Obavezno stivo za prouciti - JBL Technical Note
zeljkor
Choosing J B L Low Frequency TransducersJBL Technical Note - Vol.1, No.3A.pdfCharacteristics of High-Frequency Compression DriversJBL Technical Note - Vol.1, No.8.pdfDistortion and Power Compression in Low-frequency TransducersJBL Technical Note - Vol.1, No.9.pdfVented Gap CoolingTM in Low Frequency TransducersJBL Technical Note - Vol.1, No.18.pdfJBL’s New Optimized ApertureTM Horns and Low Distortion DriversJBL Technical Note - Vol.1, No.21.pdfJBL's New Super Vented GapTM Maximum Output Low Frequency TransducersJBL Technical Note - Vol.1, No.22.pdfJBL's New Maximum Output, Midrange/Low-Frequency TransducersJBL Technical Note - Vol.1, No.24.pdfCone Midrange Compression Drivers (CMCD)JBL Technical Note - Vol.1, No.30.pdfProgressive TransitionTM (PT) WaveguidesJBL Technical Note - Vol.1, No.31.pdfJBL's Differential Drive® TransducersJBL Technical Note - Vol.1, No.33.pdf
Ovo su po meni veoma vazni materijali kojih ima na netu ali je dobro da se ovde sacuva. Od osnova pa do tri , cetiri zadnja dokumenta koja opisuju neka nova saznanja.
  • Odgovora 31
U sustini same JBL planove za JBL 4355. Ovo su genericki dokumenti o samim jedinicama , novim saznanjima. Zanimljiv document je i 3A zasto sto opisije uticaj polozaja kalema u magnentom polju , oblik membrane i vesanja. Onda nove jedinice koje imaju kratku internu hornu sto je po meni revolucija u razmisljanju, pojava waveguide , danas posebno Image Control za koji na zalost nema dokumentacije, dual diferencijalne jedinice itd.
Patent Harmana (JBL) za novi D2430K. Revolucija u ring radiator jedinicama. Koristi se u novom M2 studio monitoru.
'bo i' otac !
tu je i AMT i slot loading i ..... sve ........
