zeljkor Napisano Novembar 3, 2013 Share #1 Napisano Novembar 3, 2013 Choosing J B L Low Frequency TransducersJBL Technical Note - Vol.1, No.3A.pdfCharacteristics of High-Frequency Compression DriversJBL Technical Note - Vol.1, No.8.pdfDistortion and Power Compression in Low-frequency TransducersJBL Technical Note - Vol.1, No.9.pdfVented Gap CoolingTM in Low Frequency TransducersJBL Technical Note - Vol.1, No.18.pdfJBL’s New Optimized ApertureTM Horns and Low Distortion DriversJBL Technical Note - Vol.1, No.21.pdfJBL's New Super Vented GapTM Maximum Output Low Frequency TransducersJBL Technical Note - Vol.1, No.22.pdfJBL's New Maximum Output, Midrange/Low-Frequency TransducersJBL Technical Note - Vol.1, No.24.pdfCone Midrange Compression Drivers (CMCD)JBL Technical Note - Vol.1, No.30.pdfProgressive TransitionTM (PT) WaveguidesJBL Technical Note - Vol.1, No.31.pdfJBL's Differential Drive® TransducersJBL Technical Note - Vol.1, No.33.pdf Ovo su po meni veoma vazni materijali kojih ima na netu ali je dobro da se ovde sacuva. Od osnova pa do tri , cetiri zadnja dokumenta koja opisuju neka nova saznanja. Link to comment Podeli na ovim sajtovima More sharing options...
zeljkor Napisano Novembar 3, 2013 Autor Share #2 Napisano Novembar 3, 2013 Verujem da ce broj 31 biti posebno zanimljiv. Link to comment Podeli na ovim sajtovima More sharing options...
ZZZ Napisano Novembar 3, 2013 Share #3 Napisano Novembar 3, 2013 Hvala na PDFovima jesi nešto od toga koristio pri izradi tvojih kabineta? tonko je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
zeljkor Napisano Novembar 3, 2013 Autor Share #4 Napisano Novembar 3, 2013 U sustini same JBL planove za JBL 4355. Ovo su genericki dokumenti o samim jedinicama , novim saznanjima. Zanimljiv document je i 3A zasto sto opisije uticaj polozaja kalema u magnentom polju , oblik membrane i vesanja. Onda nove jedinice koje imaju kratku internu hornu sto je po meni revolucija u razmisljanju, pojava waveguide , danas posebno Image Control za koji na zalost nema dokumentacije, dual diferencijalne jedinice itd. Link to comment Podeli na ovim sajtovima More sharing options...
ZZZ Napisano Novembar 3, 2013 Share #5 Napisano Novembar 3, 2013 Pa da Link to comment Podeli na ovim sajtovima More sharing options...
zeljkor Napisano Novembar 3, 2013 Autor Share #6 Napisano Novembar 3, 2013 Patent Harmana (JBL) za novi D2430K. Revolucija u ring radiator jedinicama. Koristi se u novom M2 studio monitoru. US8280091.pdf Link to comment Podeli na ovim sajtovima More sharing options...
Zvu Napisano Novembar 3, 2013 Share #7 Napisano Novembar 3, 2013 Imam sve ove pdf-ove u svom "technical notes" folderu ali dobro je podsetiti se da ih imam Hvala Željko Link to comment Podeli na ovim sajtovima More sharing options...
zeljkor Napisano Novembar 3, 2013 Autor Share #8 Napisano Novembar 3, 2013 Materijale sam postavio da ljudi koji nisu toliko u materiji imaju dobro stivo. Mnoga pitanja koja se cesto postavljaju su ovde pokrivena. Link to comment Podeli na ovim sajtovima More sharing options...
Zvu Napisano Novembar 3, 2013 Share #9 Napisano Novembar 3, 2013 Znam. Samo sam se sad podsetio koliko mi je ovoga propalo kad mi je umro hard disk pre nekoliko meseci. Brdo ovakvih PDFova i knjiga Link to comment Podeli na ovim sajtovima More sharing options...
zeljkor Napisano Novembar 3, 2013 Autor Share #10 Napisano Novembar 3, 2013 Jos jedan vazan. Note 12c. Polaritet JBL jedinica. Nije crvena uvek plus Ovde je to dobro objasnjeno. JBL_TechNoteN1V12C_v5.pdf Link to comment Podeli na ovim sajtovima More sharing options...
zeljkor Napisano Novembar 4, 2013 Autor Share #11 Napisano Novembar 4, 2013 Dynamic linearity and power compression in moving coil loudspeakers JBL - Dynamic Linearity and Power Compression in Moving-Coil Loudspeakers (Mark R. Gander - JBL) (1984).pdf Link to comment Podeli na ovim sajtovima More sharing options...
zeljkor Napisano Novembar 4, 2013 Autor Share #12 Napisano Novembar 4, 2013 JBL - Improvements in Monitor Loudspeaker Systems. Pisale same legende audio sveta! JBL - Improvements in Monitor Loudspeaker Systems (Smith, Keele, Eargle) (1983).pdf Link to comment Podeli na ovim sajtovima More sharing options...
zeljkor Napisano Novembar 4, 2013 Autor Share #13 Napisano Novembar 4, 2013 Greg Timbers o vaznoj temi - JBL - The Great Alnico-Ferrite Debate JBL - The Great Alnico-Ferrite Debat.pdf Link to comment Podeli na ovim sajtovima More sharing options...
Zen Mod Napisano Novembar 4, 2013 Share #14 Napisano Novembar 4, 2013 Patent Harmana (JBL) za novi D2430K. Revolucija u ring radiator jedinicama. Koristi se u novom M2 studio monitoru. 'bo i' otac ! tu je i AMT i slot loading i ..... sve ........ Link to comment Podeli na ovim sajtovima More sharing options...
zeljkor Napisano Novembar 4, 2013 Autor Share #15 Napisano Novembar 4, 2013 Cudo od zvucne jedinice 'bo i' otac ! tu je i AMT i slot loading i ..... sve ........ Link to comment Podeli na ovim sajtovima More sharing options...
ivica Napisano Novembar 6, 2013 Share #16 Napisano Novembar 6, 2013 Mala dopuna i za ostale veoma korisne informacije: http://www.cieri.net/Documenti/JBL/FileList.html pozdrav ivica Link to comment Podeli na ovim sajtovima More sharing options...
Zen Mod Napisano Novembar 6, 2013 Share #17 Napisano Novembar 6, 2013 DownThemAll! Link to comment Podeli na ovim sajtovima More sharing options...
zeljkor Napisano Novembar 6, 2013 Autor Share #18 Napisano Novembar 6, 2013 Znam za taj link , ja sam stavio ono sto je po meni "must". Sa druge strane ako taj link otegne papke da imamo kod nas. Link to comment Podeli na ovim sajtovima More sharing options...
Zen Mod Napisano Novembar 6, 2013 Share #19 Napisano Novembar 6, 2013 WinHTTrack radi upravo ....... Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano Novembar 7, 2013 Share #20 Napisano Novembar 7, 2013 WinHTTrack radi upravo ....... bice uskoro sve na diyaudio.rs Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano Novembar 7, 2013 Share #21 Napisano Novembar 7, 2013 ovde:http://www.diyaudio.rs/JBL/jos se skida. bice jedno giga pdf-ova Link to comment Podeli na ovim sajtovima More sharing options...
Zvu Napisano Novembar 7, 2013 Share #22 Napisano Novembar 7, 2013 To Mikoslave Link to comment Podeli na ovim sajtovima More sharing options...
