Zen Mod Napisano Septembar 5, 2022 #1 Napisano Septembar 5, 2022 https://www.diyaudio.com/community/threads/steeplejack-or-how-f8-met-mighty-babelfish-m25-schade.389982/#post-7115723 shonne, Zbora and LightMatic je reagovao/la na ovo 2 1
Zen Mod Napisano Septembar 5, 2022 Autor #2 Napisano Septembar 5, 2022 shonne, ziki, zerowaf and 3 ostalih je reagovao/la na ovo 5 1
Zen Mod Napisano Septembar 6, 2022 Autor #3 Napisano Septembar 6, 2022 shonne and LightMatic je reagovao/la na ovo 2
Zen Mod Napisano Septembar 6, 2022 Autor #5 Napisano Septembar 6, 2022 napisah tamo shonne je reagovao/la na ovo 1
shonne Napisano Septembar 7, 2022 #7 Napisano Septembar 7, 2022 Gde ga nadje 😁 Njega nemam u kolekciju. 😛
zerowaf Napisano Septembar 7, 2022 #8 Napisano Septembar 7, 2022 pre 14 časa, shonne reče Malo o zvuku? 🤗 pre 14 časa, Zen Mod reče napisah tamo Nije mi se jos Ludef usvirao kako treba, a sad trebam Mad Hattera...... Pa ima li kraja ovom ludililu???
Zen Mod Napisano Septembar 7, 2022 Autor #9 Napisano Septembar 7, 2022 1 hour ago, zerowaf said: ....... Pa ima li kraja ovom ludililu??? Nema Eo bas sad zavrsio merenja Steeplejack SET, to mu dodje Poor Men's Scryer u je zerowaf and LightMatic je reagovao/la na ovo 1 1
Zen Mod Napisano Septembar 7, 2022 Autor #10 Napisano Septembar 7, 2022 ha! just finished conversion to Steeplejack SET (Schaded Enhanced Thingie), meaning that upper mosfet is connected in Schade arrangement all measurements done, it's already singing, and as I could expect, everything is slightly more in the face, while I can still hear Miles thinking how it could be better that I didn't wiped clean damn spectacles prior to gig, probably lesser trouble with stage reflectors ZM is Happy Camper, Steeplejack SET is Poor Men's Scryer ...... even for this one 300B Fetishists can eat my liver
zerowaf Napisano Septembar 7, 2022 #11 Napisano Septembar 7, 2022 pre 4 minuta, Zen Mod reče all measurements done, it's already singing, and as I could expect, everything is slightly more in the face, while I can still hear Miles thinking how it could be better that I didn't wiped clean damn spectacles prior to gig, probably lesser trouble with stage reflectors E tako treba! Nece se nista prodati zbog dobrog grafikona. To je bilo sedamdesetih. Danas raja trazi veselo! Hoce prorocanstvo u granulama, da ako uzmu ovo pojacalo, zicu, lampu, kondenzator, promuckaju ga sa onim zvucnicima, osiguracem, osvjezivacem prostora i ako to naprave neka se paze da ih Charles Mingus ne bi aperkatom izuo iz cipela ako suskaju sa bombonima dok on svira. Ako gledaju film i imaju suraund sastavljen na ovaj nacin neka se prije gledanja Smauga namazu Coppertonom.... da ne izgore! LightMatic je reagovao/la na ovo 1
Zen Mod Napisano Septembar 7, 2022 Autor #12 Napisano Septembar 7, 2022 ako naputci izlaze iz ovu Butigu, onda namesto Coppertona sleduje uporaba Jutropada
zerowaf Napisano Septembar 7, 2022 #13 Napisano Septembar 7, 2022 pre 2 minuta, Zen Mod reče Jutropad Morao sam guglati. Jbt, prvi rezultat u guglu je Vukajlija. Bojim se i pogledati sto to znaci!
Zen Mod Napisano Septembar 7, 2022 Autor #14 Napisano Septembar 7, 2022 mjok, nemaju vukajlijci pojma Jutropad je ono sto prvo pada kad ustanes ujutru, a to sigurno nije ona aktivnost za koju muski trebaju papir kad si mali, Jutropadom resavas posekotine i ogrebotine na licu mesta igranja, tvoj licni jodni preparat Beli_Ninja and LightMatic je reagovao/la na ovo 2
Zen Mod Napisano Septembar 7, 2022 Autor #15 Napisano Septembar 7, 2022 Steeplejack SET measurements starting here: https://www.diyaudio.com/community/threads/steeplejack-or-how-f8-met-mighty-babelfish-m25-schade.389982/post-7117121 all in all ........ pretty good approximation of Scryer measurements, shown (starting from post #5) here: https://www.diyaudio.com/community/threads/scryer-or-how-f8-met-mighty-sissysit.388550/post-7078135 even if I didn't stretch my self for uncomfortable task to compare Scryer and Steeplejack SET directly, gone by always giggly auditory memory, but more by general feel of ease, measure of feet tapping and Dia of headbanging circle, these two are close enough besides, pleasure being certainly enhanced with fact that I made another one, and didn't end in heap of Gray Smoke zerowaf, LightMatic and shonne je reagovao/la na ovo 1 1 1
zerowaf Napisano Septembar 7, 2022 #16 Napisano Septembar 7, 2022 Headbanging Circles Diameter, aka HCD, the measurement unit for evaluation of Hifi gear! Spojler Interesting fact: Most succesfull amp was nicknamed, and not without reason, "Headles Ken doll". That amp is out of production for obvious reasons and is forbidden by Geneva convention.
chakija Napisano Septembar 7, 2022 #17 Napisano Septembar 7, 2022 A jel mere Semi South da se turi tu neđe?
Zen Mod Napisano Septembar 7, 2022 Autor #18 Napisano Septembar 7, 2022 mere al nisam probo niti cu chakija je reagovao/la na ovo 1
chakija Napisano Septembar 7, 2022 #19 Napisano Septembar 7, 2022 I ja bi previo ovo pojačalo, al što bi kad je isto ko ovo što sad imam LightMatic je reagovao/la na ovo 1
Zen Mod Napisano Septembar 7, 2022 Autor #20 Napisano Septembar 7, 2022 ma sva su pojacala ista LightMatic je reagovao/la na ovo 1
