Srle
71 -
Postovi objavljeno od Srle
Na povom mestu :
https://www.vinylengine.com/turntable_forum/viewtopic.php?f=18&t=79810
nađoh ovu trvrdnju:
I'd suggest to avoid cables with more than one inner conductor for phono use with regular, unbalanced
amplification, cause that just causes extra capacity - and how much exactly will depend on the
configuration.
1) For example, if you'd use the Mogami 2549 configured with one conductor plus shield for the signal
ground and the other conductor for the signal, the capacity would be the sum of the conductor to conductor
plus the conductor to shield capacity (and that regardless, whether the shield would be connected on both
sides or on one side only).
2) In case you'd use both inner conductors together for the signal and the shield for the signal ground,
the actual capacity would be twice the conductor to shield capacity. And the fun thing is, even if you'd
just use one conductor for the signal and the other for the signal ground, while leaving the shield
unconnected on either side, the total capacity would now be the conductor to conductor capacity plus half
the conductor to shield capacity due to electrostatic induction.
Well, and with the Mogami 2534 things would become even more complicated due to even more inner conductors
and hence also even more possible configuration variants.
Thus I'd rather suggest you to keep it simple, and for example consider 2964 or 2546 instead.
Oba maju chracteristic impedance 75 Ohm, 2964 (57pF/m), 2546 (62pF/m). -
43 minutes ago, vladd said:
Ne znam koji su tip kondovi, ali ako nisu mica ili stirofleks(sumnja zbog 630V), ja bi ih sve poskidao, koji su u kontaktu sa signalom, i na ulazu u stampanu plocu, posle 47k, postavio jedan od 100pF, pa u konfiguraciji sa kablom, dodavao pikofarade i kontrolisao desavanja na visokim frekvencijama(ne moze svako da meri, ali moze da vidi kakav mu se zvuk dopada). Pojacalo inace ima finu koncepciju
Pa piše oznaka u šemi. Pored tih kondenzatora od 100 pF i 220 pF stoji slovo P, a legendi pri dnu piše P - Polypropylene film capacitor
1 hour ago, vladd said:
Obrati paznju na poziciju C1016 i C1017..dva konda na ulazu u MM preamp koji dramaticno menjaju kapacitivnost ulaza.
Nakupi se tu nekih 400-500pF, sa gajtanom naravno.
Pride i C1053 specificno utice na kapacitivnost, u petlji uzemljenja, preko onih rf blokera, nesto umanjene vrednosti.
Pa onda bi ukupna kapcitativnost MM preampa bi po shemi bila 420 pF po kanalu (C1052/53 i C1002/03) + (C1016/C1017) = 200 + 220. To mi izgleda malo preterano ?
Da li se iz sheme vidi koji otpornik za MM određuje load impedance od 47K. R1039/R1040 ?
1 hour ago, NIXIE said:
MM ulaz je rešen sa fetom, ne treba mu nikakav kondenzator jer se ne može pojaviti DC.
Misliš na Q1017/Q1018 ?
42 minutes ago, NIXIE said:
Jok, ta četiri koja vezuju masu kabla na kućište su za ukanjanje radio smetnji, odvode ih na kućište.
Nema tu DC komponente, glava je magnet u kalemu (MM) ili kalem u magnetu (MC), znači samo AC proizvodi kad se mrda.
DC može da dođe iz pretpojačala, zato je (najčešće, ima i drugih rešenja) blokiran kondenzatorom na ulazu preampa, koji se ne vidi na šemi.
Evo u prilogu je cela stranica iz manuala koja se odnosi na phono karticu. Pogledaj da li se tu vidi takav kondenzator.
On 7/17/2018 at 11:07 AM, NIXIE said:
Ne, taj ne diraj. Uradi kako ti je ZM rekao, skidaj one od 100pF paralelene ulazu (1052/53 1002/03), samo to ništa više. Prvo ona dva bliže ulazu, probaš kako zvuči, pa ako fali visokih skidaš i preostala dva. Može i obrnutim redom, svejedno.
Niste me razumeli ni ti ni ZM. Nisam hteo da skidam taj, nego sam pomislio da on zbog znatno većeg kapaciteta (100 nF, 16 V) u odnosu na (1052/53 1002/03) koji su po 100 pF, nije namenjen uklanjanju RF smetnji nego ukljanjanju DC komponente u ulaznom signalu ?
21 hours ago, Zen Mod said:
C1053 i C1002 u paralelu odredjuju ulazni kapacitet , govoreci o L kanalu
ovi drugi spajaju ulaznu masu phono sekcije na kuciste , sprecavanje RF smeca
Malo sam pažljivije pogledao šemu. C1001 je 100 nF, 16 V. Da on nije možda predviđen da ukloni DC komponentu iz ulaznog signala ? Pošto je mnogo većeg kapaciteta od C1002, C1053 i C10071 koji su po 100 pF i filtriraju RF smetnje ?
15 hours ago, sax.hifi said:
sto bi smanjivao ulaznu otpornost, optimum je 47k.
smanji ili ukini kapacitet.
Gde u phono preampu ili kraćim kablom ?
25 minutes ago, vladd said:
Ne zaboravis i kapacitivnost kabla da dodas, za sveukupan suma sumarum..
Znam za to. Samo po kalkulatoru sa Vinyl Engine sitea: http://www.vinylengine.com/cartridge_database_tools.php#CartridgeAmpElectricalLoading
a za AT 440 (490 mH, recommended load 47 kOhm) mogu najviše 222 pF da imam da 47 kOhm bude optimal loading. A 200 pF imam samo na phono ulazu. Znači ostaje mi samo 22 pF za interkonekt + tonearm wiring, što je neralno. Za nekih realnijih 350 pF ukupno (200 pF na phono ulazu + 150 za dovodne kablove), morao bih da ulaznu otpornost spustim na 37,4 kOhm. Može i to pomoću Y adaptera, sa otpornikom u paraleli.
OK, hvala.
Znači ukupno 200 pF, ako su oba po 100 pF ?
U kablovskoj distribuciji nemački Classic radio, subotom uveče puštaju jazz. Pored toga, a da vredi po kvalitetu emitovanog zvuka, Radio Beograd 2 i 3, nekad i prvi program. 202 jako varira u kvalitetu, mada je ponekad jako dobar.
Trenutno na sajtu 3 članova, 1 Skrivenih, 14 Gosta (Pogledaj celu listu)
Ukupan broj tema434.6k
Da li pojačala moraju uvek da se priključe na schuko zidnu utičnicu ??
in Hi-Fi audio
Pitanje se odnosi na ona pojačala koja imaju IEC utičnicu sa 2 pina, znači bez uzemljenja. Takođe imaju na zadnjoj strani i onaj znak za dvostruko oklapanje (dva kvadrata, jedan u drugom) ?
