Zen Mod
Administrator
Sve objavljeno od Zen Mod
  1. Tea- just few thoughts ...... as you can always see from Papa's schematics - he always counts on selected parts ; same is here ; value of drain resistor in input LTP is dependable of exact lower output Jfet Ugs value ; same - value of resistance in paralell to CNY bjt is dependable of exact upper output Jfet Ugs value . so - procedure for making functional Babelfish J2 is something as : 1. test and choose output Jfets ; according to their respective Ugs values - 2. preset input LTP resistance and CNY's parallel resistance 3.preset input LTP CCS at 20mA ; then 4. solder outputs in place and proceed with proper power up procedure #3 demands some tricks how to , with auxiliary PSU ...... or just setting programming resistance in CCS to ~ 0V65/20mA=32R5 more to come - with proper schematic , with parts nomenclature
  2. just best practice but - I didn't tried really mismatched ones ; maybe I will , but not so soon ...... maybe because I don't have really mismatched ones I know that they're everywhere from 1V2 to 1V9 , at 2A in any case - I think that real and valid answer you can get only using THD meter , and comparing best and worst case
  3. onda su i ovi isti ......
  4. not exactly matched you can see their Vgs-es at 2A on pictures
  5. lepi su i jedni i drugi , al' cak i ne lice
  6. lako vam je mene zekiti ........
  7. nije samo prica u konektorima - to je samo fizicko izvodjenje veze poenta je u topologiji ......... da li se signal salje/preuzima nebalansirano ili balansirano ;u ovom slucaju - kad kolo samo po sebi ima nebalansiranu konstrujciju i ulaze/izlaze , montaza XLR konektora donosi samo kvalitetniju terminaciju .ukratko - i F5 i NS10 imaju nebalansirane ulaze/izlaze .
  8. Sipi - ovo citaju i oni koji su juce naucili koja je prava strana lemilice .
  9. finalna verzija - testirano izvrsena korekcija drain otpora kod ulaznog diff para - da bi se pokrio siri opseg Uds napona izlaznih Jfeta - taj drain otpor se sastoji sad o d redne veze fiksnog otpora i multiturn pota. uz prethodno obavljeno merenje izlaznih Jfeta na Uds na nazivnoj struji , moguce je sastaviti amp sa samo jednim trimerom , i to onim koji definise struju CCS-a za ulazni LTP zanimljiva stvar - po postizanju temp. equilibriuma , DC offset na izlazu je neuobicajeno stabilan - maltene da ne reaguje na snazno duvanje na ulazne jfete , kao ni na snazno duvanje na CCS koji ih napaja ; mada taj tip CCS-a i jeste izabran zato sto je termicki veoma stabilan ... prikacena sema : edit : schm deleted by ZM
  10. hehedanas je dan Ampova
  11. Zen Mod
    driver za 300B
    hand made motorcycle ? imas offtopic subforum ....... please (moze koja fotka ........ )
  12. Zen Mod
    Pluto.
    Maglite
  13. evo ga - pod dummy load od 8 oma , na 440Hz , klipije na 13V4rms , 38Vpp sto ce reci da je snagica 13V4^2/8=22W4 celih .........
  14. Zen Mod
    driver za 300B
    naivan si ti meni sinko ...... naivan ........ pitam se ko li se krije iza tog nick-a .......
  15. zahvaljujem cika beli - drugi kanal ce prosvirati ........ valjda uskoro moram prvo neke druge stvari pozavrsavati a ti se u goste mozes pozvati i bez J2
  16. pokajnicku glavu ni mac ne sece .......... nekad valja rekalibrisati scope Vpp je tek malo manji od napona napajanja ~ oko 40Vpp....... a da bi sve bilo jos pouzdanije , merio sam i na 440Hz , gde je multimer na AC pokazao 15,1V ja se ne secam da sam skoro dirao kalibraciju scope-a ........ mora da je cera kad ordinira i gleda cudne vijuge koje pravi prst na sondi ...... dobro je - ovako je ipak logicnije .... pitam se zasto od silnih utisaka nisam nista ni proveravao sem struje i DC offseta ... i pozurio da ga cujem
  17. nikad ja to necu nauciti .......
  18. 'bem ti imzenjeriju - nikad ja necu skontati kako od Vpp dobijes Vp
  19. sipi - nije li to ~19W na 16E , RMS ?(25Vpp x 0,707)^2 /16 ?da zanemarim cinjenicu da je Vpp mereno bez opterecenja :drinks:nisam stigao vestak da prikopcavam - zurio sam d' turim zvucnjak
  20. da znas - - neverovatnih 5W mi sa ovom semom ladno mozemo ici i na vece napajanje - samo pomenjati par tranziporta sa naponski jacima al - kome to treba - ..... jos mi nije jasno kako juce nisam uspeo da mi ijedan test CCS radi ........ kad ja izmisljam toplu vodu pa sam zato morao sastaviti amp
