba 80+ metara. I nije Techflex, to je chini mi se mono-filament, meni treba bash ovo gore. I josh... ...da ne radim poseban topic, treba mi licnasta visoko kvalitetna zica... ili dobar bakar, ili srebro, ili posrebren bakar. Velichina 24AWG ili ti 0.2050mm2. Duzina oko 20 metara. Teflonska izolacija je plus. Hvala svima.
  21. Kupujem komplet plochica za FirstWatt F1. 2 x amp + 1 x PSU.Ponude ovde ili na PP.
  • Trenutno na sajtu   3 članova, 1 Skrivenih, 86 Gosta (Pogledaj celu listu)
    452.7k
