Kuja
Sve objavljeno od Kuja
  1. Evo ja prvi nisam znao tačan odgovor na to pitanje, ali mi nije bilo teško da pitam Google. Jedan od rezultata pretrage: https://superuser.com/questions/1582324/if-you-run-fast-ram-at-a-slower-clock-speed-will-the-latency-timings-improve ---=== Timings at Standard Speeds ===--- AA-RCD-RP-RAS (cycles) as DDR4-2666 19-19-19-43 AA-RCD-RP-RAS (cycles) as DDR4-2400 17-17-17-39 AA-RCD-RP-RAS (cycles) as DDR4-2133 15-15-15-35 AA-RCD-RP-RAS (cycles) as DDR4-1866 13-13-13-30 AA-RCD-RP-RAS (cycles) as DDR4-1600 11-11-11-26 Ako sam dobro razumeo ovo gore, spuštanje brzine memorije poboljšava latenciju. Znači, umesto da se nerviramo i ljutimo na Miku, lepo u Google ukucamo nešto tipa: "does latency change if I use faster RAM in a slower motherboard".
  2. Ali to ne radi Lemić! Sludećemo čoveka načisto! Nije pitao kakav RAM mu treba za rad sa gigabajtima bibloteka semplova.
  3. Ma sve super, nije sporno, neka se time bavi onaj ko na taj način sluša muziku.
  4. Ovo nema mnogo veze sa slušanjem muzike onako kako mi to radimo. Ima veze kada u DAW-u (Digital Audio Workstation, znači u pitanju je audio produkcija a ne reprodukcija) imaš aktivnih više desetina kanala sa gomilama učitanih semplova. Why do sample libraries need so much memory? And how do you know what sort of RAM to buy? Read on for everything you always wanted to know about RAM but were afraid to ask. . . RAM is one of the biggest bottlenecks when it comes to smooth playback of digital audio, especially when large sample libraries are involved. We’ve all been there: splurging on some juicy Black Friday deal only to find that the monster 50 GB library we’ve just installed now causes our whole template to grind to a halt. At some point, an upgrade is inevitable.
  5. Ja to nisam pominjao. U mom slučaju, igra sa RAM-om nije imala veze sa kvalitetom zvuka, već sam hteo da klincu pojačam memoriju u laptopu, pa sam gledao da mu se gađaju moduli po pitanju specifikacija. Izvršio sam rokadu RAM-a između NUC-a i laptopa i to je bilo to. Kao što već rekoh, imam pametnija posla od testiranja maksimalnih dometa kompjutera. Recimo da ga koristim za ono za što je namenjen - slušanje muzike.
  6. To bi jedino imalo smisla kada bih imao native/full DSD DAC. Ovako, poptpuno je besmisleno da u letu PCM konvertujem u DSD, da bi moj DAC (koristi PCM1704 čipove, ali može da primi DSD na ulazu) taj DSD ponovo konvertovao u PCM.
  7. Nemam pametnija posla!
  8. Zaboravih, @Lemić koliko RAM-a već imaš u tim NUC-ovima? Zašto bi uopšte kupovao još? Ja u mom imam 8GB i to mi je sasvim dovoljno.
  9. Ja sam zbog neke kombinatorike nevezane za audio, vrteo nekoliko RAM modula između NUC-a i laptopa mog klinca. U pitanju su bili moduli različitih "megahercaža" i latencija. Nikakvu razliku u zvuku na NUC-u nisam čuo. Na kraju je, čisto zbog uparivanja modula istih latencija u laptopu, u NUC-u završio brži RAM sa većom latencijom, umesto sporijeg sa nižom koji je bio originalno instaliran. Kao što rekoh, nije bilo nikakve razlike u zvuku. Zato Lemiću, kupi slobodno jeftiniji RAM i ostatak potroši na ćevape!
  10. Kuja
    diyAudio.rs Linux OS
    Ne znam ni koji je problem! Ja ga nemam.
  11. Kuja
    Ama ja više puta ovde napisao da ti i ja ne koristimo istu verziju/instalaciju SnakeOila-a. Tačka.
  12. Kuja
    Čekaj malo, ti mene ubeđuješ da mi nešto ne radi, i ako sve radi bez problema. Smb file sharing radi u svim pravcima - i NUC vidi diskove u mreži svih komjutera u kući, i svi uređaji u kući vide disk na NUC-u, ...i muziku puštam u svim pravcima - NUC kao deo LMS ekosistema kontroliše druge uređaje i drugi uređaji kontrolišu njega, ...i brzina protoka je dobra... ..i meni ništa više od toga ne treba! Ne treba mi kurs Linux-a, kada mi sve radi bez problema i tačno onoliko koliko mi treba za šta mi treba. Pa ne zaobilaziš ti nas! Uzeo si SnakeOil i NUC na zub ni krive ni dužne! Ja sve vreme lepo govorim nek cveta hiljadu cvetova! Ti hoćeš da imaš supergiga mašinu za Viber, filmove i Steam igre, odlično! Brža je i jača u svakom pogledu od NUC-a, odlično! Napravio si sistem baš kakav tebi odgovara, odlično! Nama takav kompjuter i sistem ne trebaju, isto tako odlično! Pusti mene i Srećka da na miru uživamo na način koji nas zadovoljava i čini srećnim, i hajde da idemo dalje! Na kraju svega nije bitno čiji je Kernel veći , podelili smo različita iskustva i nadamo se da će nešto od toga biti i od koristi zainteresovanima za ovu temu.
  13. Kuja
    Nemam pojma kakve veze ima, ti si pominjao neke probleme sa protokom i SnakeOil-om:
  14. Kuja
    Pa mogu i ja. LMS na MacMini-ju mi vidi Squeezelite plejer na NUC-u.
  15. Kuja
    Kada sam napisao 50-ak MB/s mislio sam megabajata u sekundi a ne Mbit/megabita. To mi je sasvim pristojna brzina za matori hardver i mts ruter.
  16. Kuja
    Meni se SSD na NUC-u kao smb share vidi na svim drugim kompjuterima u kući, kao i na Android TV-u (vide ga i VLC i Kodi i Total Commander), a vide ga i telefoni. Klinac upravo sada u svojoj sobi pušta muziku koja se nalazi na disku NUC-a. Neki put čak iskopiram i filmove na SSD NUC-a pa ih onda gledamo na TV-u, a tako i delimo i razne fajlove po kući između kompjutera (recimo ako treba da se nešto štampa, pošto je ženin kompjuter vezan za štampač u njenoj radnoj sobi). NUC nam u kući dođe i kao neki mali NAS. Znači file sharing sa NUC-om pod SnakeOil-om fercera u svim oblicima i pravcima bez ikakvih problema i štucanja, a radi i internet streaming preko LMS-a. Qobuz preko LMS-a svira kod klinca na Squeezebox Touch-u, kao i na Squeezebox Classic-u u spavaćoj sobi. ...Ali ja koristim originalnu SnakeOil instalaciju.
  17. Kuja
    Ja sa protokom nemam problema. Internet streaming (Qobuz) ne štuca i radi glatko i sa 24/192 FLAC-om, ...muzičke fajlove na SSD na NUC-u kopiram preko sambe brzinom od nekih 50-ak MB/s (ograničenje rutera, ista brzina mi je i u komunikaciji sa ostalim kompjuterima u kući).
  18. Hvala gosn @Srecko, imam instaliran taj plugin. Malo sam se igrao sa njim, ali koliko se sećam on zahteva Squeezelite R2? Pošto ja preferiram R verziju, ne koristim ga trenutno, pogotovu što mi sa njim ne funkcioniše RAM playback.
  19. Kuja
    Na svu sreću LMS zajednica je veoma živa i plugin-ovi se redovno apdejtuju. Qobuz.com streaming plugin - Squeezebox : Community : Forums FORUMS.SLIMDEVICES.COM iPeng, OrangeSqueeze, Squeezelite, BBCiPlayer, CustomBrowse, Youtube, etc.
  20. Kuja
    Ako je podržan i LMS, za njega postoje plugin-ovi za sve streaming servise. Ja koristim Qobuz preko LMS-a i to radi odlično, update plugin-ova je redovan.
  21. Kuja
    Čini mi se da sam o tome već ranije pisao. Eksperimentisao sam sa promenama prioriteta Squezelite plejera i/ili LMS-a ali to je rezultovalo seckanjem zvuka i zaglavljivanjem, pa sam odustao.
  22. Nisam siguran da su šiljci rešenje za NUC na DAC-u. Vibracije iz NUC-a (ventilator, itd) putem šiljaka, kuplovanjem, bi smo prenosili na DAC?
  23. Kuja
    Sve super! Na našu veliku žalost nismo svi sa tvojim i gosn Žikinim znanjem. Za nas smrtnike tu su SnakeOil i slične distribucije, koji složene komande koje bi se kucale u terminalu pakuju u lakše razumljiv GUI. Možda kod nije tako elegantan, ali ako mačka lovi miševe nije bitno koje je boje!
  24. Kuja
    Da drugi koji sve ovo čitaju ne bi bili zbunjeni, da razjasnimo korišćenje TOP komande... U SnakeOil-u koristim TOP da bih video koji mi je IRQ za USB audio. U mom slučaju to je: "irq/23-ehci_hcd". Onda u Process Priority sekciji samo zadam rt prioritet za "irq/23" i to je to. Nadam se da je dovoljno selektivno. ...A ako hoću da dodeljujem nivoe proriteta drugim procesima, samo kliknem na Add Process ... Meni ovo završava posao, a siguran sam da i Miki njegov metod radi ono što mu treba. Što bi rekli "There's more than one way to skin a cat". Neka cveta hiljadu cvetova! Dodatno, miš, tastaturu i štampač i onako ne koristim, a i svi ostali USB portovi su mi ubijeni u BIOS-u, pošto je u pitanju headless kompjuter čija je jedina funkcija da bude audio komponenta. Naravno, to je samo jedan od pomentuih hiljadu cvetova.
  • Trenutno na sajtu   2 članova, 0 Skrivenih, 146 Gosta (Pogledaj celu listu)
    453.5k
