Zen Mod
Administrator
Sve objavljeno od Zen Mod
  1. samo ti radi sve dok uzivas u pravljenju - nista nije uzalud ni najludja ideja koja propadne , a kamoli projekat koji je ipak dokazan
  2. nope ;feel free to experiment with ratio of these resistors ...... meaning ratio of lower vs. uppertake care to re-check both bias and offset after changeeverything is OK , as long you have overall sum of 1R - and at least 1A5 across them - optocoupler is functional
  3. Genije - ako kupis drugi trafo - sky is the limits ovim koji sad imas ostaje ti da ranis svinje i ne diras nistadaklem - odluci se kojim ces putem - ili da ti ja crtam sve , pa da ti onda kupis trafo ........ ili da se drzimo ovoga sto vec imas ?ako ostaje ovaj koji imas - onda vazi sema koju sam postovao - i nemas nimalo naponskog lufta za bilo kakav regNB - potreba za regom je smanjena zato sto imas CCS kao radnni otpor u gain stageprethodno pitanje zanemarujem ; postoji razlog zasto je tamo stavljen P kanalni mosfet u CCS
  4. :air_kiss:idi spavaj
  5. Zen Mod
    Audio CD
    sretno ti bilo sa windows mountom
  6. matter of nomenclatureI'm taking it as - biasing goes from input LTP ......... other setting is chasing offset
  7. Zen Mod
    Audio CD
    neki od virtual drive programaja obicno imam instaliran alcohol 120mount image , pa onda radi sta hoces
  8. BIAS SCHMIAS:you should decrease value of R35 to reduce bias ( if R12 is already on minimal )then - if you are having positive offset and you can't decrease it - decrease R26 ( if R25 is already on minimum)easy peasy , isn't it .....
  9. you can try to change ratio of these resistors between lower and upper SS outputsnow they're 0R5 and 0R5increase upper/decrease lower (in same amount) - more local degeneration of upper SS - comparing to output node - where is - important - tied feedback netincrease lower/decrease upper (in same amount) - less local degenaration .......dunno what results - sound wise - can be ......
  10. @sp300b: why should that be possible ? it is , but I can't see why - put either power resistor from output to negative PSU leg , or CCS that way - with introducing additional current path - you can diss-balance currents through output pair
  11. nedostaje mi bar jos 130V anodnog napona - da bi imao i DC spregu izmedju gain stage i folovera , i da bi bilo sve sa 12BH7jednostavno - njene k-ke zahtevaju naponaaaaaaaaaa
  12. seems that your thinking apparatus is these dayz in ZM mode :rofl:we must include path where we can direct 900mA of differencebut - not in speaker , please :rofl:so - this isn't modern Pass SUSY amp , with introduced additional SE bias
  13. you have diff input stage to servo thatno difference in thatjust one thing - I'm pretty satisfied with Babelfish J2 as is now ........ just need to make it in box , one day .....
  14. aha .....
  15. nope - he meant changing value(s) of middle resistors in output stagewe have 2x0R5 in series ......changing them - you are changing modulation of upper half of totem poleit is impossible to have unequal currents through output vertical . except if you make another path for equalizing currents in that pole
  16. ostatak sema je drndolja ispravljac , filter , par otpornika , kond , darlington , par otpornika , kond
  17. tnx to Sipi - editovao sam vel'ku semu - imao sam duplo vise LED-ovki nego sto trebamislim na 10V ( sto je 5x1V93) a nacrtam 10 komata
  18. take money and run type
  19. onda OK ........... 1. ne moze da skodi - manje ringing-a oko ivica2. genralno neces primetiti razliku u toj klasi drivera3.da - razlog isti kao pod 14. cena , lakoca nabavke5. moze biti samo bolje , jer povecavas stepen ukrucenosti stranica
  20. jos treba da ti nacrtam ispravljac za HT ,kao i biasovanje grejanjate timer za kasnije paljenje Quad-ovog trafoa
  21. Vlado - sp300b is interested ( and I'm asking just because he's busy all day long ) - can you make direct comparison of sound of FW J2 and your Babelfish J2 , considering all differences - you heard FW at Papa's , while you are listening yours at your place ..... we already have Tea Bag's opinion - " The BJ-2 sounds a lot like I remember the FW J2 sounding like at Burning Amp 2009 " tnx
  22. zato doslo vreme za nakurnjake to mu dodje kao snake skin buzir
  23. Zen Mod
    Audio CD
  24. Zen Mod
    Audio CD
    NEMATE VI POJMA STA JE TO IZVOR I ZVUK !
  • Trenutno na sajtu   1 član, 0 Skrivenih, 46 Gosta (Pogledaj celu listu)
    451.8k
    Enzo
    Enzo
