Zen Mod
Administrator
Sve objavljeno od Zen Mod
  1. Conclusion ! My preferences: -Babelfish XA252 (that being All Mos): rails between 30 and 35Vdc - depending how much power is needed, Iq everything between 1A and 2A, depending how much aluminum is on disposal, BFR-22R -Babelfish XA252 SIT: rails 30Vdc, Iq 2A, BFR-22R Hasta La Vista, Baby........ I'll be back!
  2. Babelfish XA252 SIT - graphs , 4R load, BFR=510R Load changed to 4 Ohms
  3. Babelfish XA252 SIT - graphs , 8R load, BFR=510R .... everything same (rails +/-30V, Iq 1A7)
  4. ne zameram ja ne znam kako sam uspeo da ne pratim zadnja dva meca, ali sam uspeo ustedeo kilu zivaca
  5. current mirror is having programmed current at one side, while other side of current mirror is increasing or decreasing own current, so that voltage sags stays constant current of "working" side of CM is changed simply by effect of changing voltage between rail and base, while emiter resistor is not changing ........ so effect must be change of current though part contrary to that, reference halves of CM are having everything constant - both current through them, same as constant voltage between bases and rails
  6. Babelfish XA252 SIT - graphs , 4R load, BFR=22R everything same, load changed to 4R
  7. Babelfish XA252 SIT - graphs , 8R load, BFR=22R Today I had time just for first battery of tests, with BFR value of 22R Happy Camper, will be even more campier tomorrow, after all tests and some mooooosic time everything as before (rails 30Vdc, Iq 1A7), I've just mount necessary parts for SIT iteration and changed upper mosfet for THF51 as of recently - Ugs value of SIT is irrelevant, it's just niiiiiice to have them so-so matched by Ugs graphs going up to 30W, at greater levels than 30W - Opto+Thyristor current limiter kicked in and entire OS gone Dodo ; obviously DEF specific current distribution of parts is putting heavy burden on Mosfet and I need to investigate how much I can increase protection treshold, without risk I will also think of ways - maaaaaybe - how to slighlty increase power output ........ I don't want to change even a iota of natural DEF behavior, so I need to see how much exactly juice is going through Mosfet dynamically, and to accordingly declare new Iq point for that rails are OK, 30 as is, 35 if one want to squeeze as much watts is sane from this amp more to come these days about that
  8. SissySIT and Babelfish XA252 SIT are fooling around on the corner and chatting In one moment they see Babelfish XA252, walking on other side of the street Babelfish XA252 SIT sez : " That one could use some help ........ "
  9. zalemi masne okaste papucice na zice ako ih ne nadjes lokalno, ima u Minor iskoristi priliku i uzmi i zica i termobuzira raznih, kad vec donosi pošćar
  10. ma gotovo sa Official SSE (Second Set of Ears) ode Woli u digitalne ampove kaze ovi moji nisu neutralni
  11. ima Mou, digi nabavljas jal preko sprinta ili vremenoplova ene, manja iteracija ovoga sa railovima nazivno 24V i IRFP mosfetima ce bude uskoro manja snaga ali i manja disipacija i svi delovi tepsija ribe izoblicenja isto smrt malecka, THD Spectra ista - dominantan 2nd, amp ne obrce fazu, harmonik negativna faza radni i finalni naziv ampa - Plethora of Pinjatas
  12. nista od Wolija on prelazi na D klasu kaze, ovo mu previse greje dnevni boravci
  13. Graphs , 4R load, BFR=510R everything same as previous, load changed to 4R
  14. Graphs , 8R load, BFR=510R Everything the same, but BFR changed to 510R, that being opposite extreme to 22R - practically lowest OLG which I considered
  15. Graphs , 8R load, BFR=22R FE is made as more or less basic LTP thingy; though, I did wanted to have possibility of altering THD level by changing OLG in simple and predictable way - which I made in also basic way - tearing LTP halves ( each halve having own CCS) and introducing common degeneration resistor ( practically changing length of effective Tail of LTP) , which I then named as Beauty Factor Resistor, short BFR as you will see, changing value of that resistor is chhanging OLG, thus changing amount of overall NFB, and as result we have lesser or higher THD level Luckily, Spectra is not changing, and that was a goal now - set of measurements with highest possible OLG - BFR s 22R Rails are 30Vdc ( amp projected to work with rails of 30-35Vdc with no changes) Iq 1A7 DC offset and Iq practically not changing in temperature domain While varying mains voltage (nominal 230Vac) between 200Vac and 255Vac - DC offset is changing some 20mV, while Iq is practically not changing Good enough for me Load for these graphs is 8R; each graph is having title captured, so you can see what/how much due to 30Vdc rails, clipping smidge above 40W with 35Vdc rails, clip near 55W who needs that ?
  16. I did planned before to make it, but finally made T-Bed 2 , as proper cradle for prototyping this from one of pics, you can clearly see that ZM is Chicken , executing first power up and settings with IRFP240/9140 and 2A fuses in rails...... did it with smallish Iq, and later - when I was happy camper, changed to Biguns
  17. Now, for clarity sake, there is edited schm, parts needed for SIT iteration omitted few more funny pics, too
  18. prepis sa Big DiyA no way da kucam ponovo, zato copy-paste /////////////////////////////////////////////////////////////////////////////////// Few years ago, we had enormous fun in funny named thread : F4 Beast Builders : https://www.diyaudio.com/forums/pass-labs/300233-f4-beast-builders.html Well, you can call it Group of Hysteric Housewives Brainstorming Result of that was that I have myriad of back of napkin sketches, and after these I started simulating ...... and simulating ... and simulating After myriad of these ( out of sheer enthusiasm I even made pcb files for some of iterations), I finally had made nice smallish channel pcbs, containing OS having different-ish approach to biasing than Papa's original XA25 is having, while FE was in principle same as Papa's, but with few beautiful quirks, of which I was damn proud (yup, Mighty ZM reinventing Da Wheel, time and time again) And they were sitting, populated, on my shelf ........ always being pushing to bottom of list; I knew they would work, but somehow I wasn't content with overall picture Now, recently - besides revising biasing mechanismus for SissySIT ( resulting in R.3) and few other amps, I also made FE called Plethora of Pinjatas ( or just Plethora, short) and found interesting to combine it in sitting Babelfish XA25 project Plethora Fe having both SE and Bal inputs as matter of choice, called to adding another "2" in name , so result is Babelfish XA252 Plan is also to have iteration of DEF OS ( real SIT, no emulation in form of Schaded Mosfet), thus addition of "SIT" in name, so Babelfish XA252 / SIT Find enclosed cumulative schematic, and will do edits of this post, if and when needed OK1-OK2-TH1 .......... 10A limiting circuit, Savior of Our Souls, blatantly stolen from Pa
