ninja
Sve objavljeno od ninja
  1. Could ultrasonic cleaning damage your LP? Yes, if you over do it. So could any other record cleaning system, if you overdo it. Damage could come from exposing the vinyl surface to either excessive cavitation (bubble bursting) energy or to excessive heat. Also, you want to avoid excessive heat when working with isopropyl alcohol. Let me describe how I have kept within safe operating boundaries. Higher ultrasonic transducer frequency increases the number of bubbles and, correspondingly, decreases the energy released by each bubble. That is a good thing! Lower individual bubble energy lowers the risk of eroding the surface of the vinyl. Moreover, smaller bubbles can fit into smaller crevices – the vinyl surface is cleaned more gently and more thoroughly as the transducer frequency rises. Most ultrasonic LP record cleaning systems use a 40 kHz transducer. Cost rises as transducer frequency rises. If you want safer, go higher in frequency and in cost. For instance, the individual bubble cavitation energy from a 40 kHz transducer is about 3x greater than that of a 60 kHz transducer and 10x greater than that of an 80 kHz transducer. The magic upper bound for heat appears to me to be 95 degrees Fahrenheit (35 degrees Celsius) for three reasons. First, heat influences but does not determine the efficiency of the ultrasonic cleaner. A 60 kHz machine cleans LPs very nicely at temperatures well below 95 degrees Fahrenheit. Second, the vinyl surface is not troubled at or below this temperature. Remember that the temperature within the fluid bath is not the same everywhere because the transducer itself is causing the temperature to rise unevenly as it broadcasts into the tank. I have seen an instance in which the surface of the record ABOVE the water bath line was affected when the bath temperature approached 110 degrees Fahrenheit. I have seen no adverse effects when the bath temperature is at or below 95 degrees Fahrenheit. Third, the flash point of a 10% solution of isopropyl alcohol is about 110 degrees Fahrenheit. The cleaning bath solution ought to be a 3% to 4% isopropyl concentration. In sum, an upper bound of 95 degrees Fahrenheit gives a deeply respectful margin of error. http://sanfranciscoaudiophilesociety.com/forums/topic/observations-about-cleaning-lp-records-ultrasonically/
  2. Hajde strumfe objasni mi sta su ti mjehurici? Citas samo naslove ili ides malo i u dubinu? "This formation of microscopic bubbles of gas is the start of cavitation (i.e. the formation of gaseous cavities in the liquid)." Vidim da rasprava nema smisla, neka se napravi pa proba. Ne mora uopste biti komplikovano, Dosta je i sama kadica i onda polako uz kaficu okretati rucno. Edit: Da dodam, postoji rizik da pri "impludiranju" uz zid, osim prljavstine pocene i sam zid (ploca) da se odkida. Obicno mjesta koja su malo naceta erozijom kavitacije su kao "magnet" za ostale mjehurice i tu na tom mjestu se to ubrzano dogadja. Inace, impludacija dalje od zida je bezopasna i bez nekog efekta.
  3. Nista, ne moramo se slagati u svemu :-) Ne da mi se ovdje pisati sta je kavitacija ali za nju je potreban vrlo nizak pritisak tako da voda "ispari" i stvori se "vakumski" mjehuric... itd
  4. @zbotic: Opet se ne bih slozio ;-)
  5. Ne bih se bas slozio, da je tako isli bi mozda do 200Hza ne u kHz. Ja bi pre rekao da radi pomocu kavitacije koja nastaje pri visokim frekvencijama (ili velikim brzinama). Da vidis samo kako kavitacija "pojede" kosuljicu cilindra debljine do 20mm .... zeljeznu kosuljicu. Radio sam na rjesavanju tog problema ....
  6. Pa zar sitne pore i brazde nisu cilj svega ovoga!? Krupnije moze i "pranjem" bez ove komplikacije. Ja nisam probao ali sam citao ono sto su drugi probali
  7. Blago tebi pa sve znas, ja se nisam rodio naucen. Sad je li bas bolje 60kHZ za 220£ ili vise od 50 kHz za 120£ i nije mi neka dilema pri kupovini.
  8. Ne znam kolko je snaga vazna i da li za ploce puno znaci 150w ili 200w ... ako cistis dijelove od motora mozda ali ovako, samo za ploce, nisam siguran. Postoji diskusija da li je 50kHz ili 60 kHz bolje ali jos uvijek bez konsenzusa.
  9. http://www.hifisentralen.no/forumet/vinylavdelingen/21447-vinyl-vask-etter-usc-metoden.html http://www.ebay.co.uk/itm/6-5L-Professional-Digital-Ultrasonic-Cleaner-Heating-/160785963903?pt=UK_Sound_Vision_Other&hash=item256f971b7f
  10. BAD panel!!??
  11. Na zalost, male su sanse i da se ja pojavim ... ali cu probati.
  12. Ka bih rado 900ie a moze i ovaj novi Scrambler
  13. Eto, svi smo razliciti ... naj radije bih imao min 5 razlicitih "sorti" ... za svako raspolozenje ... ;-)
  14. Mislim, jesu li lampe za HiFi !? ... Mnogi kazu nisu ... meni jesu i ne brinem se... Japanac je njvjerovatnije pametnija varijanta ali srce kaze Ducati ... Ko zna sta ce na kraju ispasti. Dugotrajnost je relativno, ne mislim ga u sarkofag pakovati
  15. Pa... novi damper "zamiruha" cijelu kucu i malo mi briga zada, setam i mirisem u po feste, 7godina a odrasli narucuju pjesme, guma smrdi... pitam se je li Kinez zahebo sa silikonom...??? ... prijatelj mi nudi odmah teflonski selotejp u zamjenu !!??...btw: da skratim pricu, raja se razisla i slusam jednu od "problematicnih ploca" ... Ane Brun Al starts with ... sa BATom nikad problem a sa novim je previse sssssava na pojedinim pjesmamama... sa ovim damperima je ipak puno manje, ne BAT nivo ali puno bolje ... cijena za 20 komda sa postarinom cijelih 2$
  16. Nesto mi doslo da je bolje da mjesto dva grama stavim dva nosaca, jedan sa Dancom a drugi Japanac ... ali omtome posle odmora ;-)
  17. Ima, ima .. ali mise svidja samo ime, Ducati je ... Ducati
  18. Timing Evo sve moje na gomili i damperi medju ostalim kerefekama
  19. Meni se cini da ce ipak biti neki Monster
  20. Kad sam pitao za GSX-R 750 vise sam mislio kako se motor ponasa, da li je lak za upravljanje, da li je dobar i na nizim obrtajima ... btw: Na slikama sto kacite, ne vidim da iko koristi neku zastitnu opremu? Je li i to (samo) za pocetnike? ;-) @m4rk1z: Mozda i jesam, ali cisto sumnjam ... 83-84/183
  21. Moje vidjenje je da je problem mentalitet i uticaj sredine a manje sta vozis. Ponasanje mnogih vozaca na putevima bivse SFRJ je bas lose. Prihvatanje alkohola i voznje u narodu je meni strasno... nesto kao u Kuduzu kad ga pita sta ces popiti, a on kaze daj mi pivu ... vozim. Ovdje kod mene mnogi voze puno jace i vece motore. Danas je i tesko naci nesto ispod 50-60ks. CB600 Horner (koju sam najvise vozio na obuci) je skoro pa 100ks ali me niko ne bije po usima da je vrtim preko 7-8000. Broj poginulih je skoro 3-4 puta manji sa slicnim stanovnistvom. Doduse, putovi su bolji (ali ne drasticno bolji). Putevi kojima se bikeri voze su na istom nivou, bikerni ne voze autoputem. Novi trend sa metalnom sajlom na sredini puta je odlican za automobile ali smrtonosan za motore. Vrijeme je losije itd, itd... sto znaci da je kultura vozaca presudni faktor. Mentalitet nije urodjen, znam kakav sam bio pre nego sto sam se preselio a znam kakav sam sada, drustvo moze da "prevaspita" i promjeni poglede, naravno uz zelju pojedinca da se promjeni. U svim statistikama dominiraju mladi (ispod 30) tako da nije mozda ni losa ova podjela na A/A1/A2 + godine. Nemam pojma kakav je kvalitet obuke i kolko se trazi pri polaganju ali mislim da je razlika drasticna. Najbolji savjet, sa pogledom na sigurnost je, cini mi se, nemoj ni voziti motor itd, itd ...
  22. Pa razumjem da je gsxr malo previse ali je apn ili 200/250 kubikare ipak za omladince i neozbiljno.. zasto ne biciklo? Kad kazem pocetnik mislim na nekoga ko ima vozi a ne ko ce tek da se uci. U skoli se vozi min 600 a od sljedece godine 650. To naravno za A. Ja sam vozio Gladius i 600 i 650 Hornet u skoli. Brzina je do vozaca i onoga u glavi a ne onoga izmedju nogu.
  23. Pa ima samo jedan A, drugo je A1 i A2 i naravno mopedi ...
  24. Zanimljivo... a zašto? Na čemu se obučavaju ljudi dole za A? Ovdje mi niko nije preporučio "mopede" ;-)
  • Trenutno na sajtu   3 članova, 0 Skrivenih, 722 Gosta (Pogledaj celu listu)
    453.8k
