DVD 9
Zen Mod
  • Odgovora 19
Popularni dani
+1Kod Verbatima posle izvesnog vremena javlja problem u pronalazenju drugog layera
kako sad ?preporucujes , a javlja se problem sa drugim layerom ?
+ je za ocenu maxela i ostalih gluposti.Do sad je verbatim bio najmanje zlo. A i mozda je do mog dvd citaca ako jos neko ne prijavi iste probleme.Probao sam i philips, ne pase nikako.
Koristio samo Verbatim za koncerate i za sada svi živi i zdravi...Malko problematično čita jednog Peter Gabriela posle nekog vremena, al ga čita. U principu zadovoljan.
Ja sam svoje uzimao u podzemnom prolazu kod Doma Omladine u BG, ali nije ti baš usput. Kad se uđe od Doma, radnja je sa desne strane, na pola prolaza, bila bar... Ovi su boje kao Verbatim silver, DVD-R, u kutiji po jedan, neka plavo-narandžasta hartija unutra. Našao sliku... Ja ih bome plaćao skoro 200 din ali nisam kupio sigurno godinu dana.Davno nisam kupovao, ali stigao juče R. Waters - In The Flesh, valja narezati.
http://www.afterdawn.com/glossary/term.cfm/dvd-9
DVD-9
One form of DVD discs that means a single-sided dual-layer DVD disc. DVD-9 can hold approximately 7.95 gigabytes of data, even though marketers like to use the 8.5GB value instead, but this is misleading and is calculated by using so-called "Japanese gigabytes" which means that gigabyte is calculated as 1,000 megabytes, but in real computer terminology, gigabyte is 1,024 megabytes.
DVD-9 DVD-Video discs are problematic for DVD-R owners, because the cheap, writable single-layer DVDR discs can only hold the same amount of data that DVD-5 discs contain, due technical reasons. However, there are several ways to copy a DVD-9 disc to a standard, single layer DVD-R or DVD+R disc -- we have several guides available how to do this on our guide section.
DVD-9 is nowadays often used as the marketing term for dual layer DVD-R and DVD+R discs and use of that name is quite appropriate as the dual layer recordable discs can hold exactly the same amount of data as "pressed" DVD-9 discs can.
Kad smo već kod ovog, ako je frka ima besplatan programčić "DVD Shrink". Spakuje filma sa DL na običan DVD, s tim što prčka samo sliku a ton može da ostavi orginal. Za koncerte na brzaka završava posao.
Немо' да преписујеш :sarcastic_hand::serbvidkakisicl0:
Oćemo da pljujemo malo i ono dugokoso govedo od prodavca... :sarcastic_hand:Ne viđah ga. Ili imam sreće da mu nije smena, il je bila noga u guzicu.
Verbatim, to je jedini dl koji moze da se nadje kod nas u Va. Zadovoljan sam.Ali TDK :respect:Ako nadjes TDK, videces, zeleni omot, kupuj i ne razmisljaj!
Slazem se sa preporukama Zene. Uzmi Verbatim DL. Najmanje glavobolje. Ima ih za oko 125 dinara.Skoro ja resio (posle dugo vremena) da eksperimentisem sa dvd-medijima i uzmen 4 Maxell-a DL za probu. Odmah prvi kad sam narezao ubacim u dvd player i on pocne da preskace... Zbog "ustede" od 25 din. po dvd-u ja bacio 400 dinara... :serbvidkakisicl0:
