47005 -
661
Sve objavljeno od Mikorist
@silentbob Ako vidis neku nelogicnost ili neke bolje vrednosti za podesavanje ili neku dopunu javi. Ili bilo ko drugi. Sve ovo menja nacin na koji peva. Odnosno kako se procesira Audio. A od toga zavisi sta DAC radi
Evo skripta koja to radi *(zadnji minimal non-free Debian preporuceno za najmanju velicinu) #!/usr/bin/env bash ## Konfiguracija minimalnog xfce4 Desktop okruženja. ## Provera za sudo/root if ! [ $(id -u) = 0 ]; then echo "Ova skripta mora da se pokrene kao sudo, probaj ponovo..." exit 1 fi #RT kernel wget -qO - https://dl.xanmod.org/archive.key | sudo gpg --dearmor -o /usr/share/keyrings/xanmod-archive-keyring.gpg echo 'deb [signed-by=/usr/share/keyrings/xanmod-archive-keyring.gpg] http://deb.xanmod.org releases main' | sudo tee /etc/apt/sources.list.d/xanmod-release.list sudo apt-get -y update && sudo apt install linux-xanmod-rt-x64v3 FILE001=$"export QT_QPA_PLATFORMTHEME=qt5ct" echo "$FILE001" > /home/$SUDO_USER/.xsessionrc chown $SUDO_USER:$SUDO_USER /home/$SUDO_USER/.xsessionrc apt install -y \ libxfce4ui-utils \ thunar \ tango-icon-theme \ thunar-archive-plugin \ xfce4-appfinder \ xfce4-panel \ xfce4-pulseaudio-plugin \ xfce4-whiskermenu-plugin \ xfce4-session \ xfce4-settings \ xfce4-terminal \ xfce4-xkb-plugin \ clipman \ mousepad \ xfce4-clipman-plugin \ xfce4-weather-plugin \ xfconf \ xfdesktop4 \ xfwm4 \ adwaita-qt \ qt5ct #Osnovne neke stvari sudo apt install -y msr-tools zram-tools insserv git piper rar unrar zip unzip filezilla sharutils uudeview mpack arj cabextract file-roller xvfb pigz wkhtmltopdf ffmpeg flameshot vlc qbittorrent genisoimage preload curl firmware-misc-nonfree libegl1-mesa libgl1-mesa-glx libgl1-mesa-dri irqbalance net-tools rsync smartmontools #Setovanje vremenske zone i vremena sudo timedatectl set-timezone Europe/Belgrade #Tacno vreme sudo date -s "$(wget -qSO- --max-redirect=0 google.com 2>&1 | grep Date: | cut -d' ' -f5-8)Z" #Tidal curl -fSL "https://github.com/Mastermindzh/tidal-hifi/releases/download/4.1.0/tidal-hifi_4.1.0_amd64.deb" -o tidal.deb sudo dpkg -i tidal.deb rm -f tidal.deb #Google Chrome curl -fSL "https://dl.google.com/linux/direct/google-chrome-stable_current_amd64.deb" -o google-chrome-stable_current_amd64.deb sudo dpkg -i google-chrome-stable_current_amd64.deb rm -f google-chrome-stable_current_amd64.deb rm -v ~/.local/share/keyrings/*.keyring #Davanje prioriteta za audio FILE01=$"@audio - rtprio 99 @audio - nice -15 @audio - memlock unlimited @audio - nofile 8192" echo "$FILE01" > /etc/security/limits.d/audio.conf #Latencija FILE02=$'DEVPATH=="/devices/virtual/misc/cpu_dma_latency", OWNER="root", GROUP="audio", MODE="0660"' echo "$FILE02" > /etc/udev/rules.d/99-cpu-dma-latency.rules #rtirq wget http://ports.ubuntu.com/pool/universe/r/rtirq/rtirq-init_20150216-2.1_all.deb sudo dpkg -i rtirq-init_20150216-2.1_all.deb rm rtirq-init_20150216-2.1_all.deb sudo systemctl enable rtirq.service #RT Kit FILE03=$"[Unit] Description=RealtimeKit Scheduling Policy Service [Service] EnvironmentFile=/etc/dbus-1/system.d/rtkit ExecStart=/usr/libexec/rtkit-daemon $RTKIT_ARGS Type=dbus BusName=org.freedesktop.RealtimeKit1 NotifyAccess=main CapabilityBoundingSet=CAP_SYS_NICE CAP_DAC_READ_SEARCH CAP_SYS_CHROOT CAP_SETGID CAP_SETUID PrivateNetwork=yes [Install] WantedBy=graphical.target" echo "$FILE03" > /lib/systemd/system/rtkit-daemon.service FILE04=$'RTKIT_ARGS="--scheduling-policy=FIFO --our-realtime-priority=89 --max-realtime-priority=88 --min-nice-level=-19 --rttime-usec-max=2000000 --users-max=100 --processes-per-user-max=1000 --threads-per-user-max=10000 --actions-burst-sec=10 --actions-per-burst-max=1000 --canary-cheep-msec=30000 --canary-watchdog-msec=60000 " ' echo "$FILE04" > /etc/dbus-1/system.d/rtkit sudo systemctl enable rtkit-daemon.service ##Konfiguracija grub echo -n " + Konfigurisem boot opcije... " if [ -f /etc/default/grub ]; then sed -i /etc/default/grub -e "s/.*GRUB_CMDLINE_LINUX_DEFAULT=.*/GRUB_CMDLINE_LINUX_DEFAULT=\"msr.allow_writes=on clocksource=hpet net.ifnames=0 iommu=soft noresume mitigations=off nmi_watchdog=0 \"/g" && update-grub echo "OK" else echo "ERROR" fi #MX Tools sudo echo 'Package: * Pin: release a=mx Pin-Priority: 100' > /etc/apt/preferences.d/mxlinux sudo echo 'deb http://mxrepo.com/mx/repo/ bullseye main non-free deb http://mxrepo.com/mx/repo bullseye ahs' > /etc/apt/sources.list.d/mxlinux.list sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys F942E0D4E1C726CD sudo apt-get -y update sudo apt-get -y upgrade sudo apt -y install mx-iso-template mx-live-usb-maker mx-remaster mx-remastercc mx-snapshot mx-tweak mx-tweak-data mx-usb-unmounter echo 'Xft.antialias: 1 Xft.autohint: 0 Xft.dpi: 96 Xft.hinting: 0 Xft.hintstyle: hintnone Xft.lcdfilter: lcddefault Xft.rgba: rgb' > /home/$SUDO_USER/.Xresources #Isključenje hibernacije sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target sudo apt-get -y update sudo apt-get -y upgrade sudo apt -y --fix-broken install sudo apt-get -y autoremove #IP filter za Torent klijent sudo mkdir -p /home/$SUDO_USER/.config/qBittorrent cd /home/$SUDO_USER/.config/qBittorrent/ curl -sS http://upd.emule-security.org/ipfilter.zip > ipfilter.zip unzip ipfilter.zip rm ipfilter.zip rm ipfilter.dat mv guarding.p2p ipfilter.dat sudo reboot I ovo je neki minimalni *(minimum) sistem za Audiofile... Ili ovako ko se nadje u crnome ekranu i ne zna sta ce dalje wget https://www.diyaudio.rs/miko.sh bash miko.sh
Optika MTS.......
UPUTSTVO Kako SnakeOil moze da se instalira na Debian - ne mora Ubuntu csplit -s snakeoil-installer-x86_64-1.2.6.sh 680 ovo ce da ga rastavi na dva fajla xx00 xx01 kad se otvori xx00 u tekst editoru DISTRO=$(identify_distro) echo " + System identified as: ${DISTRO}" ARCH=$(uname -m) if [ "${DISTRO}" == "Ubuntu" ]; then install_packages_ubuntu if [ $? -ne 0 ]; then echo ${MSGS} quit 1 Promeniti Ubuntu u Debian Ko nece da ima samo konzoni SnakeOil mora da uradi sledece ## grub echo -n " + Configuring boot options... " if [ -f /etc/default/grub ]; then MSGS=$(sed -i /etc/default/grub -e "s/.*GRUB_CMDLINE_LINUX_DEFAULT=.*/GRUB_CMDLINE_LINUX_DEFAULT=\"text clocksource=hpet 3 biosdevname=0 net.ifnames=0\"/g" && update-grub > ${OUTPUT} 2>> ${OUTPUT}) if [ $? -eq 0 ]; then echo "OK" else izmeniti da bude clocksource=hpet biosdevname=0 net.ifnames=0 Onda cemu raditi i X11 - Xfce -Kde...etc.... sacuvari sa save pa cat xx00 xx01 > snakeoil.sh i onda se lepo instalira isto kao da je Ubuntu
A evo kak se novi instalira u 4 slike...... i to je to.... svo vreme peva muzika dok se instalira....nije stucnulo uskoro iso........
Ama ovo nije uopste u sistemu. Zato ne moze da se sacuva ako se reinstalira. Neverovali ili da diya@diya:~$ sudo systemctl daemon-reload [sudo] password for diya: diya@diya:~$ sudo systemctl enable snakeoil.service Created symlink /etc/systemd/system/multi-user.target.wants/snakeoil.service → /etc/systemd/system/snakeoil.service. diya@diya:~$ sudo systemctl start snakeoil.service diya@diya:~$
Ama ovo je nevidjeno sta radi sad....Kolika je brzina...Debian minimalni... Ali propadoh da namestim da SnakeOil radi u Live Nesto se razdesi dok se kopira sa rsync
Evo jedno uputstvo dobro ovde - i ovde isto chonky stavljaju jer ima razloga A guide to setting up a Logitech Media Server on a Raspberry Pi 4. WWW.HARALDKREUZER.NET This article shows how to install a Logitech Media Server on a Raspberry Pi 4 and use Conky as a system monitor.
Ja taj LMS brate nisam ni porbao samo sam install...Ne bi ga ni stavio da nije Srecko hteo.. Ja ne koristim te programe... Sad pravim novu verziju kod koje cu isprobati - konfigurisati sve. Jedna ce da bude klot sa LMS a druga sa SnakeOil . I to ne Ubuntu nego Debian. Ne umem tako dobro da radim sa Ubuntu kao sa Debijan. Jesu jaaaako slicni ali i nisu....
diya@diya:~$ cat /proc/interrupts CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7 0: 14 0 0 0 0 0 0 0 IR-IO-APIC 2-edge timer 8: 0 0 0 0 0 0 0 0 IR-IO-APIC 8-edge rtc0 9: 0 0 0 0 0 0 0 0 IR-IO-APIC 9-fasteoi acpi 16: 0 0 0 0 19 0 0 25 IR-IO-APIC 16-fasteoi ehci_hcd:usb1 18: 0 0 0 0 5 0 0 0 IR-IO-APIC 18-fasteoi i801_smbus 23: 0 29 23 0 0 0 0 0 IR-IO-APIC 23-fasteoi ehci_hcd:usb2 24: 0 0 0 0 0 0 0 0 DMAR-MSI 0-edge dmar0 30: 0 0 0 4784704 0 0 0 0 IR-PCI-MSI 327680-edge xhci_hcd 31: 0 0 0 0 0 9206 27819 0 IR-PCI-MSI 512000-edge ahci[0000:00:1f.2] 32: 0 0 0 25 0 0 38 0 IR-PCI-MSI 3145728-edge xhci_hcd 33: 0 0 72 0 0 0 0 88679 IR-PCI-MSI 1572864-edge enp3s0 34: 0 0 0 0 0 262450 0 1764 IR-PCI-MSI 524288-edge amdgpu 35: 678 0 0 0 0 0 0 0 IR-PCI-MSI 442368-edge snd_hda_intel:card0 36: 0 815 0 0 0 0 0 0 IR-PCI-MSI 526336-edge snd_hda_intel:card1 diya@diya:~$ sudo lsusb Bus 002 Device 002: ID 8087:8000 Intel Corp. Integrated Rate Matching Hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 002: ID 2109:3431 VIA Labs, Inc. Hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 8087:8008 Intel Corp. Integrated Rate Matching Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 005: ID 20b1:2023 XMOS Ltd JLsounds Hi-Rez Audio 2.0 Bus 003 Device 003: ID 0c45:7663 Microdia USB Keyboard Bus 003 Device 002: ID 046d:c539 Logitech, Inc. USB Receiver Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub diya@diya:~$ cat /proc/asound/cards 0 [PCH ]: HDA-Intel - HDA Intel PCH HDA Intel PCH at 0xf7f10000 irq 35 1 [HDMI ]: HDA-Intel - HDA ATI HDMI HDA ATI HDMI at 0xf7e60000 irq 36 2 [J20 ]: USB-Audio - JLsounds Hi-Rez Audio 2.0 JLsounds JLsounds Hi-Rez Audio 2.0 at usb-0000:00:14.0-9, high speed Bus 003 Device 004: ID 20b1:2023 XMOS Ltd JLsounds Hi-Rez Audio 2.0 sudo /etc/init.d/rtirq restart Setting IRQ priorities: start [ehci_hcd:usb2] irq=23 pid=129 prio=95: OK. Setting IRQ priorities: start [amdgpu] irq=34 pid=279 prio=85: OK. Setting IRQ priorities: start [i801_smbus] irq=18 pid=256 prio=80: OK. Setting IRQ priorities: start [HDA-Intel] irq=35 pid=505 prio=75: OK. Setting IRQ priorities: start [HDA-Intel] irq=36 pid=500 prio=75: OK. tree /sys/bus/usb/drivers/usb/ /sys/bus/usb/drivers/usb/ ├── 1-1 -> ../../../../devices/pci0000:00/0000:00:1a.0/usb1/1-1 ├── 2-1 -> ../../../../devices/pci0000:00/0000:00:1d.0/usb2/2-1 ├── 3-5 -> ../../../../devices/pci0000:00/0000:00:14.0/usb3/3-5 ├── 3-6 -> ../../../../devices/pci0000:00/0000:00:14.0/usb3/3-6 ├── 3-9 -> ../../../../devices/pci0000:00/0000:00:14.0/usb3/3-9 ├── 5-1 -> ../../../../devices/pci0000:00/0000:00:1c.5/0000:06:00.0/usb5/5-1 ├── bind ├── uevent ├── unbind ├── usb1 -> ../../../../devices/pci0000:00/0000:00:1a.0/usb1 ├── usb2 -> ../../../../devices/pci0000:00/0000:00:1d.0/usb2 ├── usb3 -> ../../../../devices/pci0000:00/0000:00:14.0/usb3 ├── usb4 -> ../../../../devices/pci0000:00/0000:00:14.0/usb4 ├── usb5 -> ../../../../devices/pci0000:00/0000:00:1c.5/0000:06:00.0/usb5 └── usb6 -> ../../../../devices/pci0000:00/0000:00:1c.5/0000:06:00.0/usb6 RTIRQ_NAME_LIST="ehci_hcd:usb2 amdgpu i801_smbus snd" sudo /etc/init.d/rtirq status PID CLS RTPRIO NI PRI %CPU STAT COMMAND 128 FF 95 - 135 0.0 S irq/23-ehci_hcd:usb2 280 FF 85 - 125 0.1 S irq/33-amdgpu 258 FF 80 - 120 0.0 S irq/18-i801_smbus 515 FF 75 - 115 0.0 S irq/34-snd_hda_intel:card0 98 FF 50 - 90 0.0 S irq/9-acpi 127 FF 50 - 90 0.0 S irq/16-ehci_hcd:usb1 129 FF 50 - 90 0.0 S irq/8-rtc0 257 FF 50 - 90 0.0 S irq/30-xhci_hcd 260 FF 50 - 90 0.0 S irq/31-ahci[0000:00:1f.2] 13 TS - 0 19 0.0 S ksoftirqd/0 29 TS - 0 19 0.0 S ksoftirqd/1 38 TS - 0 19 0.0 S ksoftirqd/2 47 TS - 0 19 0.0 S ksoftirqd/3 56 TS - 0 19 0.0 S ksoftirqd/4 65 TS - 0 19 0.0 S ksoftirqd/5 74 TS - 0 19 0.0 S ksoftirqd/6 83 TS - 0 19 0.0 S ksoftirqd/7
Ova verzija Debijana nema uopste pulseaudio a svira. Samo ima pipewire i wireplumber - kroz bullseye-backports
Sreca pa ne radim u nuklearnom reaktoru
########################################################################### @@ -67,363 +66,3 @@ to whom shipment is restricted or prohibited by the Export Controls, or (c) anyone who is engaged in activities related to the design, development, production, or use of nuclear materials, nuclear facilities, nuclear weapons, missiles or chemical or biological weapons. - -###########################################################################
Mikorist je odgovorio/la BANAT's temus u Muzika , Film i Fotografija
