revox
Sve objavljeno od revox
  1. i za el84možda nekome bude od koristi
  2. pošto pored ecc83 koristim el84 i gz34 za ovo što se pravi evo podataka prvo za gz34gz34-philips.pdf
  3. primljeno k`znanju, taman mi tako odgovara metnut će se ipak nešto dok se ne prigriju bar zimi. Za ljeto će se ugrade ventilatori da ik lade.Ipravljačica je gz34
  4. Pošto se sklapa jedno PP EL84 to znači da bi bilo upunto metnut prekidač za grijanje ili napravit neki skolop koji bi po obavljenom grijanju uključio radne napone.Koji vremenski period ostavit za grijanje lampi pri svakom uključenju ?
  5. Slažem se sa tobom oko strpljenja i ne pada mi napamet da bilo šta pokušam sa običnim cd-ima,mada u service manuelu vidim da ima i komandu na vraćanje na fabričko podešavanje.Probaću sa ovim likovima iz sony servisa -Input - u BG da ga pošaljem tamo možda oni mogu i znaju da ga podese da čita i cdr jer svi drugi plejeri čitaju.
  6. nađoh ovo na netu SONY XB940QS transport adjustments for non-technicians. This procedure is to correct the situation of a 940 not reading one or more types of disc, and/or not being willing to switch between layers in a hybrid disc. It does not require the case to be opened or any tools used. The transport used in this QS range player is minimalist at best, and seems eager go out of adjustment from heat, ageing and general use. Performing these adjustments may save you a trip to the service center and a painful wait without music… Please note that these steps are only for the 940, although other SONY players have a similar procedure. Their steps are contained in their respective service manuals, and I only publish this as the regular 940 manual doesnt contain them The official procedure requires unobtianium test CDs, but Ive found you dont need them to get the job done. What youll need at hand is: 1/ A single layer SACD I use any of the early SONY remasters that come in the grey paper sleeve. 2/ A regular CD Its best to use an older one, some new ones may have some copy protection BS that messes things up. 3/ A hybrid SACD 4/ And if possible, a double layer SACDmore on that later. Start with no disc in the tray and the machine OFF. 1/ Put the 940 into Test Mode by doing these steps: a/ HOLD down the AMS controller knob, b/ turn the machine ON c/ and while keeping the AMS held down, PRESS the STOP button. d/ Let go of everything. The display will read Test Mode Menu if you ve done this right. 2/ ROTATE the AMS one click clockwise, 1. Auto Adjust shows. 3/ PUSH the AMS Auto Adj Menu shows. 4/ ROTATE the AMS two clicks clockwise, 1. SACD SL shows. 5/ PUSH the AMS, the tray opens, and Set SACD SL 12 shows, so load in a single layer SACD. 6/ PUSH the AMS, tray closes, all sorts of things happen, tray opens. Remove Disc shows. 7/ Remove the SACD and PUSH the AMS. The tray closes. 1. SACD SL shows again and the pure SACD step is done.. 8/ ROTATE the AMS one click clockwise, 2. CD shows. 9/ PUSH the AMS, the tray opens and Set CD 12 shows. Load in a standard (non CDR) music CD. 10/ PUSH the AMS, again the tray close and opens. Remove Disc shows. 11/ Remove the CD and PUSH the AMS. The tray closes. 2. CD shows again so the CD calibration step is done. 12/ ROTATE the AMS one click clockwise, 3. SACD DL shows. This means it wants a double layer SACD, and I don t know how to recognise them from markings on the disc itself or it s packaging. But I read on HiRez Forum that the Hillary Hahn Brahms/Stravinsky Violin Concertos(SONY SS89649) is a DL, and it is accepted by the 940 for this test. Using any other SACD I ve tried here gives an error message. 9/ With this disc, or another known DL, repeat the steps as above. If you don t have a DL disc, bypass this step by going to step 10. 10/ ROTATE the AMS one click clockwise, and 4. HYBRID shows. 11/ PRESS the AMS and repeat the same procedure as above. 12/ When 4. HYBRID shows again, you are DONE! The full technician procedure will be posted on our site sometime as there are more steps, but these are what are needed to solve 99% of the transport problems, and all I really want to translate from Japlish tecno speak at this (or any) time. Good Hunting, Allen e sad mi samo nije jasno da li lik misli da se to može podešavati bez test cd koji Sony preporučuje, odnsno da li se to radi sa običnim cd snimljenim cdom jer sony navodi da za podešavanja se koriste njegovi cd-i 1. TEST MODE Jigs • Disc Model Type *1 Category Application HLX-503/ SL 12 cm adjustment and check HLX-504 HLX-501/ DL 12 cm adjustment and check HLX-505 PATD-012 CD 12 cm adjustment and check HYBRID 12 cm adjustment and check -L1 HYBRID 12 cm adjustment and check -L0 SL 8 cm Check CD 8 cm Check HYBRID 8 cm Check -L1
  7. vrteći po netu vidim da su jedino u ovaj player ograničili šta vidi - sacd cd i cd, ostali njihovi pleyeri iz serije scd-xb vide i cdr i cdrw.Ima li tu lijeka ?Mislim jel se to definiše nekim programom ili zavisi od lasera ili nešto treće i može li se što učinjet da "progleda"?
  8. Drug moj bilo je tu raznih kombinacija u ovih mjesec i kusur dana, od totalno nerealnih do ove koja pade u subotu.Mislim to je bila ponuda koja se ne odbija.
  9. RADI radi i to neviđeno, jedino što ne mogu koristit neke filtere digitalne koje su stavili kao da se zvuk prilagodi muzici koja se sluša ovako radi na standard što mu je to nemam pojam al dobro zvuči Jedina mana definitivno - ne čita rezance i bugare samo regularne diskove to mu uostalom piše i u prospektu ne vidi CD-ROM, CD-R, CD-RW ect. Šo ćeš ovi iz Sony-a vazda maltretiraju sa tim zaštitama kontra piraterije evo što je u njemu i malo karakteristika CD Mechanism type: CDM55B-DVBU3 Base unit name: DVBU3 Optical pick-up name: KHM-220AAA/J1N Frequency response: 2Hz to 50kHz Dynamic range: 103dB or more Total harmonic distortion: 0.0015% Wow and flutter: 0.001% W Peak Dimensions: 430 x 115 x 290mm Weight: 5.5kg a evo i kako izgleda Otvaro ga gledio pun ko šipak i viđeh dva mrežna trafoa, očigledno nisu šteđeli i na kraju više nego zadovoljan obzirom da je za njega dat Teac w6000r dupli dek.
  10. revox
    Hitachi HA3500
  11. Oglas može pod ključodustao od prodajecijene koje se nude neprihvatljivekupljena dva izlazna trafoa i mrežni trafo Ipak će biti sklopljeno pojačalo
  12. čisto me zanima o kom uređaju se ođe radi i vredi li ovo te parehttp://www.kupujemprodajem.com/BC-audio-354390-oglas.htm?filter_id=5140ide odvojeno napajanje lampaško i posebno ovaj izlazni stepennaravno ako ko zna o čemu se radi
  13. revox
    Lepota dizajna
    I ja sam se ložio na cs 300 pp el84 sve dok nisam vidio cijenu šoooooo mu je cijena 2000 jevrića PS ovaj 600 je isti kao 300 spolja
  14. ima li što da nemaš mislim pored svega što imaš pa i dekova rastavljenih u djelove radi lakšeg lagerovanja
  15. revox
    Lepota dizajna
    čak šta više ovo boli kolko je lijepo
  16. Sve ti je ovo tačno al po meni ne važi jedino za cyrus one i two pojačalae tu nisu šteđeli ni na trafu ni na limu pošto je liveni aluminijum kompletno pojačalo /5-6 kg teško/.Čini mi se ni načemu nisu šteđeliJedino su pot i svičeri malo problematičniRadi po 15 sati ni da se ugrije-Neviđeno.Ostalo je okTo sam i mislio da Nerru pšredložim da pogleda kad kupuje,naravno ako mu 2x50W CYRUS TWO odgovara snagom.Ja imam cyrus one /25w/ već 20 godina i ništa ali bukvalno ništa mu nije mijenjano.Narvano slušan je sa razumnim snagama nikad preko pola hoda potaako bi našao cyrus two i da je očuvan da valja to bi mu bila dobra trgovina naravno sa malo efikasnijim zvučnicima.
  17. Pazi care na pogrešnom si forumu za tu vrstu savjeta. Ovi ovde na to ne daju abera. Prave sami što im padne na pamet. Možeš mislit kad sve rastave i sastave i to opet proradi i još otvore raspravu kako, šta i zašto radi-zašto tako a ne ovako i kako bi radilo kad bi mu s promjenilo ovo i stavilo ono i tako to da ti ne pričam. Nego care, ako ti se ne bacju pare, nabavi ti nešto uređaja, što ti treba, iz osamdesetih pa fino dadni nekome od forumaša da to sredi, osveži imjenja sve što treba a bogami malo i unaprijedi i veseli te bože. Imaćeš šta da slušaš , nisi bacio pare a ostaće to i unucma da svira
  18. a snaga 20-30 w?
  19. izgleda da si u pravu
  20. jel misliš na tascam 32nije valjda da imaš i njega
  21. Ovo je već zabrinjavajuće ako se prišetimo da imamo i isti tjuner Technics
  22. juče dobih technics rs-bx701 u top stanju i aiwa adf 850 koju valja srediti /čišćenje i promjena gumenih djelova/ inače je za 120v pa uz nju dođe i step down ispravljačšto će mi ne znam - nek se nađe technics radi kao bombon ima simpa kalibraciju
  23. Može kompenzacija ako neko ima Minolta opreme, autofokusnih objektiva Minolta ...........
  24. čisto da podsjetim i dalje sve aktuelno
  25. revox
    8200mf50v
    može ključ nabavljeno
  • Trenutno na sajtu   3 članova, 1 Skrivenih, 127 Gosta (Pogledaj celu listu)
    452.8k
