sir Oliver
Sve objavljeno od sir Oliver
  1. Ajde nova tema o arrayima a ovde da se samo jaganjci i vuci baskare.
  2. Divergirate mi od teme. Pricamo kako se El Cheepo Philips prepakuje u El Grande McIntosh.
  3. To su zvali Isoplanar tehnologija, ako se ne varam. Bilo je dosta slicnih resenja.
  4. Ovde sigurno ima dovoljno
  5. Ozbiljno, ima li ko da iznese iskustva sa Philips T8 driverom?
  6. I sta si mu rek'o?
  7. Evo lepse slike
  8. Opet McIntosh i opet PHILIPS. Ovaj put legendarni visokotonac T8 sa Mekovom maskom. 1" Dome Tweeter 036-068 This soft fabric dome tweeter is made by Philips and is similar to the round Philips AD 0141HE-T8 but is custom made for McIntosh. The rectangular shape is custom made for Mcintosh. This allows closer spacing of the tweeters then used in multiples for the column systems. The black plastic front plate has a phasing disc in the center that smoothes the response, improves directionality and also protects the dome from being damaged. A recessed area near the bottom is for an aluminum silk-screened decal with the McIntosh name in gold lettering. The soft dome, voice coil, tinsel leads and terminals are one subassembly called a "butterfly." The tinsel leads are brought out to terminals on either end of the subassembly. Some versions had solid wire instead of tinsel wire. A red mark can be seen on the upper left part of the assembly that indicates the positive terminal. The fabric of the dome and surround has a black colored coating to seal the interstices of the material. A second custom coating under the dome was made only for McIntosh. This completely damps out the fundamental resonance. Two holes in the butterfly locate with pins on the magnet structure. These assemblies are interchangeable and a damaged butterfly assembly can be easily replaced by removing three screws from the front plate and adding the new one. The rainbow colors are from the plating process. The magnet assembly is made of three parts. The back plate and pole piece is made from one piece of cold formed steel. The magnet is barrium ferrite. The front plate is stamped steel. The two locating pins and three screw holes can be seen in the picture. The center of the pole piece is recessed for an increased air volume behind the dome. We sampled a version using Ferrofluid in the magnetic gap. This raised the resonant frequency and limited the useful low frequency response of the tweeter and that was not acceptable. Later, we found that the ferrofluid had dissolved the adhesive that held the voice coil to the dome assembly. The problem was said to have been corrected by Philips in later production. Ferrofluid is a mixture of finely ground magnetic particles suspended in a viscous fluid. It is kept in place by the magnetic field in the gap. It is used to keep the voice coil temperature down and transfer the heat to the magnet structure. It was not used with this tweeter or any other tweeter until 1993, starting with the 036-095. A McIntosh part number label is added to the tweeter after is has been tested. The tweeter is 3-11/16" X 3-1/8" and 1" deep. Weight is 262 grams or about 9.2 ounces. It is used in the XRT18 and XR290. This tweeter was no longer used for designs made after 1992.
  9. Is this a can? No this is a car “Ozone” is a concept future vehicle i designed for Peugeot design contest . The concept was based on the words; ecological, lively, simple, accessible and pleasurable. “Ozone” is a hydrogen powered fuel cell transportation vehicle. The huge wheels of ozone is controlled by two seperate electric motor powered by fuel cells. “Ozone” with semi transparent glassses. It offers a great interior volume and exterior view. Huge glass doors slides 360 degree into its symetric metal body. Motors are controlled with a joystick panel in the dash. Read more: http://funkydowntown.com/ozone-hydrogen-powered-car/#ixzz10wJgekts
  10. sir Oliver
    Prodajem
    Ja bih HDD ako ima i ako je ATA.
  11. sir Oliver
    Ecotherm clone
    Kad sam video naziv teme a i ime pokretaca iste, rekoh sebi: Stein je sredio potkrovlje i termicki ga izolovao
  12. sir Oliver
    Prilagodni trafo
    Zasto mora procep?
  13. sir Oliver
    Prilagodni trafo
    Primari mogu da se iskoriste kao choke za neko ispravljanje za neki CLC LCL
  14. Kaze se "Hladno ko tastina dusa"
  15. sir Oliver
    Head Amp
    a tube?
  16. sir Oliver
    Head Amp
    Ko o cemu, baba o ustipcima a ja o OPA2111 http://www.free-circ...t-using-op-amp/ Ili nesto mnogo prosto https://www.electric...hite-jrc4556ad/ Osim ako neces vakuum ( 250 V na glavu da stafis)
  17. Kako idu Cabasse na vakuum? Je si li probao?A umesto dva Cabasse da si uzo Tannoy i da te bog vidi ( jos i put u Goteborg)
  18. Ziko, ajde ovde cemo. Pa sta radis sa dva para istih zvucnika? U istoj sobi slusas?
  19. Kao pravi DIYeri trebali bi da sami napravimo taj oberfrezer :Viannen_loungelizard:Bez zezanja sad se setih da neki moji drugari napravili koordinatnu busilicu ( XYZ) i koriste je za busenje PCBa. Jedan od njih posle na Z osu stavio jaci motor i frezer pa radi vratanca za kuhinjske elemente i tako neke sare. Na kraju zavrsio sa slikama koje enbosira ( napravio i driver za slike iz CORELa i Photohopa). Ubi se od ikona i svetaca. Ide ko alva.Pa da ga pitam kolko bi bilo metar reza na njegovoj "svajsovanoj" emboserki?
  20. sir Oliver
    Licencirani XP pro
    http://www.kupujemprodajem.com/Windows-XP-HOME-312835-oglas.htm
  21. Mislim da je CNC preteran za ovaj zadatak.Sasvim dovoljna je ona obicna stolarska masina sa ravnom plocom i osov\nom koja viri iz nje na koju se stavi glodalo. Svaki ozbiljniji stolar je ima. Daska ( iverica, panel ploca mediapan..) se gura po stolu levo desno, napred nazad a glodalo sece zeljeni oblik.
  • Trenutno na sajtu   1 član, 0 Skrivenih, 1020 Gosta (Pogledaj celu listu)
    452.2k
    Sanjalica
    Sanjalica
