1119 -
25
Postovi objavljeno od Eci
Pogled od napred
Zadnja strana je stavljena ( nije pričvršćena ), čisto da se vidi kako se formira kutija
Tu je i naziv projekta, probani su razni fontovi i veličine papira, kao i gde treba papir postaviti
View from the front
The rear side ( part E ) is added ( it is not attached ), just to see how the box looks like
Here is also the name of the project, various letter fonts were tested and various paper sizes, also where to set the paper
Unutrašnjost kutije, pogled na S2 i S1Zabušene rupe i zavrnute matice sa spoljnim navojem ( unutrašnji navoj je 6mm ). Matice gore i dole prodiru kroz S1 u MDF, a levo i desno u deo K. HPD385 se postavlja iznutra.The box from inside, view to parts S2 and S1 .The holes are predrilled and the “Insert Nuts for wood Type D M6x13mm “are tightened. Nuts up and down across the S1 penetrate into the MDF. Nuts left and right into the parts K. HPD385 is placed from inside the box.
Ovaj momenat nije na crtežima. Na stranicu C iznad dela B izbušiti otvor prečnika 100mm. Ovim se uključuje u kompresioni deo kutije i zapremina koja je ograničena sa C, B, A i T
This move is not on the drawings. On the side C, above the part B, drill a hole of 100mm diameter. With this, the volume what is limited with parts C, B, A and T is added to the compression part of the box.
Nanošenje lepka na donju krivinu. šper 4mm je iskrojen pomoću papirnog modela. Nosači naležu 5mm na otvor od H, MDF je 19mm. Kada se sabere to je 28mm što je i debljina H.
Application of glue on the lower curve. The plywood was cut out, using the previously made paper model. Carriers are laying 5mm on the opening of H, the MDF is 19mm thick, the plywood is 4mm thick. All thicknesses added up making 28mm, what is also the thickness of H.
Već na prethodnoj slici, kutije su okrenute - stoje na delu T, zbog velikog nagiba lakše je postavljati MDF letviceZavršena gornja krivina
On the previous picture, the boxes are already turned ,and laying on the part T, because the large slope; it is easier to set the MDF stripsThe upper curve is completed
Trenutno na sajtu 3 članova, 0 Skrivenih, 56 Gosta (Pogledaj celu listu)
Ukupan broj tema435.9k
DIY Tannoy Westminster Royal
in Project gallery/WIKI
Posle treba postaviti deo GPošto je jedna strana furnirana, deo G se na deo T postavlja tiplamaNow the part G should be placedBecause the upper side of G is veneered, Part G ( the top of the box ) is set on part T with dowels.
