Mikorist
Sve objavljeno od Mikorist
  1. Ako je SO squeezelite-R2 -z -n "USB DAC" -m 24:4f:4f:24:0f:80 -o "hw:2,0" -p 99 USB Audio (hw:2,0) STD S32_LE (44100/1) I ovo piči full DSD
  2. prebacio sam ovde jer je ovo to u plejeru Puštaće sve ove iznad formate na HW 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000, 705600, 768000 Samo do 192khz radi normalno preko šušti PCM63P - mora PCM Ako je AKM čip ili Sabre ide na HW
  3. cat /proc/asound/J20/stream0 JLsounds JLsounds Hi-Rez Audio 2.0 at usb-0000:00:14.0-9, high speed : USB Audio Playback: Status: Stop Interface 1 Altset 1 Format: S32_LE Channels: 2 Endpoint: 0x01 (1 OUT) (ASYNC) Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000, 705600, 768000 Data packet interval: 125 us Bits: 32 Channel map: FL FR Sync Endpoint: 0x81 (1 IN) Sync EP Interface: 1 Sync EP Altset: 1 Implicit Feedback Mode: No Interface 1 Altset 2 Format: S16_LE Channels: 2 Endpoint: 0x01 (1 OUT) (ASYNC) Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000, 705600, 768000 Data packet interval: 125 us Bits: 16 Channel map: FL FR Sync Endpoint: 0x81 (1 IN) Sync EP Interface: 1 Sync EP Altset: 2 Implicit Feedback Mode: No Interface 1 Altset 3 Format: SPECIAL DSD_U32_BE Channels: 2 Endpoint: 0x01 (1 OUT) (ASYNC) Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000, 705600, 768000 Data packet interval: 125 us Bits: 32 DSD raw: DOP=0, bitrev=0 Channel map: FL FR Sync Endpoint: 0x81 (1 IN) Sync EP Interface: 1 Sync EP Altset: 3 Implicit Feedback Mode: No Ovo cepa full DSD sad Samo što PCM63P neče da može
  4. Zovi ako treba nešto. Dosta smo mi zvali tebe
  5. Ja brale tražim xmos.rules sa istim ID a naletim na bugarina Ljubena. Samo autor ovoga i ja tražimo isto DSD native for JLsounds boards · Issue #1 · lintweaker/xmos-native-dsd GITHUB.COM Hi Lintweaker, JLsounds converter boards supports DSD native up to DSD256. Could you please include it to the list of supported converters if it's possible? The USB ID of JLsounds is 20B1:2023 ...
  6. https://www.xmos.ai/download/AN01027:-Porting-the-XMOS-USB-2.0-Audio-Reference-Software-onto-XU208-custom-hardware(1.0.0rc1).pdf Samo modifikujem Frekfenciju oscilatora kao na JLS i imam svoj Linux drajver. Ali sumnjam da se razlikuje od postojećega.
  7. Videćemo. Više sam sad usredsređen na to kako radi na Linux. Iz uputstva za XMOS XU208 mount -t usbfs none /proc/bus/usb -o devmode=0666 /etc/fstab: none / proc / bus / usb usbfs defaults , devmode =0666 0 0 /etc/udev/rules.d/99-xmos.rules SUBSYSTEM != " usb | usb_device " , GOTO =" xmos_rules_end " ACTION != " add " , GOTO =" xmos_rules_end " # 20 b1 : f7d1 for xmos xtag2 ATTRS { idVendor }== " 20 b1 " , ATTRS { idProduct }== " f7d1 " , MODE =" 0666 " , SYMLINK += " xtag2 -% n " # 0403:6010 for XC -1 with FTDI dual - uart chip ATTRS { idVendor }== " 0403 " , ATTRS { idProduct }== " 6010 " , MODE =" 0666 " , SYMLINK += " xc1 -% n" LABEL =" xmos_rules_end " The ATTRS, MODE and SYMLINK service udev reload udevadm trigger or udevtrigger Ovo je sledeće na Sistemu. Da gađa i drajvere po proizoiđaču XMOS - da imam i debuger - FTDI/XTAG debug Tek onda ne mora da se lovi USB za RT po procesima. Ima posebnu oznaku.
  8. Ја ти кажем да имам на чему да чујем како треба. И на скушалицама и на звучницима. Остатак система је Зен направио. А он је Свети Грал овде
  9. А мој преамп боље да не помњемо...Бановаће нас конструктор.
  10. Чекај @NIXIE да се пробуди. Па се свађајте
  11. Ето направили смо ударну тему на форуму као ништа. Битно је да се пише (само ради писања) потпуно је небитно шта. Нити нас је брига шта ко мисли.....и шта је име теме..... Можемо да наставимо у другој рецимо да играмо "на слово на слово".
  12. Кикикикикикикикики
  13. Na preamp. Pa na slušalice.
  14. USB kao usko grlo. Operativni sistem. Čitaj jbt
  15. Pitanje je da li je bilo koji ΔΣ DAC bolje peva od kršteno dobro urađenog ALC audio na matičnoj. Pričam o matičnim od 600-700 evra.... Tako da PC može direkt da bude izvor zvuka.
  16. Ne razumem se u gramofone toliko. Tehniks mk2 mi je plafon bio. Ali opet, ovo nije tema. Samo PC....
  17. To je druga tema. Prebaci se tamo. Ovo je PC kao izvor zvuka. Jer imam i ALC kao decoder ovde. Ne treba mi DAC.
  18. Ne nego istina boli. To što je USB 2.0 i njegov protokol usko grlo u sistemu i što ne valja ništa - a mi ga koristimo - naš je lični problem. Ljudi lepo koriste gramofon i ne muče se ovoliko...Nisu mazohisti kao mi. I jesmo zastranili....ako me se sete.....na dan bezbednosti......
  19. I sam Windows farba zvuk. NE mora plejer uopšte. I MacOS takođe. I linuks sa običnim podešavanjima farba zvuk. I matična ploča farba zvuk. I sam procesor sa spajkovima farba zvuk. I USB port farba zvuk. I napajanje...Sve zajedno je ofarbano.
  20. Mašiš ti temu. Ofarbano je jer sistem dozvoljava da to plejer radi. Odnosno korisnik-user mu je to dozvolio na svoju odgovornost admin pristupom. Na mom sistemu toga nema. Plejer je poslednja rupa na svirali. Sem ako opet ti ne dozvoliš sa sudo/admin userom.
  21. Šta se događa posle računara i DAC me ne zanima. Nije moja oblast elektotehnike. Bolje reći elektonike.
  22. I kažeš ne može biti do opertaibnog sistema? Ja ti kažeem da može biti do opertaivnog sistema. Ne upravlja plejer operativnim sistemom nego sistem plejerom. Ako to nije slučaj onda operativni sistem ne valja. I to upravo i radimo svo vreme.....ispravljamo krive drine u sistemima. Ne upravlja DAC šta če računar da radi. Nego opertaivni sistem upravlja sa DAC.
  23. Uči se. Ali nije programiranje sve. Može bilo ko da upiše kurseve na višoj. I dobije setifikate. Cisco, Microsoft, Sistem admin ili sl. I sa drvno prerađivačkom ili poljoprivrednom. Pa čak i ovako - čisto radi znanja nekoga osnovnog. Mada i to spada u neko programiranje (nekoga hardvera). Ali svejedno sve to se krade kao zanat od nekoga. Ne preko foruma. Nego uživo negde u računskom centru - server hali il na provajderu. Promašio si temu - cela tema se zove PC kao izvor zvuka. PC kao audio komponenta.
  24. Mogu ali mi treba oprema kući koju nemam....Već sam pisao o tome.
  25. Pa Tesla i viša elektotehnička. Ali se ni to ne uči tamo. Ako si baš tehničar za računare. Na Hardvardu da.
