Okibokis
Sve objavljeno od Okibokis
  1. Ovakve emisije se vrlo retko ili gotovo nikad ne repriziraju,ali se zato na RTS-u neke tuzne serije pojavljuju po hiljaditi put.
  2. Pa ima potenciometar za podesavanje osetljivosti
  3. Ovo je stvarno lepo,ne znam kog je kvaliteta zvuk,ali prednji panel je lep.
  4. Ovo planiram da koristim kao predpojacalo,ima i lampu i ekvilajzer i gain,i dva kanala.Spojicu ga sa snagasem kojem nisam znao nista pametnije da napravim kao preamp. Evo specifikacije,pa nije lose da cujem vase misljenje... The unit also offers a high-pass filter, with a sweepable range from 15 to 320 Hz, useful for removing rumble and low frequency handling noise, and a parametric EQ with adjustable center frequency, bandwidth and amplitude. Frequency switching allows the user to sweep the entire frequency range from 10 Hz to 20 kHz. The ULTRAGAIN PRO MIC2200 can also function as DI box, converting unbalanced instrument signals into clean, balanced signals. In addition to providing a soft mute function for the +48V phantom power, the ULTRAGAIN PRO MIC2200 provides excellent service when a need occurs to convert home-recording levels, -10 dBV, to +4 dBu level, for interfacing into professional environments. Extremely low-noise, dual microphone/line preamp Integrated high-quality 12AX7 vacuum tube Extreme bandwidth from 10 Hz to 200 kHz for open, transparent sound Two additional high-end parametric EQ's Fully sweepable, switchable high-pass filter (12 dB/octave) Soft mute function for +48 V phantom power suppresses switching noise Extremely flexible "Direct Inject Box" function Independent level conversion from home to professional level (-10 dBV / +4 dBu)
  5. Evo da ga otvorimo,nije to sa oglasa,ali mislim da je isto.
  6. Mislim da jeste Kenjalo ,ali njegov sin...bilo je toga pre godinu dve u razlicitim varijantama na KP
  7. Dumb and Dumber To (Glup i gluplji 2) 2014
  8. Strasno...
  9. Ubilo se za Lowthera:))
  10. Da li neko ima iskustva sa ovakvom izvedbom zvucnika,jer na netu vidim da im cena nije bas mala.Negde pise da je to Hizumi vibration speakers.a negde da je za sve zasluzan Takeshi Teragaki genijalni cicica,koji to sve radi sam,.Ima na Youtube nekoliko klipova,ali nista vise od toga,premda deluje interesantno...
  11. http://youtu.be/lzZWrCumvYE
  12. Ubilo se za lampe i velike papire....
  13. http://www.ebay.com/itm/like/321582320775?item=321582320775&lgeo=1&vectorid=229466
  14. Evo ovo ima u prodavnici da se kupi... A ovo drugo nisam ni znao da postoji,mozda nekom treba.
  15. Ja ne znam da gledam semu,ali ako neko zna koja je ovo vrsta a klase ili uopste na sta podseca,neka napise nesto.Mozda se ova sema pojavljivala i u nekim drugim modelima Sony pojacala,a ja to ne znam.U svakom slucaju neka mi neko od iskusnijih clanova kaze,da li je ovo komplikovano napraviti,i da li je izvodljivo? sony_ta-n86b_sm.pdf
  16. Da li je neko od kolega sa foruma imao bliski susret sa ovim kompletom,i ako jeste interesovale bi me impresije? Da li se isplati naci ga negde ocuvanog,jer sam citao da je radio u ,,A" klasi i uradjen veoma kvalitetno.Interesuje me da li postoji klon ovakvog malog snagasa,da moze da se napravi i vredi li ovo truda?
  17. Bas bih voleo ovo da imam.
  • Trenutno na sajtu   3 članova, 1 Skrivenih, 299 Gosta (Pogledaj celu listu)
    453.7k
