Sign in to follow this
revox
sonic frontiers anthem pre 1L
Recommended Posts
ima veze koje se dje stavljaju ... ima prednji I zadnji par
Back pair = closer to rear panel. Front pair = closer to front panel.
I kao bolje lampe idu na zadnji par kaze lik iz upscaleaudio - Kevin Deal:
the Pre-2L and Pre-2LSE both pairs of tubes are voltage gain. One may be more pleasing to upgrade than the other for you. There are no rules to that. Try it for yourself.
In the Line 1 and Line 2 we seemed to get the best results by changing just the rear pair. This in an effort to get the most bang for the buck and not do all six tubes.
The good news is that both preamps are such that you can mix and match. Just make sure that each pair are the same. So you can put Russian 6922 in one position and 7308, 6922, 6DJ8, CCa, etc in another.
https://forum.audiogon.com/discussions/anthem-pre-2l-tube-rolling-question
Share this post
Link to post
Share on other sites
Prvo kaže možda je bolje, pa onda da nema pravila.:krstix:
Share this post
Link to post
na
AR PH3SE riaa izlazna impedanca 200 ohms, rated output 0,5V
a na ulazu u preamp
ulazna impedanca 40 kOhm podesiv gain 8-16-24 db
Jel ovo kompatibilno il ce bude problema
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
