chakija Napisano April 4, 2021 #1 Napisano April 4, 2021 Ako nekome stoji u šteku, rad sam da ga rešim muke... Treba mi PCB sa regulatorima.
ManicP Napisano April 4, 2021 #2 Napisano April 4, 2021 Član voruma vukashin će imati nešto u narednom periodu pa je to adresa za pitati. Samo neće biti baš odma chakija je reagovao/la na ovo 1
Zen Mod Napisano April 4, 2021 #3 Napisano April 4, 2021 vis, mogao bi i to da napravim, jednom, da ne stoji u kutiji
chakija Napisano Septembar 5, 2021 Autor #7 Napisano Septembar 5, 2021 (izmenjeno) ap može i varijanta sa 9028/9038pro Izmenjeno Septembar 5, 2021 od chakija
shonne Napisano Mart 14, 2022 #8 Napisano Mart 14, 2022 @chakija Pratis li ovu temu? Buffalo III upgraded with ES9028Pro | diyAudio WWW.DIYAUDIO.COM Since I happened to have a burned out Buffalo III board, I experimented with mounting an ES9028Pro on it. Since the 9028 has the same pinout as the 9018, all that needs to change on the B3...
chakija Napisano Mart 15, 2022 Autor #9 Napisano Mart 15, 2022 Ne pratim Uživam u kombinaciji 9018/mercury shonne je reagovao/la na ovo 1
