1119 -
25
Postovi objavljeno od Eci
Kutije se zatim polože na ledja, radi formiranja gornje krivine sa MDF letvicama. Svaka se posebno obradjuje kao i kod donje krivine.
After this process the boxes should be laid on the rear side, to form the upper curve with MDF strips. Every strip should be especially processed, like by the lower curve.
Formiranje gornje i donje krivine je izvedeno sa MDF 19mm, svaka MDF letvica je obradjena sa 4 strane, pošto se dimenzije menjaju sa promenom nagiba..
Forming the upper and lower curve was realized with 19mm thick MDF. Each MDF strip was processed from four sides, because the dimensions are vary with the change of slope ..
Ovaj deo nije na crtežima. Ovako rešenje je primenjeno za formiranje krivina prednje horne. Napravljen je nosač, koji naleže 5mm na otvor prednje strane H, i jedan deo iznutra na H. Zadnji deo nosača naleže na S1. Isto, nosač je uradjen i za gornju krivinu, sa istim principom naleganja na H i S1.Nosač za formiranje donje krivine
This part is not on the drawings. This solution was applied to form the curve of the front horn. There was made a carrier which one part lays 5mm on the hole of the front side H, and the other part lays inside the H. The rear part of the carrier lays on the S1. The same way, another carrier was made for the upper curve too, with the same principle of laying on H and S1.On the picture : carrier for forming the lower curve
Furniran S1.Stranice A nisu zalepljene, gornja ploča G nije zalepljena. Razlog je velika težina kutija, koje će se u kasnijim koracima morati okretati.
Part S1 veneered.The A sides are not fixed, the top plate G is also not fixed in this moment to the box. The reason is the large weight of the boxes, which should be rotate in later steps of production
Trenutno na sajtu 3 članova, 1 Skrivenih, 39 Gosta (Pogledaj celu listu)
Ukupan broj tema435.9k
DIY Tannoy Westminster Royal
in Project gallery/WIKI
Nastavak
Process continues
