krvimozak
Sve objavljeno od krvimozak
  1.  krvimozak
    Visaton B80
    Bolje ne...
  2. Ovo nadjoh na netu. Moguce je da je drajver original i da je samo promenjeno vesanje...The SR 142/17 on the rubber surround is just an oem designation for the surround itself....it has nothing to do with a polk part number...I have no less then four 6 1/2" drivers here from 4 different manufacturers with the exact SR 142/17 designation on the rubber surround ( I can see Eton...Vifa...Polk....and the 4th I cant remember the raw drivers name...but its my in wall's from ACI/Audio Concepts ) Looking for correlation in Vifa's pdf's for the drivers, I have some of their older 6 1/2" woofers that use the 17W designation in the part number and they happen to have an OD of 170mm. Their new 7 inch woofers have 18W in the part number and they happen to be 180mm OD. I also have some 5" vifa's in my ACI AV-1's....their rubber surrounds read SR 110/14 ......their OD is 140mm So it looks like the 17 is just showing that the rubber surround flange fits/glues onto a frame of 170mm +/- The preceding number 142 happens to equal 5.6 inches.....I grabbed my caliper and just measured the OD of the rubber surround only ...not including the flange part that glues to the frame....it was 5.6 inches exactly So the surround itself has an exact OD of 142mm......and with the generously wide flat glueable area of the surround past that 142mm....it allows it to be used on frames measuring around 170mm...probably why they dropped the zero because with that wide glueable area it would work just fine with a 167mm frame or even a 173mm frame. Looks like they didnt want to label/limit it to just 170...so they marked it as 17. S R 142 / 17 Surround Rubber Surround OD 142mm 170mm frames +/-
  3.  krvimozak
    Visaton B80
    Mali oftopic - zasto je neko dodavao visokotonca na ovaj drajver? Po frekventnoj karakteristici u specifikaciji on ide skoro do 20KHz, i mnogo je bolje (valjda?) dokrpiti ga u basovima jer mu tu fale tri oktave.
  4. Slusao sam nekada HB1 sa Hafler ampom i preampom. To je sviralo do OO. Za cenu koju trazis, ovi zvucnici su kao poklonjeni (poranio Deda mraz ove godine). HB1 neocekivano malo zaostaje za HB3 modelom a HB3 je i dan danas klasa za sebe. Najtoplija preporuka...
  5. Kako i sta ne razumes? Matematika je jasna - uzeli ljudi u obzir Plankovu konstantu...
  6. Vaki sat nemas, u opkladu. Ne znam kolko novci traze za njega
  7. Nekad davno me pitala devojka sta da mi kupi za rodjendan. "Kolko para mislis da potrosis?" pitam je ja. "Mislim da ti kupim nesto sto vredi oko 50 maraka.""Odlicno, kupi mi onda 50 maraka!"I tako, ja dobijem 50dm na poklon.U prevodu, uzmi joj 100 evrona pa kupi sta ti dusa zeli...
  8. Ovo niko ziv vise ne slusa http://www.youtube.com/watch?v=P-tyETi_U1g
  9. Dali si naslov teme skuckao na brzinu?
  10. Zaboravio si da nam kazes glavnu stvar - da li si koristio usmerene kablove...
  11. Ovaj komentar nije vic - stvarno se desilo samo sam izmenio ime iz razumljivih razloga:Komandant jednog jerodroma za vikend ode na pecanje, Taman zabacio udicu, kada se pojavljuju gazele tik iznad reke. Resili piloti da malo zezaju pecarose i da preplase ribe. On besan okrece mobilni i zove dezurnog sa jerodroma:- Kakvi su vam ovi helikopteri na tri metra iznad reke?!Dezurni odgovara very cool- Slusaj bre ti, vise mi je pun qrac vas takvih sto odokativno odredjujete visinu helikoptera!- Alo, ovde Crni!- Koji Crni?- Tvoj komandant!- Upssss.....
  12. Ukratko - zna li ko neku firmu koja se bavi nanosenjem teflonske obloge na zadatu povrsinu?Pozeljno je da firma bude blizu Naisusa ali nije neophodno...Dakle, ne plastifikacija vec teflonizacija.
  13. - 'ebote onaj ko ti dade dozvolu! - Mislis da nije?
  14. Taj.
  15. Instalirao sam trial kaspersky, ocistio je desetak virusa.Trial verzija radi mesec dana.Par dana sam ga zbunio vracanjem datuma na kompu, pa mi javljao da ce da radi jos 29 dana.Medjutim, ipak razmislja. Danas ukapirao fazon...Ima li neko boju ideju, mislim, hmhm moze i na pp
  16. Uspesno sam pobio g.... na hardu i problem resen. Hvala svima na interesovanju i savetima.Moderatori se mogu osecati slobodnim da promene naziv teme i usklade ga sa korisnim uputstvima koja su data u diskusiji tako da i sira zajednica ima neke fajde od ove price.
  17. Ok, jedino sto to nije moj kompjuter pa su mi ruke malo vezane.Inace, Nod i Avast su tu po preporuci coveka koji je taj komp cistio pre 2 god od virusa.Jedini nacin da se tada skinu zivotinjke je bio da aktivira oba antivirusa.Guglao sam furaka i bujacha i google nista nije nasao.Folder bazooka sam obrisao pa mi nije palo na pamet da ga guglam.
  18. Moram li i NOD32 da deinstaliram?Na ovom kompu su i Avast i Nod istovremeno aktivni.
  • Trenutno na sajtu   4 članova, 1 Skrivenih, 149 Gosta (Pogledaj celu listu)
    453.6k
