1119 -
25
Postovi objavljeno od Eci
Ovaj deo takodje nije na crtežima, ubačen je u toku rada, sprečava vibriranje dela W. Radi se o uporniku koji se nalazi izmedju W i L, trapeznog je oblika.
This part is also not on the drawings, it was inserted during the building process, prevents the vibration of part W. It is a trapezoidal shape vertical part located between parts W and L.
Proba: kako se deo W uklapa - veoma bitan deo, razdvaja kompresioni deo kutije od unutrašnje horne, formira ujedno i grlo horne
Ostali delovi su stavljeni sa stegama, čisto da se stekne uvid, kako će to izgledati
Test: How the part W fits - a very important part, separates the compression part of the box from the inner horn, and also forms the horn throat.
All other parts are placed with clamps, just to see how the box will look like
Trenutno na sajtu 4 članova, 2 Skrivenih, 59 Gosta (Pogledaj celu listu)
Ukupan broj tema435.9k
DIY Tannoy Westminster Royal
in Project gallery/WIKI
Sledeći delovi nisu na crtežima, ubacuju se u toku rada. Radi se o formiranju tunela, postoje otvori izmedju delova O i dela P, zatvaraju se sa trouglovima ( formiraju se stranice levog i desnog tunela ). Označeno na slici sa crvenim strelicama. Takodje postoje otvori ( levo i desno ) izmedju delova O, D, H i F - to je na slici zaokruženo žutom bojom, koji se zatvaraju delom koji je na sledećoj slici ( trapez čija je donja ivica oborena na 45*, ta ivica naleže na O )
The following parts are not on the drawings, they are inserted during the building process; They are necessary for tunnel forming. There are openings between the O parts and part P, they should be closed with triangle shape parts (they forming on this way the sides of the left and right tunnel). That is marked on the picture with red arrows. There are also openings (left and right ) between the parts O, D, H and F – they are on the picture circled with yellow. That openings should be closed with a part what is shown on the next picture (a trapezoid, whose bottom edge is lowered to 45 *, that edge comes on the part O)
