Stradi
Sve objavljeno od Stradi
  1. Stradi
    dobre MM zvučnice
    @paja959 slike (da ih ne kopiram ) Ovo ja zovem MK2 Jelacicevom ruckom a gledano realno ovo jeste Jelaciceva rucka bez obzira sto je uzet princip sa WTA rucke a ona predhodna koju ja zovem MK 1 verzijom je u stvari kopija WTA samo je Jelacic pravio masovno i jeste najbolje uradjen klon u bukvalnom smislu reci klon. (pozitivnom) ali je ipak WTA klon a ne Jelacic kao sto je MK 2. Nista lose ne mislim pod tim i sudeci da sam jednu posedovao a drugu slusao mislim da su 99 % identicnog zvuka ali je Jelacic malo komotnija ( i po meni dosta lepsa ali je to samo moje misljenje).
  2. Stradi
    dobre MM zvučnice
    Pa vidi ja sam Saxu dao na poklon Jelacic rucku MK1 nadam se da ti to nesto govori I o meni a i o tome da sam je valjda slusao a MK2 sam slusao kod prijatelja bar 4 god sa Koetsu wood i black WDH frog EMt mono nekom Shure Denon 103 i i sta ne vec vise se i ne secam. Tako da je moj balkon prvi red partera mislim. Ja sam kopirao nesto da ima kome zatreba cak nisam ni komentarisao nista vezano za zvuk konkretno ali kad nekome nesto ili neko nije potaman onda.....
  3. Stradi
    dobre MM zvučnice
    Calculating tonearm's effective massThe easiest way to calculate the effective mass of a tonearm-headshell–cartridge assembly is to sum the (given) effective mass of the tonearm and the weights of the headshell and cartridge. The effective mass calculated this way is not exact and should used only as a directive. A more thorough way to calculate the effective mass is the following:M=I/L^2M = effective mass in gramsI = inertia of all tonearm parts combinedL= distance from tonearm pivot to stylus in millimeters (Lenco stock arm 228 mm)Calculating inertiaInertia of each part of the tonearm assembly needs to be calculated individually. If a part goes past the tonearm's pivot point, both sides are considered to be individual parts. The results are then summed up to get the inertia of the complete tonearm assembly. I=md^2I = inertia of the considered partm = mass of the considered part in gramsd = distance from the middle of the considered part to tonearm pivot in millimetersParts that need to be taken into account (Standard Lenco L75 arm):-Counterweight (mass and distance to the pivot)-VTF weight (mass and distance to the pivot)-Rear part of the arm (mass (25g) and distance to the pivot (lenght of the part halved))-Arm tube (mass (9.3g) and distance to the pivot (distance from the end of the arm tube to the pivot halved))-Headshell and cartridge assembly (mass and distance to the pivot from the middle point of the headshell)Resonance frequency-Resonance frequency within 7-12 Hz is optimal for the system. -Resonance frequency slightly outside optimal interval (~6-7 Hz and ~12-15 Hz) can be considered as a possible that probably can be used without problems.-Resonance frequency outside the interval 6-15 Hz is questionable.Diagram: resonance frequency, effective mass and cartridge complianceCalculating resonance frequencyf=1000/(2 π√(MC)) f = cartridge resonance frequency in HzC = cartridge compliance lateral in µm/mNM = effective mass of tonearm assembly in grams
  4. Stradi
    dobre MM zvučnice
    Cartridge compliance-Compliance up to 10 µm/mN (or CU, compliance unit, or equal amount x 10-6cm/dyne) is considered low. -Compliance in the range of 10 to 20 µm/mN is moderate. -Compliance in the range of 20 to 35 µm/mN is high. -Compliance value above 35 µm/mN is very high.Effective (dynamic) mass of the tonearm-Low mass arms* mate well with both moderately high and very high compliance phono cartridges. *A tonearm whose effective mass is rated at 10 grams or below is considered low mass (e.g. early SME’s, Grace 747).-Moderate mass arms** are good companions for moderate to low compliance cartridges. **A tonearm whose effective mass is rated between 11 and 25 grams is considered moderate mass (e.g. SME 309, IV, IV-VI, V, Triplanar, Graham). Arms above 25 grams of mass are high mass in nature (Eminent Technology, Dynavector). Kompilijansa Decce je 10 sto je na gornjoj granici low compilijance a Koetcu je kompilijansa 5 . Jasno vam je koje masse rucke su tu pozeljne. Low mass arms mate well with both moderately high and very high compliance phono cartridges. * Moderate mass tonearms are good companions for moderate to low compliance cartridges. * If a low compliance cartridge is used with a low mass tonearm, undesirable resonances can occur in the audible range. Mis-tracking may also be a problem. * When a high compliance cartridge is mated with a moderate mass tonearm, resonances in the infrasonic range may occur in addition to some unwanted high frequency damping. To je neka opsta teorija koja je tacna ali u praksi ima svasta. Jelacic je pravio ako se nevaram low mass rucke. Evo postavicu i kako se racuna effective mass i ostalo.
  5. Sve to moze ali na kraju krajeva mislim da dampiranje mehanizma treba najvise da znaci , Pogledaj malo kako su izvedena neka fabricka resenja pa probaj nesto da iskombinujes, Neka tvoja ideja o bitnim tackama za dampiranje, Pogledaj VRDS (mislim da je jedan od najboljih) sistem transporta njemu je ona klampa odozgo teska poprilicno to je neki metal ili legura neka pa nekako dampiraj tvoj da ima slican efekat na disk tj da nema disk vibracija dok radi. Sa druge strane ja sam svojevremeno imao CD player sa cd rom sistem unutra znaci najgore i najeftinije resenje a svirao je odlicno i bio dosta cenjen u svetu po zvuku (mozda bi svirao bolje da je bio bolji mehanizam ali svirao je odlicno i bez). Na ovom Teac koji sada imam unutrasnjost ima dva poklopca da tako kazem jedan koji vidis spolja kao taj tvoj i jos jedan unutra a izmedj njih je tanak neki filc i po ivicama tog spoljneg poklopca sa unutrasnje strane su zalepljene neke trake kao onaj diht za vrata i prozore samo pun materijal a ne supalj. Eto ako nesto znaci . Nije losa ta ideja sa drvenim poklopcem samo onda neki javor da bude sto teze , i ja sam uvek za prirodne materijale.
  6. Sad ja kao laik. Treba ukrutitu tu veliku povrsinu poklopca kad si vec resio to da radis. Podloga misa je mekana . Tu moze eventualno onaj materijal sto se lepi na unutrasnju stranu od vrata automobila da ne bi zvonila i uvijala se od vetra. Nije bas jeftino a ima u Wurth-u.
  7. I za kraj veceras
  8. Od najdrazih
  9. Posle mesec i 1/2 dana cekanja naizad
  10. Drugaciji i sensibilitet i tehnika.
  11. Pa onda tema gubi draz, Polako pa ce biti svega . Mislim da je tako jedino OK. Imas bezbroj odlicnih preporuka u temi Trenutno na gramofonu sa odlicnim opisima pojedinih dela i izdanja tako da pogledaj tamo, Predpostavljam da ce se dosta toga i ovde vremenom ponoviti sto bih bar zeleo jer je meni primarna zelja bila bas to da se objedini klasika sto vise na jednom mestu.
  12. I za kasnije apsolutno fenomenalna Yuja Wang. Vise nego preporucujem skoro sva njena izvodjenja. Mocarta posebno.
  13. Subota popodne, ostah sam kod kuce
  14. I ovo izvodi Denis Matsuev. Ja sam juce postavio klavirski no2 koncert u onoj temi za klasicnu muziku. Izgleda se specijalizovao za Rahmanjinova sto je stvarno nesto jako, jako posebno. Ne samo tehnika nego mu tonovi zvuce potpuno zaokruzeni. Postao sam pa mogu reci obozavalac u neku ruku jer jedno dva dela kada umetnik odsvira moze da bude i da je tada bio nadahnut. Slusao sam vise izvodjenja Denisa i nije samo nadahnut u trenutku . Lep izbor ova rapsodija za subotu .
  15. Jedno od najtezih dela za izvodjenje na klaviru ako ne i najteze Rahmanjinov klavirski koncert No3 Jedan siroj javnosti manje poznati pijanista koji je po mom skromnom misljenju ovde pokazao sav svoj preraskosan talenat i tehniku i to na takvom masivno teskom delu. I orkestar je fantastican sto cete cuti i sami.
  16. Kako to oseca i izvodi stvaralac Kako to oseca i izvodi umetnik Neki od komentara za izvodjenje I love Richter's tempi here - even though they're not Rachmaninov's. This is a sublime interpretation from start to finish and there is much more audible detail than in most modern performances. There is a mighty intellect at work here as well as unalloyed passion which never trespasses into sentiment. It's all truly wonderful. And now I can listen to it whenever I please. Thank you so much for posting this. It is a real treasure.
  17. Copernicus Chamber Orchestra, Horst Sohm (conducting/Leitung) Tomaso Albinoni - Adagio en sol menor, in G minor, Live in concert - Festival de Musica de L´Escala Concerts Clàssics L'Escala-Empúries Live performance - 2011
  18. Evo teme za sve ljubitelje i slusaoce klasicne muzike. Otvorena sa namerom lakseg pregleda i trazenja od strane onih koje ova vrsta muzike privlaci pa da eto sto vise toga bude pod jednom kapom a ne rasuto po mnogim temama. Sa komentarima ili bez njih, slikama ili snimcima kao i obavestavanjima ili opisima desavanja a vezanim za ovaj zanr muzike. Jednom reci sve sto je sa i oko klasicne muzike.
  19. Stradi
    Philips cd 204
  • Trenutno na sajtu   1 član, 0 Skrivenih, 1879 Gosta (Pogledaj celu listu)
