Woland Napisano Februar 15, 2019 Share #4445 Napisano Februar 15, 2019 jedno viđenje analogne reprodukcije zvuka: in 1948 in America the 33 rpm is officially introduced as an evolution of the previous 78 rpm disc. As its shellac ancestor is a round plate on which the recording is coded in an analogical way. However, the best quality of vinyl (PVC) compared to shellac has made it possible to reduce the thickness of the grooves, decrease the pitch of the spiral and consequently lower the rotation speed from 78 to 33 revolutions per minute. The sound is read by means of a pin, in diamond or other synthetic material, placed on the engraved groove. The rotation of the disc causes the needle to generate vibrations resulting from the irregularity of the groove and the sound reproduced produces a series of imperfections that make music more "natural" and "hot" compared to modern digital systems, certainly more precise but also more "cold". But back to today: to 2019. Now the 33 rpm records are almost always recorded digitally and then printed on vinyl. A sort of compromise between new technologies and romanticism that can certainly guarantee an excellent result of sound "beauty" but also of executive precision. Link to comment Podeli na ovim sajtovima More sharing options...
vladd Napisano Februar 15, 2019 Share #4446 Napisano Februar 15, 2019 Malo je rudimentaran stav. Glavno pitanje je, kojim ce se putem krenuti. Podrzavati abnormalne cene analognih studija i biti u riziku malog profita skupih ploca beznacajnog prometa, ili se nadati nekom Samsungu, da ce pokrenuti novu standardizaciju digitalizacije zvuka(i prenosa digitalnog zvucnog zapisa), za sta su potrebna jos veca sredstva, resursi uz potrebu prilagodjenja postojecem. U veku masprodukcije i minijaturizacija. Nekako sam siguran da to necu doziveti, pa bih se romantici posvetio prostim vracanjem u proslost. Link to comment Podeli na ovim sajtovima More sharing options...
vladd Napisano Februar 15, 2019 Share #4447 Napisano Februar 15, 2019 Pri tome bi trebalo razbiti marketinske kulise, preci na semplovanje sa 200-500KHz i smanjiti broj bita digitalizacije, na 16 ili jos dramaticnijih 12...sto bi zahtevalo strahovito pojasnjavanje i ispravku razmisljanja ljubiteljima velikog broja bitova. Protokol prenosa je nekako najbezbolniji deo posla, ali o tome niko ne razmislja, bar ne zvanicno. Link to comment Podeli na ovim sajtovima More sharing options...
Woland Napisano Februar 15, 2019 Share #4448 Napisano Februar 15, 2019 Malo je rudimentaran stav. Glavno pitanje je, kojim ce se putem krenuti...ma jok - to je samo jedan od odgovora zbog čega se nekim ljudima sviđa zvuk sa gramofonskih ploča.. rudimentarno? jeste, nema svako potrebu da se udubljuje u priču o tržišnom učešću, osvrne na tehnologiju i predviđa tendencije razvoja obe stvari.. msm - ljudi uzmu i nose.. Link to comment Podeli na ovim sajtovima More sharing options...
vladd Napisano Februar 15, 2019 Share #4449 Napisano Februar 15, 2019 Imam ja i takve medju prijateljima, a imam i neke kojima se gramofon nije svidjao, dok mi ga nisu poklonili pa dobili nazad. Nisu odsrafili transportne srafove na doticnom...pa posle u jeee... Skrajnuti "ljude" kao argument. Zato vise volim pricu o tehnici i profitu koji ce ili da je pokrene ili da je satre u nekoj formi. Link to comment Podeli na ovim sajtovima More sharing options...
Woland Napisano Februar 15, 2019 Share #4450 Napisano Februar 15, 2019 ^ ljudi kao argument teško da mogu da se zanemare.. naposletku sva ova furtutma je zbog njih - takvi su, kakvi jesu, iza svake teorije se pojavi čovek, kao začetnik ili ishodište.. ono između vremenom izbledi, zastari, postane irelevantno, jedino je čovek u svojoj savršenoj nesavršenosti konstanta Link to comment Podeli na ovim sajtovima More sharing options...
vladd Napisano Februar 15, 2019 Share #4451 Napisano Februar 15, 2019 Ali da bi bio uzor i referenca, mora da bude znacajno manje nesavrsen od masovnosti. Zato tehniku posmatram sa tehnicke strane, a ne sta neko negde bahato misli o necemu. Ali, jbga kriv je katandzija kafanice, ovde treba stavljati vinile na gramone i prezentovati.. Link to comment Podeli na ovim sajtovima More sharing options...
Woland Napisano Februar 15, 2019 Share #4452 Napisano Februar 15, 2019 ^ nekako se uvek na kraju, nezavisno od teme, razjasniš i nanovo povrdiš svoje stavove pred sobom i publikumom.. toliko potvrđivanje nekome može da zamiriše na nesigurnost u iste, meni ne, ja sam samo preneo tuđ doživljaj koji u dobroj meri delim.. Link to comment Podeli na ovim sajtovima More sharing options...
Aoxomoxoa Napisano Februar 15, 2019 Share #4453 Napisano Februar 15, 2019 First press,made in Holand. Kada sam donosio ploce iz Londona,davnih sedamdesetih godina proslog veka,najredja ploca od Fleetwood Mac koju sam mogao naci.Kupio sam jednu ,second hand, po ceni od 5f,kada su druge kostale oko 1.5-2f. Link to comment Podeli na ovim sajtovima More sharing options...
Doktor Napisano Februar 16, 2019 Autor Share #4454 Napisano Februar 16, 2019 Preko dobrog prijatelja nekako ( ahhhh . . . konacno ) pronadjen "Nemac" RS albuma " Goats Head Soup ". Sasvim solidno stanje ( ex- ), medjutim bez onog sjajnog inner-a ( sl. br. 2 ). Zasto ovo pisem ? Zato sto je to Suzy objavio, ja to imao, slusao, poklanjao, maznjavali mi po zurkama, ponovo kupovao . . . poslednji zateceni primerak ( Suzy, of course ) i nije bio nesto. Elem, thnx Milanu za ovaj GEMA primerak, a posebno @paja959, koji kada je cuo da mi nedostaje taj kultni inner je od svog licnog primerka napravio jedan sjajan dubl na kolor fotokopiru. Atm, ide strana A , "valja" se A3 numera, " Comming Down Again". Woland je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
Aoxomoxoa Napisano Februar 26, 2019 Share #4455 Napisano Februar 26, 2019 Nisam mogao da odolim.Iako imam prvo US izdanje( Garcia remaster 1971).Sta cu,kad je volim vise od Majlsovog "Kind of blue". Ploca ima pozadinski sum.Original mi deluje svezije.Ostaje mi da nabavim jos original mix iz 1969.g. Doktor and paja959 je reagovao/la na ovo 2 Link to comment Podeli na ovim sajtovima More sharing options...
paja959 Napisano Februar 26, 2019 Share #4456 Napisano Februar 26, 2019 2 hours ago, Aoxomoxoa said: Nisam mogao da odolim.Iako imam prvo US izdanje( Garcia remaster 1971).Sta cu,kad je volim vise od Majlsovog "Kind of blue". Ploca ima pozadinski sum.Original mi deluje svezije.Ostaje mi da nabavim jos original mix iz 1969.g. ne kupuj ta picture disc LP izdanja,tonski su losija pretezno,i vise hebava iglu.... Link to comment Podeli na ovim sajtovima More sharing options...
Aoxomoxoa Napisano Februar 26, 2019 Share #4457 Napisano Februar 26, 2019 2 hours ago, paja959 said: ne kupuj ta picture disc LP izdanja,tonski su losija pretezno,i vise hebava iglu.... U potpunosti se slazem sa tobom.Ali za ovu plocu ne postoji sansa da je nemam u svim izdanjima. Ne znam samo gde ovo da nadjem Link to comment Podeli na ovim sajtovima More sharing options...
paja959 Napisano Februar 27, 2019 Share #4458 Napisano Februar 27, 2019 13 hours ago, Aoxomoxoa said: U potpunosti se slazem sa tobom.Ali za ovu plocu ne postoji sansa da je nemam u svim izdanjima. Ne znam samo gde ovo da nadjem https://www.ebay.com/itm/Rediscover-Grateful-Dead-Classic-Album-Covers-Jigsaw-Puzzles-300-Piece/253958652280?epid=1743589648&hash=item3b211d8178:g:husAAOSwHhRb2dRi Link to comment Podeli na ovim sajtovima More sharing options...
Aoxomoxoa Napisano Februar 27, 2019 Share #4459 Napisano Februar 27, 2019 Oho, 40 evrica.Moze,po 500kinti mesecno,taman do kraja godine.Lepo sto su puzle dvostrane,mnogo mi se vise svidja zadnja strana.Hvala za info. Link to comment Podeli na ovim sajtovima More sharing options...
paja959 Napisano Mart 3, 2019 Share #4460 Napisano Mart 3, 2019 Santana IV...3LP + 1 dvd... Woland and ninja je reagovao/la na ovo 2 Link to comment Podeli na ovim sajtovima More sharing options...
shonne Napisano Mart 10, 2019 Share #4461 Napisano Mart 10, 2019 @Doktor sta je trenutno na gramofonu? Link to comment Podeli na ovim sajtovima More sharing options...
paja959 Napisano Mart 10, 2019 Share #4462 Napisano Mart 10, 2019 MJQ.....ulov sa danasnje berze..naci ocuvan primerak ovog je mislena imenica,i medju MJQ fanaticima,em ako i nadjes,bude neki urnisan primerak,pa su tisi pasazi prakticki neslusljivi..mashala,USA izdanje,5 sve..bivsi ORTF primerak Link to comment Podeli na ovim sajtovima More sharing options...
paja959 Napisano Mart 13, 2019 Share #4463 Napisano Mart 13, 2019 Storm Corrosion... Doktor je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
Doktor Napisano Mart 13, 2019 Autor Share #4464 Napisano Mart 13, 2019 40 minutes ago, paja959 said: Storm Corrosion... . . . Drago mi je da pratis ovu novu progresivu ( Opeth & Porcupine Tree ). Evo ti hint od danas - video sam se sa Miljetom, pa mi rekao da je nabavio poslednji regularni, doopli LP od Stivn Vilsona, To The Bone. Preporuka ! Link to comment Podeli na ovim sajtovima More sharing options...
paja959 Napisano Mart 13, 2019 Share #4465 Napisano Mart 13, 2019 4 minutes ago, Doktor said: Drago mi je da pratis ovu novu progresivu ( Opeth & Porcupine Tree ). Evo ti hint od danas - video sam se sa Miljetom, pa mi rekao da je nabavio poslednji regularni, doopli LP od Stivn Vilsona, To The Bone. Preporuka ! falaVi ..sad cem poslusam/Tidal..a ovaj Storm Corrosion su mi isto slucajno skrenuli paznju na to..cisto 5 po svim parfametrima.. Link to comment Podeli na ovim sajtovima More sharing options...
Doktor Napisano Mart 13, 2019 Autor Share #4466 Napisano Mart 13, 2019 On 3/10/2019 at 3:40 PM, shonne said: @Doktor sta je trenutno na gramofonu? . . . Trenutno nista . . . . . . . nema gramofona. Link to comment Podeli na ovim sajtovima More sharing options...
