2219 -
11
Postovi objavljeno od bata bane
So the story goes on.....after a lot of temperature measurements, I decided that the most optimal solution would be a two monoblocks version. This way one side of monoblock woud be used for power resistors and other side for output transistors and power supply.Mesurments were.... power resistor cooling block was not more than 50C in room temperature during summer, and side where power transistor and supply were was even less , about 45CMesurments were taken whith unimer so might be a little higher, but even so I was happy whith heatsinks
dont have it right now, I will put it as soon as I get it dont have 1t813b data either, could you post it for me, pleasefinal schm is ?
Druze B, zahvaljujemVeoma lep rad, svaka pohvala BataBane!Pozdrav.Borko.
After a while I finaly finished my amp...
basic caracteristics 34V supply, 2.6A bias curent...
it started like this http://www.hifi-forumi.com/forum/viewtopic.php?f=18&t=10229&hilit=sega ,but after a lot of experimentation and few changes in circuts design it looks something like this
base of the amp is Russian military Ge power transistor 1T813b, and imput transistor is AC 141K, in the midle AD 162
thiese are the glimps of my hevy metal work for now
EDIT :
SCHEMATIC INCLUDED,by bata bane request
ZM
For some time I was also interested in making field coil magnet, but with voice coil patented by our countryman which made some controversies in hi-fi community, the DD voice coilYou can sure make a field coil stronger than a neodymium, that's just a matter of the power applied. I've played around with coils as magnets previously, and sure there is a limit, but it's beyond what you'd consider reasonable from a power consumption aspect.The main benefit, would be higher flux in the voice coil gap, and a possibility to adjust that parameter. This I would expect, could turn out as a possibility to get better frequency response in the upper end. Magura
As I understand, the neodyum magnet are stronger than field coil magnet...It is a considerable job to make some thing like that...what are the adventages of such concept?regards BB
@mentoksvaka cast za entuzijazam i trud obzirom da ti je "prvi put".... da nisi spomenuo nikad ne bi rekao meti te svece pa da cujemo utiske....jos edared
ja sam zainteresovan, pile imas ppIz par privatnih poruka koje sam danas razmenio sam skapirao da je oglas malo zbunjujuć. Slike sirove kutije su tu orijentacije radi. Kutija trenutno izgleda kao na prve tri slike.Priprema za novo pojačalo je moja obaveza. Podrazumeva nov klirit u prednjoj ploči i aluminijumske ploče 10mm x 120mm x 300mm koje prelaze preko oba hladnjaka iperfektno ih termički sprezu.
gujo, sta da kazem.... adapteri su superiskačiča, miča, gotova priča. adapteri su kod postavljača teme pa njega davite dok se stanovita količina ne potrosi.
ma pokupi
ah, da ...mene treba 10 komata
gujo, radis na telepatiju.... juce sam iskuckao poruku, ali nisam poslao...ko da sam znaoimas moj broj...i resavamo problem na licetu mestasho bi rekli ...cekam tvoj poziv pozz18 komada prvih i 5 komada drugih je izecovano.dakle?
lep tekst, jedino bih dao sugestiju da se prebaci u "know how" ili "data & tips"pozdrav
druze G, ni jednog momenta nije dolazilo u pitanje moja resenost da preuzmem robu, no nisam zeleo da budem nametljiv...jel'tezemun mi vise odgovara, pa samo reci mjesto i vrjeme...a moze i nesto da se popije na neutralnom terenu ako vise odgovara u svakom slucaju za inicijativu i ekspeditivnostpozdrav bmob 064 11 57 111ti si bata-bane počeo kviz, znači ti dolazis.biraj: vidikovac ili zemun.
ajde gujo...pa nismo deca majka mu stara, tolke eure dadosmo na sisteme pa da nam je sad mnogo za postarinu salim se, pa postekspres je resenje
gujooo ne udaraj nam ceznju, nego zbori....
pa recimo da bih mogao da uzmem 8 komada sa tim da bih voleo da znam okvirno kolika bi bila cijena istih pre togaok. smisli količinu pa javi.
Germanium SE Amplifier
in Project gallery/WIKI
