Zen Mod
Administrator
Sve objavljeno od Zen Mod
  1. C4 - u paralelu zeneru - smanji na 1uF i vidi kako se ponasa pri ukljucenjuSipi ti je rekao za toplotu - 20s je vecnost ; jedino Bata Zivotinja ima volju vecu od toga ; Chuk Noris je mala beba za njega
  2. Google , Yahoo i ja ......
  3. I don't care too much for Rdc this time , 'cause Iq will be in range of 1A - plenty for 16R spks , and good enough for (servo) concept proving one day - I have those (previously discussed ) biguns , and they need re-winding
  4. I'll give ya picture tomorrowpretty big - core size will not be an issue , and sections are perfectly matched
  5. I'll try it these dayz in Ikebana fashion that 0,9H/4R4 per leg critter is ancient isolation xformer , on proper C core , scavenged form old Grundig TV set ; most important , besides fact that I have it and it's adequate is - that another one will be tossed in my direction very soon perfect for Little Donut
  6. @Magura soon - I don't have enough time drawing all these backofnapkin projects for greedy boyz :)I'll try soon li'l donutya likee sketchs ?
  7. vidi se na pocetku teme - ima se komplet velki' i ima se komplet mali' SJEPovakomplet mali ce bude neki choke amp , a komplet veliki ce bude proper big amp - najverovatnije Bbaelfish J2jos samo da nabavim par malcice ofucanih Papinih original hladnjaka , pa da pravim original Babelfish kuteju
  8. medium donut sketchMetaldanske - is 0,9H/4R2 per leg good enough for test with smaller SS's , at 1A per leg Iq ?intended as killer amp for my 16R spks ?
  9. zahvaljujem kolezi Sipiju za asocijativnost
  10. Zen Mod
    Babelfish J
    sto veci bias - bolje svira stavi duplo hladnjake struja kroz Aleph CCS i jeste definisana konstantom Vbe malog tranzistora ; on se trudi da drzi napon od 0,6 do 0,65V izmedju B i E , tako sto "clampuje" gate mosfeta i diriguje mu time koliko struje ce da pusta ...... da bi na tom source otporu bio tacno Vbe napon dakle - kad nema onog nedostajuceg (na KK semi) otpora za grubu korekciju biasa - samo source otpor definise struju sa 0R47bi imao I=U/R ........... I= 0V63/0R47 = 1,34A postoje i optpori od 0,39 ........ kao iparalelne kombinacije , pa mozes sam da programiras mirnu struju
  11. kako god okrenes - sp300b profitira ....
  12. Zen Mod
    Babelfish J
    sto se tice termickog sprezanja - sad vidim i taj I deo na hladnjaku - dovoljno da ih priblizis jedan do drugog i da na njih zajedno zavrnes komad Al debljine 4-5mm
  13. Zen Mod
    Babelfish J
    onda stavi na dva hladnjaka- za DC offset pomaze ako su termicki spregnuti - stavis neki AL ili Cu chunk da povezuje oba hladnjaka , te na njega montiras mosfetepad napona na source otporu , onda Kirhof I=U/R
  14. li'l donut sketch - with diff servojust for Metal'kid's eyes
  15. dodje SUSY do izrazaja , pa malo manje imaju uticaja oni Jumini sprezni kondovi ......
  16. e tacno cu da se o'cepim i odem Madjaronima ..... bar cu onda uzimati Sonide u Prestonici
  17. Zen Mod
    Babelfish J
    stojeci na tom VHS-u i nema dotok vazduha od dole kako treba ;jes da su rebra slobodna , ali si mu zablokirao dovod vazduha sa jedne strane ;da se nalazi namontiran na kutiji - vazduh bi dolazio iz tog pravca ispod kutije i hladnjak bi bio ipak malo hladnijidaj nesto podataka - napon napajanja , mirna struja ;mozes dati i podatke - dimenzije hladnjaka , pa da pogledimo u nekom katalogu , mada je hand test najmerodavnijiinace - nije to bas tako scorching hot - najbitnije je da kad ga bude skutijao - napravis donji i gornji poklopac dovoljo provetrivim - da se ne prze elkovi i trafo bespotrebno
  18. zaboravio si najvazniji izvadak - 'oenta je u cevama i travojima , 'bes ti te tvoje osfete jofete i ostale fete - to nit cujes kako zuji , nit vidis kako svekli , nit svira kako treba
  19. nije on to hteo - htelo ga ....... il' sto bi mi rekli kad smo bili klinci , pa neko ubaci bez koske - usralo ga
  20. Zen Mod
    sony cd
    kondove moras zadrzati (2V5 na izlazu DAC-a) . ali mozes staviti malecne - 100n je dosta da - trimer je za DC offset
  21. Zen Mod
    sony cd
    eve ti ovo onda - ako gain nije problem i ako ni impedansa sledeceg stepena nije prevelik problem i bolje da je pot sto vise odvrnutdakle - izbacis pot iz predmetne seme i to je tonapone za napajanje ukradi iz CD- ja od gdegod , po mogucstvu sa sirovog neregulisanog , pa regulisi s onim za sta imas voljeR104 i R204 - umesto nacrtanih 1K stavi 10-33 oma naponi napajanja sve od +/-9 do +/-18V
  22. Zen Mod
    sony cd
    tesko je reci ; pogle dna signal sa osciloskopom bi rekao koliko i da li treba filter niskog propusta ( imas li sad suma ?) , kao i koji test da se utvrdi izlazna otpornost samog DAC-a gledano na pojacanje prvog stepena ( prvi OP posle daca) trebalo bi ti 4-5x pojacanja da se vratis na fabricki nivo ; sledeci stepen je NP filter od 12db/oct ....... idealno bi bilo ubaciti ili nesto kao sto je Sloba upravo ubacio u Primare ( gde biimao i mogucnost balansiranog izlaza ) ili takav isti sklop , ali samo sa jednom buffer stranom - za nebalansiran izlaz u svakom slucaju - cak i obicni buffer bi uradio stvar , i to bi sigurno sviralo bolje dakle - ako nisi u frci sa nivoom suma u ovom momentu , moj savet bi bio da se prijavis Sipiju i pitas ga za adekvatnu kolicinu cijenjenih BF862 kojih on ima za izvoz , pa valjda i treba koji da ustupi po cijeni koja je naravno sitnica on ce moci i da ti prilozi vec probanu semu buffer stage ili sl. sa pomenutim tronoznim bubama cak bi i nas zajednicki Jfet BOZ stage sa J310 , pravilno dimenzionisan - predstavljao poboljsanje u odnosu na sadasnju situaciju - golim DAC dupetom u svet .....
  23. @sipito sve stoji - ako maris za linearnost a ako ne maris - stoji i dalje ...... al' ne maris
