4528 -
54
Postovi objavljeno od Nesic
ma drugar nije imao drugu cev u bazi ... probamo kasnije i ecc88, Zenov predlogta neka je ..... ne treba ti sim za ovo ; sto se mene tice - ECC88 malo vise volim u poziciji CF , zbog vece strmine i manje Ri .s druge strane - treba ti manje napona .no - kako ti drago...... odnosno - koje cevi vec imas , a ti radi ;6SN7/12SN7/ECC82 i svi ostali derivativi pasu za to sto je simovano .i za to vazi da ti ne treba vise od -25V dole
Allen Wright http://www.vacuumstate.com/index.tpl?rubrik=8〈=2&a=%25B3%2588%258D%25B71%257DB%2526&b=734094.4795522681
Andypairo http://www.diyaudio.com/forums/tubes-valves/76602-my-version-vacuum-state-fvp5.html#post893451
Oće li ko da pojasni kako rade prikazani SLCF, kako "doterati" CCS-ove, izbor cevi, radne tačke, itd... thx.http://www.customanalogue.com/joe%27s_fvp_page.htm
Super Linear Cathode Follower (SLCF)
In his book, Allen is asked by someone whether he uses Cathode Followers. When he answers 'sometimes yes' his questioner turns his nose up. But Cathode Followers do provide the low output impedance that is often needed, especially on the main output of pre-amps. But they have sonic problems: They loose information. If you are using a good Single Ended power amp (I say 'good' as all SE amps are not created equal) or something equally revealing, then the loss is crucial.
Introducing the SLCF: An improved Cathode Follower that leaves many of it brethren behind. It is fed in a Constant Current mode and the follower element (triode) works in Constant Voltage mode due to bootstrap fitted. See Allen's book for further analysis. A 'mu' follower or SRRP could also have be considered. It seems a good idea since it overcomes short-comings in Cathode Followers but has higher output impedance.
Recent experiments show that the SLCF is sonically W*A*Y better than SRPP.
Kad pomenu SLCF, otvaram novu temua i nema se puno izbora ...... ili 2 gain stages sa EQ izmedju , ili split EQ na 2 , gde bi se islo sa dva gain stage-a (prvi GS pa pola EQ,drugi GS pa druga polovina EQ ) i SLCF na izlazu .
Odlična tema, pozdravljam Skoro upadoh i sam u ove cevne vode... ps: Dajte nešto oko line sa 6SN7
Nešto što ja radih na ovu temu. Šema je dole, radi odlično. Sipijevo rešenje je ipak elegantnije.
Ako nekom treba PDF za izradu nek se javi na PM... ili da ga postujem ovde, kako vam volja.
Poz
primetih i ja kad postavih sliku... naivaБоје садржаја кутије се слажу са бојама лемилице
update...
još par sati i finito...
mašala
ok. A3 ima 22k, ovaj drugi ima 44k. Za A5 bude malo, ovaj ima samo 10k.
Dakle, ovo ide u kutije joše večeras, a onda krećemo sa novim preampom, takođe sa ovom cevi.@Zen: Koji CCS predlažeš umesto ovog C4S, što je trenutno kod mene? NPN tranzistore?
Fala za PDF.
evo sve na stolu...
grejanje je ipak ostalo naponski regulator, probaćemo u drugoj verziji CCS. Tu je i plocica koja je zadužena za upravljanje relejima, HV PSU, choke, pločica za line deo (delovi dole, cev gore)... utp kabl kao interkonekt ukupne duzine oko 3m i nesmeta preampu da bljuje vatru ka power ampu. užas.
sledeće je ubacivanje svega ovoga u kutiju...
nismo još, treba sve ubaciti prvo u kutiju, sve je još uvek na stolu... ovaj zvuk te totalno poremeti, prodrma te celog, sve što si do sada čuo nema nikakvog smisla... ko da je iluzija u pitanju... da daa jel' se već stig'o spariti sa Zokijevim A5, il' čekate da se najpre malo usvira ?
loše sam se odrazio
Sve će primedbe biti uvažene da se poboljša iovako strahovit preamp, ali u njegovoj drugoj inkarnaciji. Ovaj primerak će raditi ovako kakvo je trenutno stanje, ništa ne menjam. Dakle, drugi primerak ide sa svim sugestijama, da iscrpimo još malo muzike iz ovog čuda. Trenutno se nema ni snage ni volje ni para da se išta menja, ide u kutiju ovako kako je.Slede još par slika...
Napajanje je izvedeno sa 6x5GT, nakon nje 220R, pa c od 22u, pa induktivnost 20H, pa bleeder za nekih 10mA, pa C od 200u, pa RC račvanje ka oba kanala (1k1 pa ide 20 i nešto uF MKP)... 60 i kusur mA ide od ispravljacice. struja kroz 12b4a je 25mA.
rele ne prekida put signala, vako je malo nezgrapno nacrtan. odspaja signal sa mase.
47R5 - R133k x 2 - 66k – R2470k - R5 i R5a2k2 - R31k5, 1k - 600R - R4220uF - C20,47uF - C1MJE350 - T22N2907 - T1LED - crvena100k - P1
šema:
a i evo kutija... i kako je sve ovo zamišljeno da izgleda na kraju svega...
Još jedan preamp.... nikad kraja. Šemu za ovaj preamp sam dobio od Mukija (član na ovom forumu) sa rečima da ovo moram napraviti i zaokružim priču
Direkt na projekat.
Evo rupe za cevke:
SLCF
in Tubes
Koji su tranzistori kandidati za CCS?
