zeljkor
Sve objavljeno od zeljkor
  1. Stigli JBL reconi za 2202. Ugradio i ostalo da se zaleme pletenice. Bilo je malo problema sa JBL kvalitetom iz Mexica ali sam resio problem.
  2. Premeri jedinice. To ti je jedini pravi pristup.
  3. Moze lock.
  4. zeljkor
    P: Iskra Altec 811B
    Ko zeli da pravi Altec Model 19 ili nesto slicno pravo resenje.
  5. zeljkor
    P: Iskra Altec 811B
    Prodajem par horni u prilogu. Cena 130Eur za par. Potrebno da se peskiraju i prefarbaju. Teze su , masivnije i po meni puno manje zvone od originala.
  6. Korigujem cenu na 150Eur.
  7. zeljkor
    P: JBL D16R2445
    Jeste, presao sam se. Ako moze samo neko da promeni u nazivu teme.
  8. Prodajem jedinice u prilogu. Cena za par 450Eur. Moguca i manja korekcija cene ozbiljnim kupcima.
  9. Prodajem uredjaj iz naslova. Jedan od boljih u svojoj klasi. Posto sam odustao od izrade DAC uredjaja to mi je visak. Originalni projekat : http://www.diyaudio.com/forums/exadevices/183374-exau2i-multi-channel-asynchronous-usb-i2s-interface.html • Sampling frequencies (kHz): 44.1, 48, 88.2, 96, 176.4, 192, 352.8• Resolution (bits): 16, 24, 32• 8, 4 or 2 channels for sampling rates up to 192 kHz• 4 or 2 channels for 352.8 kHz• Galvanic isolation between the USB ground and the I2S outputs.• Two quartz oscillators for the 44.1 kHz and 48 kHz sampling rate groups• FPGA implementation• 256 kB FIFO buffer to support asynchronous operation• Two analogue voltage regulators with filters• Sample rate LED indicators• USB power LED indicator• Buffer level LED indicator• Four I2S data outputs (8 channels) powered by the DAC power supply (3.3V or 5V)• USB 2.0 interface, Mini USB connector• Proprietary bit-perfect ASIO driver completely independent from the Windows sound system; No software volume control or mixing.• ASIO driver implements automatic sampling rate switching; no re-sampling• Works on Windows XP, Windows Vista and Windows 7.• Tested with Foobar and J.River Media Center• Project homepage – http://www.exaDevices.com Kostalo je 430$ u USA. Cena je 180Eur.
  10. Bilo je zaista brzo Moze lock.
  11. Prodajem DAC kit u prilogu. Odustajem od projekta! Cena 300Eur. Medju slikama ima i cena sa sajta sa prevozom bez carine i PDV
  12. zeljkor
    P: JBL D16R2445
    Prodajem originalne JBL membrane iz naslova. Ostalo kao visak iz projekta. Odlicno stanje. Cena 100Eur za par.
  13. Prodajem mikrofonski preamp iz naslova. Cena 50Eur.
  14. Veliki strucnjak i audiofil. Veliki gubitak za zajednicu RIP
  15. http://www.kupujemprodajem.com/Altec-A7-Hand-Made-9530492-oglas.htm?filter_id=304194 Eto, sta sve ima kod nas DIY Verovatno ce da nabiju cenu ali ko zna: http://www.ebay.de/itm/Altec-Lansing-605A-Duplex-Haupt-Stereolautsprecher-/261357502682?pt=DE_Lautsprecher_Martin&hash=item3cda1f00da
  16. Bio Zvu i zajedno smo zakljucili na nesto nije kako treba kada se stave 2202 "original". Usput ja sam posle te prikacio na 60Hz na 4V cca i cuje se da grebe. Nije pod rukom toliko osetno ali kada smo malo vise probali da setamo membranu u +/- osetilo se Drugi je ok na test signalu ali se isto pod rukom blago oseti. Moguce da je sundjer poceo da trune i da je upao. Druga opcija je da je posto su bili u PA upotrebii u nekim hornama , pocela deformacija tela kalema od toplote. Ovaj sto grebe vise ima Fs 55Hz , ovaj drugi je na 52Hz. Re je za oba 5.7Ohm sto je ok. Ovih dana cu da izmerim ostale stvari.
  17. Moze. Mogli bi se videti da poslusas
  18. Ostaje da prenoci , da malo odmorim glavu pa da sutra ponovo poslusam. Nesto su mi ovi "originali" sumnjivi. Videcemo.
  19. Kao sto neki znaju midovi na mom sistemu nisu pravi 2202. U to vreme nisam imao srece da nabavim recone posto se isti vise ne pravi. 2202 recone je napravio legendarni edgewound sa lh foruma a stavljeni su u korpe od E120 koje imaju nesto veci magnet a samim tim i BL factor. Sada su stigli originali pa sam ih danas ugradio. Cudno je ali zvuk je TOTALNO drugaciji. Vise je mrtav, taman i dobio je onaj zvuk koji su imali 4345 da nema odusevljena pri slusanju. Nekako je vise sve "previse" ravno i dosadnije. U svakom slucaju sada je sve 100% po originalu. Iskreno meni se vise svidja stariji zvuk sa kvazi 2202 pa moram da razmislim sta cu da uradim.
  20. 100% necu vise
  21. Mislis na mene?
  22. Par JBL 2202. Jako dobro stanje. Po meni jedni od boljih mid basova.
  23. Vidim Pa lepo, ovo je verovatno jedan od najboljih kompresionih na svetu. Cena mozda bude i povoljna ali naci parnjaka nije lak posao.
  24. zeljkor
    Papa's Koan (M)2
    Ma Gagi nije ozbiljan
  25. Laze prodavac ! Slika je od D2. Nije ni blizu.
  • Trenutno na sajtu   0 članova, 0 Skrivenih, 144 Gosta (Pogledaj celu listu)
    453.5k
