40966 -
627
Sve objavljeno od Zen Mod
SissySIT P ..... or how I proved fact of making more Hats than Pa did
Zen Mod je odgovorio/la Zen Mod's temus u Solid State
pa, po merenjima ..... uporedi sa sebi omiljetim ce vidimo za slusanje -
How it sounds? Well, as close Cousin ( younger one) of Babelfish XA252 SIT Good enough for Mighty Moi -
Proof is in da Pudding ( or how me Mom always said - eat your Porridge if you wanna grow strong and handsome!) Rails +/-24Vdc-ish, Iq 1A7-ish Load 8R -
temu je objavio/la Zen Mod u Solid State
https://www.diyaudio.com/community/threads/sissysit-p-or-how-i-proved-fact-of-making-more-hats-than-pa-did.385400/#post-7000665 Well, anyone at least partially partial with my omnipresent babbling, knows about endless series of M2 derivatives, I made sorta recently All of them having M2-like Front End (my biggest Fetish), so entire voltage gain got from autoformer, so no (overall) NFB involved Also - all of them having second of my recent Fetishes - Square Law OS Ok, that is line of unnecessary long line of M2 derivatives, difference being that each is having different quirk of OS parts Then came next fixation point... when I concocted FE for Babelfish XA252, biggest part of invention was proper name for same FE - Plethora of Pinjatas ....... so I ( naturally) came to idea of making second totally unnecessary line of derivatives, now having Plethora of Pinjatas FE, and simply varying already proven SL OS iterations This line having slightly different ( sorta mirrored/flipped/downundered/whatever) biasing mechanimus, comparing to older specimens, this one directly taken form Babelfish XA252 Comparing to older ones ( having opto between Mosfet Gates and fixed resistors from rails to gates), there are current mirrors from rails to fixed resistor(s) between Mosfet gates; result is better Iq behavior in domain of rails change, same as better Iq behavior in thermal change domain, and also firmer relaxation factor (Iq stability in dynamic domain; think recovery time if change occurs with long large signal) Anyway, let's ignore Babelfish XA252 as first one, declare SissySIT P (P suffix for Plethora of Pinjatas family) as first one Am I happy ...... yes! (this one done, so I can think of working on next ) Confirming same amp sound character, for amps made without NFB and with Autoformer gain and amps made with sorta heavy NFB and active gain ....... well, not exactly a novelty per se this post intentionally made pic-less - in case of later edits, lesser mess -
-kako Bosanac dere zeca? -nikako; nabije ga na spolovilo i on se sam dere msm, tu sad moze i varijacija na temu..... -kako Ninja dere zeca? -nikako, Hanuma i to uradi, kao i sve ostalo, da ne bi Ninja sto zaebo
smrzo se on sam i ceo, cim je oziveo i shvatio ko mu Tatko ono, ko kad Bosanac dere zeca
pre nekog vremena, u etapi ponovne konzuacije video sadrzaja nakon duge apstinencije, odgledao Enola Holms msm zabavna razbbriga, dovoljno drugacija od sveopsteg mulja zainteresovao se za lik i delo mladjane Millie Bobby Brown, pa skontao da su joj poceci u Stranger Things (TV Series 2016– ) - IMDb WWW.IMDB.COM Stranger Things: Created by Matt Duffer, Ross Duffer. With Winona Ryder, David Harbour, Finn Wolfhard, Millie Bobby Brown. When a young boy disappears, his mother, a police chief and his friends must confront terrifying supernatural forces in order to get him back. 'blo me bingovanje, prespavah danas ceo dan mala Millie je stvarno neobicno stvorenje, Winona Ryder po obicaju briljira sve u svemu, stripovskom umu kao sto je moj, ovo je ihaj vise nego dovoljno dobro a Millie ce cuda da napravi, samo da je buducnost ne odvede u svet ciste komercijale
sa prakticne strane ja vise volem relay opciju kao prvo, licno vise verujem u diskretno preklapanje otporne matrice nego poluprovodnicko, drugo manja komplikacija u kodovanju, trece ne zavisim od nabavke Muse aha, i ako imam razvijen takav atenuator ( a imam , trenutno inkorporiran u Irreverent i INT), meni licno je univerzalniji nego Muse
@zerowaf vis da je em gluv em udaren binuj ga na nedelju dana, zbog neaktivnosti
sve je to manje vise isto ..... generalno slican koncept, isti ili slicni aktivni delovi tamo gde se decaci odvajaju od muskaraca je sama implementacija - kako su uradjene pcbs i rutiranje generalno, kako je uradjeno napajanje sve jedan Nelsonov (Wayne-ov) low & line level signal stage bolje zvuci kad ga nakacis na posten shunt reg to sto oni prodaju ovako kako prodaju ........ pa nije red da odmah naprave najbolje sto se moze, sta ce sutra prodavati ? a ima i to da su obojica trvdoglavi i smatraju da shunt regs nisu bolji od serijskih kao sto sam ja tvrdoglav pa smatram suprotno al, ajd sad - kuj uspesan HiEnd proizvodjac - oni sa svojim stanovistem , ili ja sa mojim ? mda, mozemo da pricamo o konceptima do prekosutra ....... al ako pricamo o uredjaju kao celom - cim vidim unutra resistivni attenuator, nema potrebe da pricam vise o istom
ce skinemo
jeftiniju
Influjenser, msm, kako drugacije?
zato sto mi nisi poslao potrebne trola zice
Tokini su se koristili za kontrolere motora liftova, naponske pretvarace, pojacivace u ultrazvucnim kadama ( onim industrijskim od 50L navise), predajna oprema neki kazu i za radare, al necemo sad preterivati .... nemamo dokaze u pisanom obliku
cheapskate kaze - kuca mu manje od P+3, pa mu ne trebaju oni elevatorski tranziporti a kad vec placa, bolje da dobije 25 nego 18W
Trenutno na sajtu 5 članova, 1 Skrivenih, 118 Gosta (Pogledaj celu listu)
Ukupan broj tema454k
