40966 -
627
Sve objavljeno od Zen Mod
Posted na BIg DiyA, kao i obicno mrzi me da kucam opet Finally, Plethora of Pinjatas, origin of P series of amps These (P) being more or less derivatives of my recent M2 derivatives ........and you know them , so no need to go in detail So, active FE instead of buffer+autoformer Fe; biasing mech being more or less same (current sense in rails), only - with help of current mirrors, being sorta flipped upside down, vs. previous optocoupler based one even if optocoupler based biasing is moe than good, believe me, this one is even better ...... in anything you can remember to ask about Iq and Offset stability is bespoke, in any domain I can think of - time, temperature, rails change ( mains fluctuation), no even slightest pops during Power On and Power Off everything to embrace Square Law OS (aha, this one being origin, even if its bigger brother - Babelfish XA252 been made first) OK, straight MOS being real Plethora of Pinjatas ....... (is it Mini Babelfish XA252?) SET P being then same pcb with twist - upper mosfet in Schade arrangement (is it Mini Babelfish XA252 SET ?) pretty close to point where I can't even follow my self, go figure 'nuff babbling, some usual pics schm is cumulative; down will post separate ones
editovah post gore, sa links
to ti je skolska razlika izmedju pojacala sa dominantnim 3-im harmonikom i previse stepena pojacanja (sto ubija zilu) i jednostavnog [pola+jedan+jedan+pola]-stepenog pojacala koje sad slusas ..... a koje ima dominantan 2-gi harmonik , ko ceve SE https://sound-au.com/tcaas/hiraga1f.htm https://sound-au.com/tcaas/hiraga.htm
zato i rekoh soft start modul
otvori posebnu temu pa turaj slike dok pravis mozse, ne daj Boze, desi da neko kaze i neku pametnu ono, niko se naucen nije rodio, nije sramota pitati sramota je pravit se pametan , pa se qurobecati posle a ne biti svestan svoje gluposti been there, done that .....
nikad ne smes obe strane srafa na toroidu da vezes, da imaju elektricni kontakt eve ti slika, sve jasno snalazi se, ako nema drugi nacin, resavaj elektricki izolovano pricvrscenje
obavezno svaki trafo svoj mrezni osigurac ako hoces IEC integrisan sa prekidacem i osiguracem ..... tu je samo mali prekidac moguc pa bih to preskocio na tvom mestu stavi posten velik rocker prekidac, ako hoces da traje, i kucista osiguraca levo i desno od IEC svaki trafo poseban soft start - mozes NTC 10R ranga CL60 ili uzimaj soft start pcbs - imas kod Trafco ostalo nemam zamerke
jbte slike su ti bas informativne dje fuses ( posebno za svaki trafo) dje IEC (ajd reko si bice) dje switch koja snaga trafoji i kolki capsovi, da znamo da li treba softstart dje grecovi ene etc
aha i ja tisucu puta krenem da upotrebim tu sentencu iz zeze ..... al se onda obsetim da je ista tuzna do bola ......
kanal koji pratim redovno ( ne postuje svaki dan, pa se moze) cika , inace bogatun do koske, ali i dalje prizeman i veoma normalan covek elem, danasnji video.... "Silverstone Auctions next sale is their specialist Ferrari auction, held at Sywell Aerodrome in association with the Ferrari's owners' Club of Great Britain" eeeee, vidis ti to .... sta ti je znacenje kriticne mase - elem kad se predje kriticna masa u broju stanovnika, broju godina sa predjenom kriticnom masom novca u opticaju ...... pa imaju i Ferrari's owners' Club of Whatever Country" jos jedan podsetnik, da se uzmemo u pamet, koliko nas je malo i koliko razvlacimo kolacic koji ionako na jedvite jade ispekosmo gde bi mi bili , da nam je pameti da svako radi svoj posao ..... izmedju ostalog, nismo u stanju ni zakone da prepisemo i primenjujemo ih kako treba
kod ZM nema vs. sve se to u stomaku pomesa ZM, World Greatest fan of: FG,FZ, JT, WF, Crusaders, SD, PdL, Magma, ABB, Cream, JH, LC, TM, KK, DL, EC*, ..... ...... ....... nikad ne podcenjuj enormity of skupljacki karakter
ZM, World Greatest Crusaders fan
ja reko nema dzaba ni kod baba msm, ima dzaba ako kopas pa iskopas edit: ne znam kako mi se provuce typo - nije 2 para na raspolaganju nego jedan par
ZM, World Greatest SD fan
e kuj hoce da pravi PCM63, imam ja da prodam, P jeftino, 4 kom msm ono, bing kako brat, ni kod babe nema dzabe
znam sta je soška za ninjino oružje, kad sleti na pasulj
Trenutno na sajtu 7 članova, 0 Skrivenih, 257 Gosta (Pogledaj celu listu)
Ukupan broj tema454k
