Zen Mod
Administrator
Sve objavljeno od Zen Mod
  1. sotono pozajmi zenin laptop
  2. Zen Mod
    Mali shunt
    paralelni regulator
  3. sta ce ti 5qmm ?kolika je impedansa onih Cabassova ?ne racuna se tankoca licni , nego celog provodnika u jednoj dimenziji
  4. how's ..... " I'm engim .... I'm emgin ....... I'm emgem..... I'm good in math ! "anyway - that's all ZM knows in electronic .....
  5. with all 3 - 4K7 , you'll have 3,3mA through both sides
  6. it's either some special Kirchoff , or I'm not following you ;in any case - I'm not following someone isn't unusual at all
  7. extremno tanko je ono sto je bitnoe - to extremno tanko moze imati zeljenu kvadraturu ako je u obliku folije 0,1mm x 35mm daje 3,5qmm itd probati , pa komentarisati
  8. put all 3 same in value - 4K7 plain MF resistors still in green area , regarding dissipation disclaimer : I have 0V65 where needed - with BC556C , with 12K resistors
  9. (((24V-1V3)+24V) / ((10K II 1K ) + 10K ) = 4,28mA overall
  10. I'm too :sarcastic_hand:and - what Kirchoff sez - what's current through R70 now ?
  11. zica menja zvuk . to je definitivno - ali samo tamo gde ostali parametri nisu optimizovani - mislim prvenstveno na impedanse izuzetak je naravno paucina za zvucnicke - kad se moze staviti gledajuci strujne zahteve - meni je zvuk uvek bolji hocu reci - gde god mozes - stavi 0.1 mm precnik
  12. Q26 and Q28 - each one is conducting ~1,3mAthere is no need for more than 5mA through eachso - Slobo - you can substitute all 12K with - say - 4K7and - replace both Q26 & Q27 ..... that will cost ya a fortune
  13. zakljucak - tanki su najbolji
  14. a di drugde do u ponajboljim serbianskim ajzlogcima ?koji vode do najzabudzenijih garaza i podruma lijepe nase ...... :buehehe:a sva roba - origin - okolina mariaterezianskih i vaterlandskih kontejnera
  15. yes , indeed .......... certainly ...... why not ........ how else ..........
  16. to samo znaci da se ne bavis strukom dovoljno dugo - kad to nisi video
  17. :connie_nutzo:taking in account that just 6 pairs are made ....... and that's probably all what will be made:cheers:
  18. yup - nomenclature made by mistake of pcb maker:rofl:
  19. yup stari dobri Quad 405ja nikako da to odradim i stavim na ulazne terminale na samim zvucnicima bas me briga za amp ........
  20. najnoviji ZM's OB :sarcastic_hand:zahvalnost drugu Steintrikes sto je izvrsio preuzimanje , kao i fotkanje istihne zna se koji je ludji ....... ja sto ga terah da ode po to , il' on sto me poslusao da mi ucini uslugu :Viannen_loungelizard:bass je 10" , onda se vec znaju dimenzije ostalogda predupredim potpitanje te vrste - jeste - slikan je samo jedan komad od para
  21. http://www.diyaudio....-spavleski.html
  22. I like that ........ sp300b & ZM ........ Mythbusters and - one member on Big Diya
  23. :buehehe:you have doubts ? and even more , at least with my parts/outputs/gate resistorsI have some notes in my workshop , along with CRO screenshots , but they're completely boring - nothing to write home about . whatever it needs ; these Jfets are trickier to set , comparing to big ole mosfets , due to smaller Ugs .... and wild xconductance ; but - as I said before - nothing to worry aboutplain boring amp - to make
  24. @ skydog ..... try this way - many information in original thread http://translate.goo...inster-royal%2F you can also choose translation to Russian anyway - you can contact FFL also via board personal message thingy http://www.diyaudio....odule=messaging that's upper right corner on each page , just right of your name
  • Trenutno na sajtu   1 član, 0 Skrivenih, 130 Gosta (Pogledaj celu listu)
    454k
    DusanJovanovic
    DusanJovanovic
