47005 -
661
Sve objavljeno od Mikorist
1. Da li koristite tonske kontrole ?2. Da li sve tonske "nedostatke" resavate novim komponentama ?3. Ako imate tonske kontrole da li ih drzite na 0 - odnosno iskljucenim ?
jos ce da ispadne da smo bolji Hi-Fi sti od Fi-Fi sta :JC_moon:leb te ........
patkometrija :sarcastic_hand:ljudi zapisujem sve odavde i bacam tamo
daj jos ruznog dobro je
first watt
upucaj ga
kako ce ove lampe da `drndaju` preko 150BPM znas nasta mislim ipak sam za sporet varijantu sa fet ili mos-fetima
Hvala puno zelja da ti se ispuni
samo da znate kako je sve ne modifikuju: We've previously been scathing about soundcards: “Don't buy one, the only place for a DAC is outside a PC, abolish PCI for music, etc”. But for this one, we had to make an exception. If you really can't live with an off-board digital to analog converter, this Burson-modified card, distributed in the UK and Europe uniquely by Item Audio, is the only one to have. The Audiotrak Prodigy HD2 in stock form is one of the best sounding cards available for two channel audiophile playback, but the HD2-SE is seriously hot-rodded for uncompromised performance. The HD2 incorporates many audiophile grade features: a low jitter oscillator, short signal paths, specialised power caps, and a fully differential output stage. It supports 192 kHz at 24-bit, with a sensational dynamic range of 120dB for playback. No other hardware in this price range provides this high level of output quality. The single most intractable problem for soundcards is noise and interference. Audiotrak caims to have resolved this issue completely with their PNK technology (PCI Noise Killer). Few external USB DACs in the market can match the Prodigy's attention to detail. However, the Special Edition is an entirely different animal. For starters, the NE5532 op-amps have been replaced with no less than three fully discreet Burson Audio dual opamps – regarded by audiophiles and the recording industry as simply the best alternative to IC opamps. Their performance significantly surpasses the once popular OPA627. This mod alone pushes the design complexity of the HD2 beyond many audiophile DACs or CD players. Naturally the power supply of the HD2 has also been optimized for the Burson Opamps. Close inspection revealed that the 'gold RCA connectors' of the standard unit were low grade plated aluminium connectors with poor quality soldering. So out they came in favour of top notch CNC RCA sockets which were more widely spaced to accommodate high quality single ended cables. Compared to the stock version, the supercharged soundcard projects a much wider soundstage. Mids and highs are fuller and more realistically drawn. Fine detail and subtle intonations can now be heard and analysed at a micro level. The bass goes deeper and, more importantly, gains control and definition. The card comes complete with ASIO 2, GSIF and WDM drivers for Windows versions. Please note that Apple Mac drivers are not presently available. We believe its the finest soundcard a discerning listener can buy, and it's the only one we are likely to offer in the forseeable future. We also think it's a bargain! “I think it's worth every penny. Absolutely fantastic! What a beautiful sound. Thanks!” – JW http://www.itemaudio.co.uk/prodigy_hd2.html ima i gorih od mene
za mene su naucna fantastika ovi ADAM S2.5A monitori i ovo pojacalo Behringer A500 preko koje je testirano.... Babel peva samo tako zakacen direktno na karticu
evo ti neka merenja ako ti to znaci :Objective measurements RMAA measurements are quite low. It has to do with low Loop values because of the ADC. And the spectrum shows additional noises, when tested via other cards. High noise is registered not only in the test with the E-MU1212m, but also with the E-MU1616m and the Lynx Aurora8 - the latter have external power supply. To check it up, we have run the E-MU1616m >> Lynx Aurora8 test - we've got clear spectrum even with a usual non-balanced cable. The other cards (X-Fi Elite Pro and Juli@) were also tested in the same system unit. The Juli@ shows a clean spectrum, the X-Fi Elite Pro - dirty. These noises are most likely caused by non-optimal layout of the ground. When connected to another device, all noises do not go to the ground, but through analog outputs to the ground of the other card. The E-MU1616m has a special ground screw on the external unit to flush all noises down to the ground, by-passing analog inputs. If a tested device does not have a similar ground connector, it won't be able to suppress noises completely. This can be illustrated by plugging computers to different mains sockets. If a mains socket is not grounded, a discharge may burn your card's inputs and outputs, when you hot-plug it. It happens a lot. You should also pay attention to PC cases - they are often made of riveted thin metal sheets. Grounding in these PC cases is highly inefficient, even if you have a high quality PSU. We'll review this problem in detail in a separate article. My point is that you can take readings with minimal noises, but it does not mean that the problem is gone on its own. Have a look at the Prodigy HD2 >> E-MU1212m readings. The noise level rises at 5 kHz. Then we plugged the Behringer A500 amplifier to the cards with it volume set to maximum. It was a non-balanced connection for both cards. The microphone registered noises generated by the cards. We can see the same rise in the spectrum. The E-MU1212m catches fewer interferences. You can hear them only in gaps at high signal amplification. You won't hear the interferences in a common situation. That's the case when numbers do not reflect characteristics directly. So you should pay attention to spectrums only. When we tested the ProdigyHD2 with the E-MU1616m, we managed to squeeze 110 dB versus official 120 dB. It's a good result. Audiotrak notes that the card uses the PNK technology (PCI Noise Killer). We can see that it does not work well, perhaps this optimization works better in Japan and Korea. It must be also mentioned that the card was redesigned a little after the first revision. It may be a tad simplified. We also come to a conclusion that power filtering is implemented better in the E-MU1212m and Juli@, which do not use advertised technologies. You must understand that signal-independent noise does not affect signal quality. RightMark Audio Analyzer Report DeviceProdigy HD2 >> E-MU1616m Dock A/BMode24-bit, 44 kHzAudio interface Signal pathExternal loopback (line-out - line-in)RMAA Version6.0.5 PRO 20 Hz - 20 kHz filter YESSignal normalizationYESDeviation-0.1 dB / -0.1 dBMONONOFrequency of the calibration signal, Hz1000Polarityright/wrong General results Frequency response (from 40 Hz to 15 kHz), dB +0.01, -0.17 Very good Noise level, dB (A) -110.3 Excellent Dynamic range, dB (A) 110.4 Excellent THD, % 0.0012 Excellent Harmonic distortion + noise, dB(A) -92.4 Very good Intermodulation distortion + noise, % 0.0024 Excellent Channel crosstalk, dB -111.2 Excellent IMD at 10 kHz, % 0.0018 Excellent General performance Excellent RightMark Audio Analyzer Report DeviceProdigy HD2 >> E-MU1616m Dock A/BMode24-bit, 192 kHzAudio interface Signal pathExternal loopback (line-out - line-in)RMAA Version6.0.5 PRO 20 Hz - 20 kHz filter YESSignal normalizationYESDeviation-0.1 dB / -0.1 dBMONONOFrequency of the calibration signal, Hz1000Polarityright/wrong General results Frequency response (from 40 Hz to 15 kHz), dB +0.02, -0.15 Very good Noise level, dB (A) -109.1 Excellent Dynamic range, dB (A) 109.1 Excellent THD, % 0.0012 Excellent Harmonic distortion + noise, dB(A) -92.3 Very good Intermodulation distortion + noise, % 0.0022 Excellent Channel crosstalk, dB -104.4 Excellent IMD at 10 kHz, % 0.0017 Excellent General performance Excellent Subjective audition E-MU1616m vs Prodigy HD2 Gold vs Aurora8 The E-MU1616m is a multi-channel professional card. Its audio quality is similar to that of the E-MU1212m, which has fewer input and output channels. So results of the E-MU1616m vs ProdigyHD2 comparison will be similar to that of E-MU1212m vs ProdigyHD2. The LynxStudio Aurora8 + LynxStudio AES16 is a complex solution - "digital card" + "external multi-channel DAC+ADC". The price is high owing to specific studio functions. Approximation of sound quality and price is not a good idea for professional cards. The LynxStudio Aurora 8 was used as a reference device and a switchboard to re-route signals to the ADAM S2.5A monitors. Tests were conducted by Maxim Liadov and Roman Kuznetsov. The DBT (double-blind test) shows that the E-MU1616m and ProdigyHD2 play on the same level. The difference in audio quality is insignificant. The Aurora8 sounds better, offering more details and a better attack. However, the difference between the Aurora8, the E-MU1616m, and the ProdigyHD2 is clearly noticeable only in some tracks. So does it really make sense to hunt after higher quality in hardly noticeable nuances? It's up to our readers to decide. Conclusions This card is a high quality top product from Audiotrak. There is weak competition in the Hi-End market of sound cards, so the direct rivals are only the X-Fi Elite Pro and the E-MU1212m. Unlike the X-Fi Elite Pro, drivers of the Prodigy HD2 are more professional, and have a simpler control panel than for the E-MU1212m. What concerns games, the card fares in between high quality sound processing in the X-Fi and no 3D audio support in the E-MU1212m. Unlike the E-MU1212m and X-Fi Elite Pro, the ProdigyHD2 is a low-profile card, so it can be used in compact HTPCs. Another advantage of this card versus the 1212m is its built-in preamp for headphones. http://ixbtlabs.com/...test-page4.html
http://www.player.rs...gory.php?ID=369imas i M Audio koja je izuzetna isto a ima i moja - Audiotrak Prodigy 7. HiFi 8690 din (naravno mora da se nadogradi da bi bolje svirala) http://www.player.rs...uct.php?ID=1785 slusao sam ih sve i ne znam sta da ti kazem sem da je najbolja Audiotrak Prodigy HD2 (za moje uvo) http://www.audiotrak...cts/prodigyhd2/ model koji nema da se kupi ovde - i skupa je u odnosu na sve ove jer ima samo dva kanala Nema bolje kartice koja svira pod Linux-om to mogu da potpisem
Izgleda da su nestali dok sam cacko po bazi.....
Intel D510MO Mini-ITX Motherboard velicina 1:1 » Model: D510MO» Processor: Intel Atom Processor D510 Quad (Dual Core), 1.66GHz » Chipset: Intel NM10 Express Chipset (TigerPoint) » L2 Cache: 512 KB x 2 L2 Cashe » System Memory: Single channel DDR2 800/667 MHz, 2x DIMMs (max 4GB) » Graphics: Integrated graphic VGA port & on board LVDS (optional) » Power: 24 Pin ATX » Connectors (rear): » 1x D-SUB15 (VGA) » 1x LAN 10/100/1000MBit (Realtek) » 3x Sound (Line Out, Line In, Microphone) » 2x PS2 » 4x USB2.0 » Audio: Realtek High Definition Audio (ALC) Incl multi-stream support » Connectors (internal): » 1x PCI » 1x Mini PCIex » AUDIO (Front panel) » AUDIO (SPDIF) » 3x USB » 2x SATA (3GBs) » 2x COM (Serial) » 1x Parallel » Included: » D510MO Main board (with 1.66Ghz Atom N510 CPU) » I/O ATX rear plate » SATA cable » Drivers CD » Form Factor: mini-ITX (170mm X 170mm) » Thermal solution: Passive, Z-height 35mm » Additional comments: » Windows Vista Basic WHQL certified » Windows 7 Starter/ Home basic support + taman jedan slot za zvucnu
ajde da (na)pravimo ovo napajanje :scratch_head:ne lici mi na rocket science :sarcastic_hand:odavno zelim da napravim jedno DIY za sva vremena
Presently, FLUENT can translate Chinese, Korean, Portuguese, Russian, Serbo-Croatian and Ukrainian, Reuters says.http://www.theregister.co.uk/2001/03/06/cia_patching_echelon_shortcomings/
Echelon, under U.S.'s NSA and other world superpowers, can intercept two billion phone calls per day, along with faxes and e-mails and other electronic communications. http://www.greaterth...ations/Echelon/ kakvu oni tehnologiju koriste i koje OS-ove ?
ali bate na 3 kontinenta
patkometrija
ima i cetvrti nacin: (meni sluzi za eksperimentisanje sa sistemima i instaliranje) MultiBoot ISO http://www.pendrivel...-multiboot-usb/ radi kroz tool koji se zove GRUB4DOS njime se i bavi izmedju ostalog detaljno http://www.boot-land.net/ na cijem se serveru nalazimo
pa Mac je taj Svemir na kome se nalazim sad
sto se mene tice moze i mac na pc :http://lifehacker.com/5360150/install-snow-leopard-on-your-hackintosh-pc-no-hacking-required:buehehe:
neki od komentara odatle........ocigledno da su podeljena misljenja :scratch_head:pasce cena tom uredjaju za 6-12 meseci sigurno
minika nije Engleski zvuk no Srpski + nemam ovako dobre zvucnike ......... :blackeye:no minika ovo sije za medalju :Viannen_loungelizard:EDITOpis kako zvuci Mini Babelfish J dao sam ovde koga zanima:http://www.diyaudio....ndpost__p__8726
Trenutno na sajtu 1 član, 0 Skrivenih, 41 Gosta (Pogledaj celu listu)
Ukupan broj tema452.7k
