Speed Up Firefox
Mikorist
type “about:config” in the address bar of your firefoxnglayout.initialpaint.delay = 0 integercontent.notify.interval = 500000content.notify.ontimer = true Boolean valuecontent.max.tokenizing.time = 1500000(default value: triple the value ofcontent.notify.interval)content.interrupt.parsing = truecontent.switch.threshold = 500000 integer (default:750000)content.maxtextrun : 8191content.notify.backoffcount : 5browser.search.openintab = true Boolean valuelayout.word_select.eat_space_to_next_word = false Boolean valuenetwork.http.max-connections = 48 integer (default:30)network.http.max-connections-per-server = 16 integer (default:15)network.http.max-persistent-connections-per-server = 8 integer (default:6)network.http.request.max-start-delay = 0 integer (default:10)network.http.pipelining = true Boolean value (default:false)network.http.pipelining.maxrequests = 8 integer (default:4)network.prefetch-next = false Boolean value (default:true)browser.cache.memory.enable = true Boolean valuebrowser.cache.memory.capacity = 1 GB RAM – 184322 GB RAM – 245764 GB RAM – 30720browser.sessionhistory.max_entries = 5 (default:50)browser.sessionhistory.max_total_viewers = 0 (zero) to disable session history.This will reduce your Ram consumption by a 50%.(default:-1)config.trim_on_minimize = true Boolean valuesigned.applets.codebase_principal_support : true (default:false)plugin.expose_full_path : true (default:false)ui.submenuDelay = 0 (zero)optional:network.http.keep-alive = true (it is the default value)network.http.keep-alive.timeout = 600 (default: 115 on XP)network.dnsCacheExpiration = 3600network.dnsCacheEntries = 1000restart your firefox and feel the speed faster than a speeding bullet…
  • Odgovora 5
Popularni dani
