InSides
K: Wow & Flutter Meter.
Recommended Posts
Хтео бих да купим справу за мерење Wow & Flutter параметра.
eBay је пун, али рекох да питам прво локално?
Share this post
Link to post
Share on other sites
1 hour ago, grau said:
Covek koji to ima u Beogradu sigurno ne zalazi na ovaj forum.
KupujemProdajem, онда?
Share this post
Link to post
Za šta ti je tačno potrebna takva sprava?
Ne znam koliko je stvarno upotrebljivo i precizno, ali postoje i softverske varijante.
WFGUI:
http://www.ant-audio.co.uk/index.php?cat=post&qry=library
http://www.tapeheads.net/showthread.php?t=55581
http://new-hifi-classic.de/forum/index.php?topic=7328.0
Ovo poređenje sa pravim hardverskim uređajima ne deluje loše:
Share this post
Link to post
Pa jesi gledao na KP?
Ima ovaj:http://www.kupujemprodajem.com/Leader-Wow-Flutter-Meter-LFM-39a-50682758-oglas.htm
The LFM-39A Wow & Flutter Meter is a direct reading type
instrument designed for measurement of Wow, Flutter and
Drift characteristics of tape recorders, recordplayers and
other playback/recording equipment. The effective values,
peak-to-peak values and center frequency (3kHz or 3.15kHz)
of Wow & Flutter are indicated on the meter in accordance
with J1S, CC1R, DIN, and weighted specifications.
Five full scale ranges, 0.03%, 0.1%, 0.3%, 1% and 3%, are
used. The use of 0.03% range makes it possible to measure
accurately the Wow & Flutter characteristics of high-grade
tape recorders.
The LFM-39A contains an oscillator with excellent frequency
accuracy, which can be used to calibrate the drift meter and
supply a recording signal.
Moreover, this Wow &c Flutter meter is equipped with a TO
SCOPE terminal for analyzing Wow & Flutter components and a
RECORDER terminal for Wow & Flutter recording.
Share this post
Link to post
Хтео бих да мерим грамофон који дизајнирам. Па рекох, да не буде да се само на уши ослањам...
...мада имам велике уши. :)
23 minutes ago, ivan_ said:
Видео сам тај, да - али рекох да прво проверим да Форуму, да некоме другарски помогнем. :)
Share this post
Link to post
ovaj o kome sam pisao je bio vlasnistvo nebojse maričića, jednog iz stare garde beogradskih audifila i konstruktora. video sam to kod njega u sobi, mislim da je bio bruel & kjaar.
Share this post
Link to post
2 hours ago, grau said:
ovaj o kome sam pisao je bio vlasnistvo nebojse maričića, jednog iz stare garde beogradskih audifila i konstruktora. video sam to  . . .
poznatog kao Buca . . . ili Bibi  . . . :)
Share this post
Link to post
Da, ako neko sa foruma i dalje ima kontakt sa covekom bilo bi lepo da pomognemo In Sidesu da dodje do ove lepe sprave...
Share this post
Link to post
Може lock. Софтверска варијанта коју је @Kuja предложио ради сасвим солидан посао.
Хвала!
Share this post
Link to post
