Babysitter je za pi**** :P
Pržiš bajo moj, što bliže meltdown point - ljepši zvuk :P
http://www.schiit.com/products/magni-3
Dobar kandidat da pogura MoFo, a ? Lepa kutijica, gura i sluške... 99$
Frequency Response: 20Hz-20Khz, -0.1db, 2Hz-900KHz, -3dB
Maximum Power, 16 ohms: 3W RMS per channel
Maximum Power, 32 ohms: 2W RMS per channel
Maximum Power, 50 ohms: 1.3W RMS per channel
Maximum Power, 300 ohms: 430mW RMS per channel
Maximum Power, 600 ohms: 230mW RMS per channel
THD: Less than 0.001%, 20Hz-20KHz, at 1V RMS, less than 0.02% at 5V RMS into 32 ohms
IMD: Less than 0.001%, CCIF
SNR: Greater than 108db, unweighted, referenced to 1V RMS
Crosstalk: -70dB, 20 Hz-20KHz
Output Impedance: Less than 0.3 ohms at either gain
Input Impedance: 25k ohms
Gain: 2 (6db) or 7 (17db), selectable via rear switch
Topology: fully discrete, fully complementary all-bipolar, symmetrical current-feedback design with no capacitors in the signal path and DC servo
Protection: Standard failsafe DC power input and muting relay
Power Supply: “Wall wart” style 24VA 14VAC transformer, regulated +/- 17V rails with over 6,000uF filter capacitance
Power Consumption: 6W
Malko je slabašan gain i izlazni napon, izračunaj koliko treba ulaznih volti RMS za taj MoFo, 13Vrms ti treba recimo za 21WRMS/8oma.
Najprostije resenje za MoFo je Pass BoZ pretpojacalo, pa neko od Sipijevih pretpojacala, pa Ba-3,pa lampasko pretpojacalo o kome smo pricali...
Ali da ne zaboravimo, bitno je znati da li ce MoFo biti pogodan za zvucnike koje imate..ako ne, cela prica zajedno sa pretpojacalima...pada u vodu..
Čekaj, pa valjda ide x2 na svaka 3 dB, pa sa 2V ulaza i 17dB gain-a je izlaz...valjda veći od 32V, možda sam ja pogrešno to skapirao... Ne čekaj ,to dupliranje ide sa Wattima, tj. snagom i decibelima buke... a kako ide sa naponom?
Ali, zar nema i Salas 6V6 oko 15 dB gaina?
Vix, to jeste to, napraviti BoZ i gotovo. Kontam da ako se napumpa BigMoFo, sa velikim prigušnicama i ladnjacima, i sa 22W po kanalu, izbor zvučnika se drastično proširuje u odnosu na Sewu ili mali MoFo...
Može i bridge big Mofo, to je oko 80-100W, ojha...
Je... prešao sam brzo preko teme. Jel ona pravila pojačalo el akcelerator čestica? :rofl:
E da, Bridge Big MoFo, u tom slucaju to bi se zvalo MthFcko :). A mozda bi mesto prigusnice mogao veliki trafo. Da ne lupam, nego da pogledam to Magurino chudo...
on
Može, ako ga rasturiš pa složiš E na E i I na I  limove sa air gapom ~ 1mm.
Plus treba pogodiš induktivnost + da bude za tu struju, itd itd... :D
1 minute ago, Zen Mod said:
on
MaguraN znači :D
Od kad sam napravio i poslušao, nemam više animozitet prema elektrolitu na izlazu iz ampa.
A tvrdio sam kao ti, isto tako oštro, samouvereno... bež'o k'o đavo od krsta od te topologije.
BTW: Ja bi ovde samo dodao 10uF MKP u paralelu sa elektrolitom ;)
Ma nije bitno, probao sam davno dodavanje elektrolita na DC pojačalo kome ne treba izlazni elektrolit čisto da čujem kakva je razlika, i nije mi se dopalo to što sam čuo. Visoki kšš kšš, srednji ko iz čabra, a bas dum dum. Hteo sam da pravim za probu onaj  DoZ sa delovima koje sam imao pri ruci, nekim minimalnim napajanjem 30VDC, približno 2x10w/8 oma, ali brzo sam odustao. Taj elektrolit je bio 10000uF 100V polarisan Siemens, to je kvalitetan kondenzator (veliki ko konzerva graška), možda bolje zvuči kad ima DC napona na krajevima. U svakom slučaju mislim da je elektrolit na putu signala nepoželjan u bilo kom obliku.
