5621 -
16
Sve objavljeno od crni.
pa onda white belt ima smisla sačekaću neko vreme da se naviknem na ovaj zvuk pa ću onda da testiram taj famozni remen
- 3408 novih odgovora
originalna krpa vs pluta? pa ja obrto ovu plutu i čujem razliku piše na jednoj strani plute this side down i ja se nasmejem i namerno tu stranu stavim gore slušam slušam i neda mi đavo mira okrenem kako treba i u neverici čujem razliku pet puta proveravao, ćerku iznervirao jer ona naravno ništa ne čuje, ali ja čujem i ubi i evo, tu stranu držim dole koji je ovo blesav hobi...stvarno smo opičeni
kakvo crno nazad...pa od kad se zanimam za gramofon, već godinama, oću-neću, pitaj ovog pitaj onog... kad ikad je bilo kad me sipi ubedačio...taman ja krenuo u priču, malo se ovde interesovao a on me odmah sasekao u stilu, koj će ti to njesra e sad nema nazad
evo šta je jedan rekao Decided to get the Michael Lim 50Hz dual-pulley upgrade for my RP6, but before installing it on my TT, I bought one Rega white reference belt Friday to replace the stock black one. I wanted to do a gradual buildup to the upgrade and see just how much of a difference it would make. My thinking being that the RP8 has dual white belts (and a fully-machined subplatter, but that's a month away for me), so this was an incremental upgrade test. So I just played Chromatics "Tick of the Clock" off their 2010 release Night Drive three times at 10 o'clock on my volume dial before swapping belts. This track has a big, bouncy bassline, is very sparse, very electro, with no vocals so I could concentrate on the mids and bass punch alone. Tech note: the white belt is thicker and much more snug in it's fit on the subplatter than the standard Rega black belt, and the stock belt was not worn, the TT is only a month old. Swapping out the belt and setting the volume again at 10 o'clock I sat back to see what, if any change there would be. Oh my. Big difference. No doubt. Instantly noticeable. Db output was louder at same volume postion. Bass and midrange were more taut, extended and had an added visceral, meaty quality to them – by about an order of magnitude. I have had an RP1, a P3-24 and now this RP6. I have never used a Rega reference belt before as an upgrade (Lim's red belts on my RP1, which while noticeable, were nothing near this), so needless to say, I can see why Rega would classify this as an "upgrade" to their TTs which don't come stock with it (RP1, RP3, RP6) vs those that do (RP8, RP10). Having tweaked my RP1 a fair bit before realizing tweaks on the lower-end Rega's only go so far, I can now say that there seems to be a much larger margin of improvement for even modest tweaks the more you go up the Rega TT ladder. I never would have though this lavel of improvement was possible with a $60 belt upgrade. Makes me wonder how much more of an improvement two will make when I install the dual pulley. I'll write more about what the white belt reveals over the next few days as I spin more LPs. –R
sve dobio...dečko je car nego, dobio sam i nekorišćeni rega white belt za koga sam čitao po netu da pravi čuda, što je meni neverovatno...bajka, trač ili istina?
stiglo... od igora kupim pluta-guma mat, a od oglašavača neplanirano pazarim i mf phono preamp. cena za gram i preamp je bila takva da nema šanse da se ne kupi...mislim da sam super prošao problem je što nemam ni jednu ploču, pa moram da idem kod burazera da vratim ono što je nekad bilo moje
koliki realno ima uticaj fono preamp na zvuk? vidim da ljudi svašta koriste, od riaa pločica do nekih lampaških čudovišta i na kp ima svašta pa sam malo u nedoumici inače, verovatno ću završiti posao sa onom regom 2 sa kp. pitao igora, on napisao opširan odgovor u korist te kupovine, moja žena pročitala i složila se
gledam stradi, gledam poslao sam igoru poruku, čekam da se javi...možda ima neki polovnjak a njegove polovnjake bi čak i moja žena kupila
jedino na sajtu i sve mi skupo ima jedan hermes na kp, traži se 900e
tako je...da se ja pitam kupio bih polovnu regu, ali kad je već takva situacija ajd da bar od novog izvučem maksimum suština mog pitanja je da li je razliaka između projecta i rege vredna tih 110e? meni se čini da nije, ali ajd da pitam
ma kakvi nezahvalno, samo ožeži to za cenu sam i ja primetio, u britaniji je skoro ista cena a kod nas razlika dobrih 100e, što nikako nije malo nekako mi je za ovaj tip gramofona normalna cena 300-400e, a već 500...mnogo brate. zbog zvučnice sve smo bliži projectu, ali ajde, što kažeš da "opipamo"
hvala stradi, puno si mi pomogao trebaće mi i neki preamp, možda riaa...čini mi se da sax hifi pravi nešto tog tipa
gledam nov rega planar 2 u one hifiju je 490e, karbonska ručica, regina zvučnica u av impulsu debut carbon sa ortofon 2m red zvučnicom je 380e, na popustu meni deluju skoro isto, ali da li je rega baš za toliko bolja? ja se izvinjavam što vas maltretiram, ali žena hoće za godišnjicu da mi kupi gramofon, ali neće ni da čuje za neki polovan, to joj je suludo za poklon mene duša boli, ali šta da radim, pare su njene ajde mi malo pomozite
hvala stradi tvoje mišljenje po pitanju gramofona inače puno cenim
video sam rega gramofone, naravno...meni se sviđaju ja na tu dasku sa tanjirom gledam kao na minimalizam koji dobro svira što je za mene umeće ne znam, teško je reći...izvor u zvuku jednog sistema učestvuje sa jedva 10ak % pa tako i gramofon nemam ja neki sistem koji dupe pomera pa sad da čujem neku svemirsku razliku između rege 1,2,3 i nekih tehniksa, lina, kuzme i šta ti ga ja znam čega skroman sistem i pripadajući gramofon koji nije kršina iz kontejnera, to je to mene ovde više zanima koliko će ovo da radi, a ne da za par meseci moram da menjam glavu, iglu...i tako to
spustio mi cenu na 290e
treba mi pomoć gramofondžija da li ovo vredi? https://www.kupujemprodajem.com/Rega-Planar-2-Ortofon-2M-Blue-41628644-oglas.htm
gledao arrival kladim se da ni autor nema pojma šta je hteo da kaže bezveze
Fotografija, foto aparati i dodatna oprema
crni. je odgovorio/la revox's temus u Muzika , Film i Fotografija
ja bih najradije neki prosumer ali čega se latim to je preskupo dok sam mislio o d3100 pojavio se d3200 i taman da se rešim kad se pojavi d3300 za sada se aparati pojavljuju na 18 meseci ali vrlo brzo će kao i mobilni, na godinu dana. ko to može da prati? inače ideja je da imam apart koji će da pravi malo kvalitetnije slike nego dosad, naročito noćne. klasična upotreba. letovanja, izleti, proslave, razna putovanja...nisam ja lovac na dobre fotke, samo uobičajena upotreba. prosumer je jako upotrebljiv, mali, lagan, a kvalitetan. međutim, skup. nešto mi se ne daje 500-600e za onaj prcvoljak ps velika je razlika u ceni objektiva 55mm i recimo 105mm da li imaš neke slike slikane jednim i drugim objektivom da vidim realnu razliku? -
crni. je odgovorio/la Mikorist's temus u Muzika , Film i Fotografija
hvala stein -
juče gledao inferno nije loš, ali ne mogu reći da se nisam malo razočarao
Trenutno na sajtu 6 članova, 0 Skrivenih, 161 Gosta (Pogledaj celu listu)
Ukupan broj tema453.5k
