Showing content with the highest reputation on 10/01/15 u svim oblastima
  1. zeljkor
    Kraj jedne ere u JBL
    Greg Timbers je postovao sledecu vest: I was unceremoniously separated from employment by Harman following a 90 second explanation. My position was eliminated! Following an explanation of benefits, I was escorted out. The timing came as a surprise and as such, I haven't thought about my future plans. While I don't need to work financially, I need to be active and challenged so I must figure out what makes sense for me going forward. To be clear, this is not what I wanted or deserved, but I will not comment further on details until a much later date. My decision, not theirs.It was a good run and I am very pleased that I have brought so many people enjoyment with the products I have developed over the last 4 decades. Once things settle down, I hope to be more available on the forum, but I need some time to adjust.My best wishes to all you JBL fans. Treat your products well and enjoy them while you can.Best Regards,Greg Timbers Ako je ovo stvarno istina (nije hakovan profil i sl.) ovo je jako tuzno. Neke od najboljih sistema na svetu je radio ovaj sada vec cikica. Kapitalizam u svojoj najgoroj formi osvaja svet. Nadam se da ce se Greg posvetiti malo i DIY zajednici i podeliti svoje bogato iskustvo.
  2. danaske bio do Severca. berza radi, ali kafana ne radi jebi ga. promenio se gazda pa jos sve ne funkcionise kako treba. uzeo 6P6S (ruske 6V6), 5C3S (ruske 5U4G) i 6N8S (ruske 6SN7) i jos neke razne ruske uljne kondove. upoznao se sa Maretom (Mamlaz na forumu). nismo mnogo naglabali, jer je zurio za S. Palanku. ali ovih dana cu za Smederevo do cika-Bojana, pa ce da organizujemo vidjenje. na slici Ivailo (levo) i cika-Brka (desno), sa punom kesom 6P6S (ruske 6V6). Mare se ne vidi jer je slikao.
  3. bata bane
    RS1003 amp
    evo i po koje slikice Ono sto svetli, to je lan-pa
  4. ab
    Sav Taj Jazz !
    Nesto Vas je sve uspavala ova kisa...rek'o da ozivim temu. Pozdrav svima.
  • Trenutno na sajtu   0 članova, 1 Skrivenih, 1637 Gosta (Pogledaj celu listu)
